Cisco Nexus 3172P deployment procedure
Contributors netapp-dorianh Download PDF of this page
The following section details the Cisco Nexus 3172P switch configuration used in a FlexPod Express environment.
Initial setup of Cisco Nexus 3172P switch
The following procedures describe how to configure the Cisco Nexus switches for use in a base FlexPod Express environment.
This procedure assumes that you are using a Cisco Nexus 3172P running NX-OS software release 7.0(3)I7(5).
  1. Upon initial boot and connection to the console port of the switch, the Cisco NX-OS setup automatically starts. This initial configuration addresses basic settings, such as the switch name, the mgmt0 interface configuration, and Secure Shell (SSH) setup.
  2. The FlexPod Express management network can be configured in multiple ways. The mgmt0 interfaces on the 3172P switches can be connected to an existing management network, or the mgmt0 interfaces of the 3172P switches can be connected in a back-to-back configuration. However, this link cannot be used for external management access such as SSH traffic.
    In this deployment guide, the FlexPod Express Cisco Nexus 3172P switches are connected to an existing management network.
  3. To configure the Cisco Nexus 3172P switches, power on the switch and follow the on- screen prompts, as illustrated here for the initial setup of both the switches, substituting the appropriate values for the switch-specific information.
    This setup utility will guide you through the basic configuration of
    the system. Setup configures only enough connectivity for management
    of the system.
    *Note: setup is mainly used for configuring the system initially,
    when no configuration is present. So setup always assumes system
    defaults and not the current system configuration values.
    Press Enter at anytime to skip a dialog. Use ctrl-c at anytime
    to skip the remaining dialogs.
    Would you like to enter the basic configuration dialog (yes/no): y
    Do you want to enforce secure password standard (yes/no) [y]: y
      Create another login account (yes/no) [n]: n
      Configure read-only SNMP community string (yes/no) [n]: n
      Configure read-write SNMP community string (yes/no) [n]: n
      Enter the switch name : 3172P-B
      Continue with Out-of-band (mgmt0) management configuration? (yes/no) [y]: y
        Mgmt0 IPv4 address : <<var_switch_mgmt_ip>>
        Mgmt0 IPv4 netmask : <<var_switch_mgmt_netmask>>
      Configure the default gateway? (yes/no) [y]: y
        IPv4 address of the default gateway : <<var_switch_mgmt_gateway>>
      Configure advanced IP options? (yes/no) [n]: n
      Enable the telnet service? (yes/no) [n]: n
      Enable the ssh service? (yes/no) [y]: y
        Type of ssh key you would like to generate (dsa/rsa) [rsa]: rsa
        Number of rsa key bits <1024-2048> [1024]:  <enter>
      Configure the ntp server? (yes/no) [n]: y
        NTP server IPv4 address : <<var_ntp_ip>>
      Configure default interface layer (L3/L2) [L2]: <enter>
      Configure default switchport interface state (shut/noshut) [noshut]:  <enter>
      Configure CoPP system profile (strict/moderate/lenient/dense) [strict]:  <enter>
  4. You then see a summary of your configuration, and you are asked if you would like to edit it. If your configuration is correct, enter n.
    Would you like to edit the configuration? (yes/no) [n]: n
  5. You are then asked if you would like to use this configuration and save it. If so, enter y.
    Use this configuration and save it? (yes/no) [y]: Enter
  6. Repeat this procedure for Cisco Nexus switch B.
Enable advanced features
Certain advanced features must be enabled in Cisco NX-OS to provide additional configuration options.
The interface-vlan feature is required only if you use the back-to-back mgmt0 option described throughout this document. This feature allows you to assign an IP address to the interface VLAN (switch virtual interface), which enables in-band management communication to the switch (such as through SSH).
  1. To enable the appropriate features on Cisco Nexus switch A and switch B, enter configuration mode using the command (config t) and run the following commands:
    feature interface-vlan
    feature lacp
    feature vpc
    The default port channel load-balancing hash uses the source and destination IP addresses to determine the load-balancing algorithm across the interfaces in the port channel. You can achieve better distribution across the members of the port channel by providing more inputs to the hash algorithm beyond the source and destination IP addresses. For the same reason, NetApp highly recommends adding the source and destination TCP ports to the hash algorithm.
  2. From configuration mode (config t), enter the following commands to set the global port channel load-balancing configuration on Cisco Nexus switch A and switch B:
    port-channel load-balance src-dst ip-l4port
Perform global spanning-tree configuration
The Cisco Nexus platform uses a new protection feature called bridge assurance. Bridge assurance helps protect against a unidirectional link or other software failure with a device that continues to forward data traffic when it is no longer running the spanning-tree algorithm. Ports can be placed in one of several states, including network or edge, depending on the platform.
NetApp recommends setting bridge assurance so that all ports are considered to be network ports by default. This setting forces the network administrator to review the configuration of each port. It also reveals the most common configuration errors, such as unidentified edge ports or a neighbor that does not have the bridge assurance feature enabled. In addition, it is safer to have the spanning tree block many ports rather than too few, which allows the default port state to enhance the overall stability of the network.
Pay close attention to the spanning- tree state when adding servers, storage, and uplink switches, especially if they do not support bridge assurance. In such cases, you might need to change the port type to make the ports active.
The Bridge Protocol Data Unit (BPDU) guard is enabled on edge ports by default as another layer of protection. To prevent loops in the network, this feature shuts down the port if BPDUs from another switch are seen on this interface.
From configuration mode (config t), run the following commands to configure the default spanning- tree options, including the default port type and BPDU guard, on Cisco Nexus switch A and switch B:
spanning-tree port type network default
spanning-tree port type edge bpduguard default
Define VLANs
Before individual ports with different VLANs are configured, the layer 2 VLANs must be defined on the switch. It is also a good practice to name the VLANs for easy troubleshooting in the future.
From configuration mode (config t), run the following commands to define and describe the layer 2 VLANs on Cisco Nexus switch A and switch B:
vlan <<nfs_vlan_id>>
  name NFS-VLAN
vlan <<iSCSI_A_vlan_id>>
  name iSCSI-A-VLAN
vlan <<iSCSI_B_vlan_id>>
  name iSCSI-B-VLAN
vlan <<vmotion_vlan_id>>
  name vMotion-VLAN
vlan <<vmtraffic_vlan_id>>
  name VM-Traffic-VLAN
vlan <<mgmt_vlan_id>>
  name MGMT-VLAN
vlan <<native_vlan_id>>
  name NATIVE-VLAN
exit
Configure access and management port descriptions
As is the case with assigning names to the layer 2 VLANs, setting descriptions for all the interfaces can help with both provisioning and troubleshooting.
From configuration mode (config t) in each of the switches, enter the following port descriptions for the FlexPod Express large configuration:
Cisco Nexus Switch A
int eth1/1
  description AFF A220-A e0c
int eth1/2
  description AFF A220-B e0c
int eth1/3
  description UCS-Server-A: MLOM port 0
int eth1/4
  description UCS-Server-B: MLOM port 0
int eth1/25
  description vPC peer-link 3172P-B 1/25
int eth1/26
  description vPC peer-link 3172P-B 1/26
int eth1/33
  description AFF A220-A e0M
int eth1/34
  description UCS Server A: CIMC
Cisco Nexus Switch B
int eth1/1
  description AFF A220-A e0d
int eth1/2
  description AFF A220-B e0d
int eth1/3
  description UCS-Server-A: MLOM port 1
int eth1/4
  description UCS-Server-B: MLOM port 1
int eth1/25
  description vPC peer-link 3172P-A 1/25
int eth1/26
  description vPC peer-link 3172P-A 1/26
int eth1/33
  description AFF A220-B e0M
int eth1/34
  description UCS Server B: CIMC
Configure server and storage management interfaces
The management interfaces for both the server and the storage typically use only a single VLAN. Therefore, configure the management interface ports as access ports. Define the management VLAN for each switch and change the spanning-tree port type to edge.
From configuration mode (config t), enter the following commands to configure the port settings for the management interfaces of both the servers and the storage:
int eth1/33-34
  switchport mode access
  switchport access vlan <<mgmt_vlan>>
  speed 1000
exit
int eth1/33-34
  speed 1000
exit
Perform virtual port channel global configuration
A virtual port channel (vPC) enables links that are physically connected to two different Cisco Nexus switches to appear as a single port channel to a third device. The third device can be a switch, server, or any other networking device. A vPC can provide layer-2 multipathing, which allows you to create redundancy by increasing bandwidth, enabling multiple parallel paths between nodes, and load-balancing traffic where alternative paths exist.
A vPC provides the following benefits:
  • Enabling a single device to use a port channel across two upstream devices
  • Eliminating spanning-tree protocol blocked ports
  • Providing a loop-free topology
  • Using all available uplink bandwidth
  • Providing fast convergence if either the link or a device fails
  • Providing link-level resiliency
  • Helping provide high availability
The vPC feature requires some initial setup between the two Cisco Nexus switches to function properly. If you use the back-to-back mgmt0 configuration, use the addresses defined on the interfaces and verify that they can communicate by using the ping [switch_A/B_mgmt0_ip_addr]vrf management command.
From configuration mode (config t), run the following commands to configure the vPC global configuration for both switches:
vpc domain 1
 role priority 10
  peer-keepalive destination <<switch_B_mgmt0_ip_addr>> source <<switch_A_mgmt0_ip_addr>> vrf management
  peer-gateway
  auto-recovery
  ip arp synchronize
int eth1/25-26
  channel-group 10 mode active
int Po10
  switchport
  switchport mode trunk
  switchport trunk native vlan <<native_vlan_id>>
  switchport trunk allowed vlan <<nfs_vlan_id>>,<<vmotion_vlan_id>>, <<vmtraffic_vlan_id>>, <<mgmt_vlan>, <<iSCSI_A_vlan_id>>, <<iSCSI_B_vlan_id>>
  vpc peer-link
  no shut
exit
copy run start
vpc domain 1
  peer-switch
  role priority 20
  peer-keepalive destination <<switch_A_mgmt0_ip_addr>> source <<switch_B_mgmt0_ip_addr>> vrf management
  peer-gateway
  auto-recovery
  ip arp synchronize
int eth1/25- 26
int Po10
  switchport
  switchport trunk allowed vlan <<nfs_vlan_id>>,<<vmotion_vlan_id>>, <<vmtraffic_vlan_id>>, <<mgmt_vlan>>, <<iSCSI_A_vlan_id>>, <<iSCSI_B_vlan_id>>
  vpc peer-link
no shut
exit
copy run start
Configure storage port channels
The NetApp storage controllers allow an active-active connection to the network using the Link Aggregation Control Protocol (LACP). The use of LACP is preferred because it adds both negotiation and logging between the switches. Because the network is set up for vPC, this approach enables you to have active-active connections from the storage to separate physical switches. Each controller has two links to each of the switches. However, all four links are part of the same vPC and interface group (IFGRP).
From configuration mode (config t), run the following commands on each of the switches to configure the individual interfaces and the resulting port channel configuration for the ports connected to the NetApp AFF controller.
  1. Run the following commands on switch A and switch B to configure the port channels for storage controller A:
    int eth1/1
      channel-group 11 mode active
    int Po11
      description vPC to Controller-A
      switchport
      switchport trunk allowed vlan <<nfs_vlan_id>>,<<mgmt_vlan_id>>,<<iSCSI_A_vlan_id>>, <<iSCSI_B_vlan_id>>
      spanning-tree port type edge trunk
      mtu 9216
      vpc 11
      no shut
  2. Run the following commands on switch A and switch B to configure the port channels for storage controller B.
    int eth1/2
      channel-group 12 mode active
    int Po12
      description vPC to Controller-B
      switchport
      switchport trunk allowed vlan <<nfs_vlan_id>>,<<mgmt_vlan_id>>, <<iSCSI_A_vlan_id>>, <<iSCSI_B_vlan_id>>
      mtu 9216
      vpc 12
      no shut
    exit
    copy run start
    In this solution validation, an MTU of 9000 was used. However, based on application requirements, you can configure an appropriate value of MTU. It is important to set the same MTU value across the FlexPod solution. Incorrect MTU configurations between components will result in packets being dropped and these packets.
Configure server connections
The Cisco UCS servers have a two-port virtual interface card, VIC1387, that is used for data traffic and booting of the ESXi operating system using iSCSI. These interfaces are configured to fail over to one another, providing additional redundancy beyond a single link. Spreading these links across multiple switches enables the server to survive even a complete switch failure.
From configuration mode (config t), run the following commands to configure the port settings for the interfaces connected to each server.
Cisco Nexus Switch A: Cisco UCS Server-A and Cisco UCS Server-B configuration
int eth1/3-4
  switchport trunk allowed vlan <<iSCSI_A_vlan_id>>,<<nfs_vlan_id>>,<<vmotion_vlan_id>>,<<vmtraffic_vlan_id>>,<<mgmt_vlan_id>>
  mtu9216
  no shut
exit
copy run start
Cisco Nexus Switch B: Cisco UCS Server-A and Cisco UCS Server-B configuration
int eth1/3-4
  switchport trunk allowed vlan <<iSCSI_B_vlan_id>>,<<nfs_vlan_id>>,<<vmotion_vlan_id>>,<<vmtraffic_vlan_id>>,<<mgmt_vlan_id>>
  mtu 9216
  no shut
exit
copy run start
In this solution validation, an MTU of 9000 was used. However, based on application requirements, you can configure an appropriate value of MTU. It is important to set the same MTU value across the FlexPod solution. Incorrect MTU configurations between components will result in packets being dropped and these packets will need to be transmitted again. This will affect the overall performance of the solution.
To scale the solution by adding additional Cisco UCS servers, run the previous commands with the switch ports that the newly added servers have been plugged into on switches A and B.
Depending on the available network infrastructure, several methods and features can be used to uplink the FlexPod environment. If an existing Cisco Nexus environment is present, NetApp recommends using vPCs to uplink the Cisco Nexus 3172P switches included in the FlexPod environment into the infrastructure. The uplinks may be 10GbE uplinks for a 10GbE infrastructure solution or 1GbE for a 1GbE infrastructure solution if required. The previously described procedures can be used to create an uplink vPC to the existing environment. Make sure to run copy run start to save the configuration on each switch after the configuration is completed.
