Configure the cluster to listen for NTP broadcasts
By using the broadcast mode, you can instruct each node in a cluster to listen on the network for Network Time Protocol (NTP) broadcast messages from a particular server.
What you'll need
You must have cluster administrator privileges to configure this setting.
You must configure an NTP server on your network as a broadcast server.
Steps
Click Cluster > Settings.
Enter the NTP server or servers that are using broadcast mode into the server list.
Under Network Time Protocol Settings, select Yes to use a broadcast client.
To set the broadcast client, in the Server field, enter the NTP server you configured in broadcast mode.
Click Save Changes.
