Perform the prerequisite tasks for installation
Ensure that you perform the necessary checks and verify that your environment meets the configuration, IP addressing, and networking requirements before you install SolidFire eSDS.
Install the supported server. See NetApp Interoperability Matrix (login required) for more information.
Ensure that your hardware configuration is balanced and all channels are populated. For more information about maximizing bandwidth, see the KB article (login required).
Install RHEL based on the supported versions listed in the NetApp Interoperability Matrix (login required).
Configure a Network Time Protocol (NTP) server to use with all the hosts in your network.
When selecting the installation destination, select the radio button to manually configure file system partitioning. On the Manual Partitioning page, use the + and - buttons to remove any existing partitions, and create new partitions and size them following the recommendations listed here. Using the default LVM partitioning scheme enables you to easily resize later, if needed.
By default, RHEL chooses xfs
as the default file system for the partitions that you manually create. You should change it toext4
, except for the/boot
andswap
partitions. Your/boot
partition should useext2
.If your SATA disk is 250GB, follow the recommended partition below. If your SATA disk has more space, you can increase the /opt and /var partition sizes.
Partition Size /boot
1GB
/opt
50GB
/var
50GB
swap
4GB
/home
5GB
10GB minimum
/usr
10GB minimum
The /dev/sdb
disk is not used by any process. -
Disable RAID for /boot.
On the Software Selection screen, where you select specific packages to install, select Server or Infrastructure Server based on your RHEL version.
After the first boot, do the following:
Install Red Hat Subscription Manager, and enable the following repositories:
rhel-7-server-ansible-2.9-rpms rhel-7-server-optional-rpms rhel-7-server-extras-rpms
Enable SSH on your nodes.
If you want to disable IPv6, follow the steps detailed in this KB article (login required).
Install Ansible, Git, Podman, and Python 3.0.
For Element 12.3, the supported Podman version is 1.6.4.
Use the SolidFire eSDS configuration listed in the NetApp Interoperability Matrix Tool (IMT) as a reference.
If you contact NetApp Support for assistance with issues relating to SolidFire eSDS, Support will first verify that your platform complies with the reference configuration for SolidFire eSDS listed in the IMT. If Support determines that your underlying platform does not comply with the reference configuration, Support will guide you in aligning the non-compliant firmware, software, and/or hardware components with the correct versions in the IMT. -
Run a compliance check for SolidFire eSDS.
Run the
ansible-galaxy install
command to install thenar_solidfire_sds_compliance
role.ansible-galaxy install git+https://github.com/NetApp-Automation/nar_solidfire_sds_compliance.git
You can also manually install the role by copying it from the NetApp GitHub repository and placing the role in the
~/.ansible/roles
directory. NetApp provides a README file, which includes information about how to run a role.Ensure that you always download the latest versions of the roles. -
Move the roles that you downloaded up one directory from where they were installed.
$ mv ~/.ansible/roles/ansible/nar_solidfire_sds_* ~/.ansible/roles/
Run the
ansible-galaxy role list
command to ensure that Ansible is configured to utilize the new roles.- nar_solidfire_sds_install, (unknown version) - nar_solidfire_sds_upgrade, (unknown version) - ansible, (unknown version) - nar_solidfire_sds_compliance, (unknown version) - nar_solidfire_cluster_config, (unknown version) - nar_solidfire_sds_uninstall, (unknown version)
Create the playbook to use for the compliance check.
Run the compliance check playbook as shown in the following example:
$ ansible-playbook -i yourinventory.yml yourplaybook.yml
Even after you start using the SolidFire eSDS system, you should run the compliance check regularly to ensure that your system is in compliance. In some cases, NetApp Support will ask you to run the compliance check to help diagnose and troubleshoot issues. -
Familiarize yourself with how to configure and manage networks and network interfaces in RHEL. See the RedHat documentation.
Configure your network following the IP requirements detailed here:
Component Storage network IP address Management network IP address Total # of IP addresses Storage node
1
1
2 per node
Management node
(Optional) 1
1
1 per cluster on the storage network + 1 per cluster on the management network + 1 FQDN per cluster for the management node
Storage cluster
1 storage IP (SVIP)
1 management IP (MVIP)
2 per storage cluster
Configure the storage network on 25GbE Ethernet switches and the management network on 10GbE switches. See the following cabling illustration:
Item Description 1
Ports for storage network
2
Port for IPMI
3
Ports for management network
The illustration given here is intended to be an example. Your actual hardware might be different based on the server you have. |
Change the switch port MTU to 9216 bytes.
If
firewalld
is enabled on the storage node running RHEL, ensure that you have the following ports open, so that you can manage the system remotely, allow clients outside of your datacenter to connect to resources, and ensure that internal services can function properly:Source Destination Port Description Storage node MIP
Management node
80 TCP/UDP
Cluster upgrades
SNMP server
Storage node MIP
161 UDP
SNMP polling
System administrator PC
Management node
442 TCP
HTTPS UI access to management node
Storage node MIP
442 TCP
HTTPS UI access to storage node
iSCSI clients
Storage cluster MVIP
443 TCP
(Optional) UI and API access
Management node
monitoring.solidfire.com
443 TCP
Storage cluster reporting to Active IQ
Storage node MIP
Remote storage cluster MVIP
443 TCP
Remote replication cluster pairing communication
Storage node MIP
Remote storage node MIP
443 TCP
SolidFire eSDS sfapp
Per-node UI and API access to create a cluster
2010 UDP
Cluster beacon (to discover nodes to add to a cluster)
iSCSI clients
Storage cluster SVIP
3260 TCP
Client iSCSI communications
iSCSI clients
Storage cluster SIP
3260 TCP
SOAP server
7627 TCP
SOAP web services
N/A
8080 TCP
System administrator communications
vCenter Server
Management node
8443 TCP
vCenter Plug-in QoSSIOC service
Ports 2181, 2182, and 2183 are needed for are needed for the Element distributed database, and will be dynamically opened from the Element container when you install SolidFire eSDS. -
Use the following commands to open the ports mentioned above:
systemctl start firewalld firewall-cmd --permanent --add-service=snmp firewall-cmd --permanent --add-port=80/tcp firewall-cmd --permanent --add-port=80/udp firewall-cmd --permanent --add-port=442-443/tcp firewall-cmd --permanent --add-port=442-443/udp firewall-cmd --permanent --add-port=2010/udp firewall-cmd --permanent --add-source-port=2010/udp firewall-cmd --permanent --add-port=3260/tcp firewall-cmd --permanent --add-port=7627/tcp firewall-cmd --permanent --add-port=8080/tcp firewall-cmd --permanent --add-port=8443/tcp firewall-cmd –-reload
Configure your host network using the best practices provided.
You should complete the steps to configure your host network to ensure a successful installation of SolidFire eSDS.
Install One Collect, which will be used by NetApp Support for host log collection. You can install One Collect from here. You need a NetApp account to access the download. You can also find the One Collect Installation Guide and Release Notes at the same location.
You must download and install One Collect in order to receive an optimal support experience. -
Install the management node for log collection and to enable NetApp Support access for troubleshooting. For information about management node and installation steps, see here.
