Element Software
Prepare Element cluster for FIPS drives feature
Contributors netapp-pcarriga
Security is becoming increasingly critical for the deployment of solutions in many customer environments. Federal Information Processing Standards (FIPS) are standards for computer security and interoperability. FIPS 140-2 certified encryption for data at rest is a component of the overall security solution.
To prepare for enabling the FIPS drives feature, you should avoid mixing nodes where some are FIPS drives capable and some are not.
A cluster is considered FIPS drives compliant based on the following conditions:
  • All drives are certified as FIPS drives.
  • All nodes are FIPS drives nodes.
  • Encryption at Rest (EAR) is enabled.
  • The FIPS drives feature is enabled. All drives and nodes must be FIPS capable and Encryption at Rest must be enabled in order to enable the FIPS drive feature.
