Base infrastructure configuration
Contributors netapp-dorianh Download PDF of this page
Network connectivity
The following network connections must be in place before configuring the infrastructure:
  • Link aggregation using port channels and virtual port channels is used throughout, enabling the design for higher bandwidth and HA.
    • Virtual port channel is used between the Cisco FI and Cisco Nexus switches.
    • Each server has vNICs with redundant connectivity to the unified fabric. NIC failover is used between FI for redundancy.
    • Each server has vHBAs with redundant connectivity to the unified fabric.
  • The Cisco UCS FI are configured in end-host mode as recommended, providing dynamic pinning of vNICs to uplink switches.
Storage connectivity
The following storage connections must be in place before configuring the infrastructure:
  • Storage ports ifgroups (vPC)
  • 10G link to switch N9k-A
  • 10G link to switch N9k-B
  • In- band management (active-passive bond):
    • 1G link to management switch N9k-A
    • 1G link to management switch N9k-B
  • 16G FC end-to-end connectivity through Cisco MDS switches. Single initiator zoning configured.
  • FC SAN boot to fully achieve stateless computing. Servers are booted from LUNs in the boot volume hosted on the AFF storage cluster.
  • All Epic workloads are hosted on FC LUNs, which are spread across the storage controller nodes.
Host software
The following software must be installed:
  • ESXi is installed on the Cisco UCS blades.
  • vCenter is installed and configured, with all the hosts registered in vCenter.
  • VSC is installed and registered in vCenter.
  • A NetApp cluster is configured.
