E-Series storage systems
Modify connection settings for SANtricity Remote Storage Volumes
Contributors NetAppZacharyWambold netapp-jolieg
You can edit, add, or delete connection settings for any remote storage configuration through the View/Edit Settings option.
Making changes to connection properties will affect in-progress imports. To avoid disruptions, only make changes to connection properties when imports are not running.
Steps
  1. From the Remote Storage screen of the SANtricity System Manager, select the desired Remote Storage object under the result list section.
  2. Click View/Edit Settings.
    The Remote Storage Settings screen is displayed.
  3. Click the Connection Properties tab.
    The configured IP address and port settings for the remote storage import are displayed.
  4. Perform one of the following actions:
    • Edit – Click Edit next to the corresponding line item for the remote storage object. Enter the revised IP address and/or port information in the fields.
    • Add – Click Add, and then enter the new IP address and port information in the fields provided. Click Add to confirm, and then the new connection appears in the list of remote storage objects.
    • Delete – Select the desired connection from the list and then click Delete. Confirm the operation by typing delete in the provided field and then click Delete. The connection is removed from the list of remote storage objects.
  5. Click Save.
    The modified connection settings are applied to the remote storage object.
