Element Software
Remove the QoS policy association of a volume
Contributors netapp-pcarriga
You can remove a QoS policy association from a volume by selecting custom QoS settings.
The volume you want to modify should be associated with a QoS policy.
  1. Select Management > Volumes.
  2. Click the Actions icon for a volume that contains a QoS policy you want to modify.
  3. Click Edit.
  4. In the resulting menu under Quality of Service, click Custom Settings.
  5. Modify Min IOPS, Max IOPS, and Burst IOPS, or keep the default settings.
  6. Click Save Changes.
Find more information
