Element Software
Event types
Contributors netapp-pcarriga
The system reports multiple types of events; each event is an operation that the system has completed. Events can be routine, normal events or events that require administrator attention. The Event Types column on the Event Log page indicates in which part of the system the event occurred.
Note The system does not log read-only API commands in the event log.
The following list describes the types of events that appear in the event log:
  • apiEvent
    Events initiated by a user through an API or web UI that modify settings.
  • binAssignmentsEvent
    Events related to the assignment of data bins. Bins are essentially containers that hold data and are mapped across the cluster.
  • binSyncEvent
    System events related to a reassignment of data among block services.
  • bsCheckEvent
    System events related to block service checks.
  • bsKillEvent
    System events related to block service terminations.
  • bulkOpEvent
    Events related to operations performed on an entire volume, such as a backup, restore, snapshot, or clone.
  • cloneEvent
    Events related to volume cloning.
  • clusterMasterEvent
    Events appearing upon cluster initialization or upon configuration changes to the cluster, such as adding or removing nodes.
  • cSumEvent
    Events related to the detection of a checksum mismatch during end-to-end checksum validation.
    Services that detect a checksum mismatch are automatically stopped and not restarted after generating this event.
  • dataEvent
    Events related to reading and writing data.
  • dbEvent
    Events related to the global database maintained by ensemble nodes in the cluster.
  • driveEvent
    Events related to drive operations.
  • encryptionAtRestEvent
    Events related to the process of encryption on a cluster.
  • ensembleEvent
    Events related to increasing or decreasing the number of nodes in an ensemble.
  • fibreChannelEvent
    Events related to the configuration of and connections to the nodes.
  • gcEvent
    Events related to processes run every 60 minutes to reclaim storage on block drives. This process is also known as garbage collection.
  • ieEvent
    Internal system error.
  • installEvent
    Automatic software installation events. Software is being automatically installed on a pending node.
  • iSCSIEvent
    Events related to iSCSI issues in the system.
  • limitEvent
    Events related to the number of volumes or virtual volumes in an account or in the cluster nearing the maximum allowed.
  • maintenanceModeEvent
    Events related to the node maintenance mode, such as disabling the node.
  • networkEvent
    Events related to the network error reporting for each physical network interface card (NIC) interface.
    These events are triggered when any error count for an interface exceeds a default threshold of 1000 during a 10-minute monitoring interval. These events apply to network errors such as received misses, cyclic redundancy check (CRC) errors, length errors, overrun errors, and frame errors.
  • platformHardwareEvent
    Events related to issues detected on hardware devices.
  • remoteClusterEvent
    Events related to remote cluster pairing.
  • schedulerEvent
    Events related to scheduled snapshots.
  • serviceEvent
    Events related to system service status.
  • sliceEvent
    Events related to the Slice Server, such as removing a metadata drive or volume.
    There are three types of slice reassignment events, which include information about the service where a volume is assigned:
    • flipping: changing the primary service to a new primary service
      sliceID oldPrimaryServiceID->newPrimaryServiceID
    • moving: changing the secondary service to a new secondary service
      sliceID {oldSecondaryServiceID(s)}->{newSecondaryServiceID(s)}
    • pruning: removing a volume from a set of services
  • snmpTrapEvent
    Events related to SNMP traps.
  • statEvent
    Events related to system statistics.
  • tsEvent
    Events related to the system transport service.
  • unexpectedException
    Events related to unexpected system exceptions.
  • ureEvent
    Events related to Unrecoverable Read Errors that occur while reading from the storage device.
  • vasaProviderEvent
    Events related to a VASA (vSphere APIs for Storage Awareness) Provider.
