FlexPod
Cisco components
Contributors LuiMK1
Cisco is a substantial contributor to the FlexPod Express design and architecture; it contributes the compute and networking layers of the solution. This section describes the Cisco UCS and Cisco Nexus components that are available for FlexPod Express.
Cisco UCS X-Series Direct
Cisco UCS X-Series Direct is a new architecture that integrates a pair of Cisco UCS Fabric Interconnect 9108 100G with Cisco UCS X9508 Chassis and Cisco UCS X-Series Compute nodes to deliver the UCS X-Series Direct solution.
For a quick overview of Cisco UCS X-Series capabilities and features, see Cisco UCS X-Series Direct At-a-Glance.
Cisco UCS X-Series Direct consists of the following components:
  • Cisco UCS 9108 100G Fabric Interconnect
  • Cisco UCS X9508 Chassis
  • Cisco UCS X-Series Compute Nodes
  • Optional components:
    • PCIe Nodes and X-Fabric Module
    • Second Cisco UCS X9508 Chassis with X-Series Compute Nodes and Cisco UCS 9108-100G Intelligent Fabric Modules and up to four C-Series Rack Servers
Note Refer to this link for the complete technical specification for UCS X-Series Direct: Cisco UCS X-Series Direct Datasheet.
Refer to the tables below for the technical specifications for the X-Series Direct components.
Cisco UCS X-Series Direct fabric interconnect Part number Technical specifications
UCSX-S9108-100G
Cisco UCS 9108 Fabric Interconnect
Cisco UCS X-Series Direct Chassis Part number Technical specifications
UCSX-9508
Cisco UCS X-Series Direct compute nodes Part number Technical specifications
Cisco UCS X210c M7
UCSX-210C-M7
Cisco UCS X210c M7 Compute Node
Cisco UCS X210c M8
UCSX-210C-M8
Cisco UCS X210c M8 Compute Node
Cisco UCS X215c M8
UCSX-215C-M8
Cisco UCS X215c M8 Compute Node
Cisco UCS X410c M7
UCSX-410C-M7
Cisco UCS X410c M7 Compute Node
Cisco UCS X410c M8
UCSX-410C-M8
Cisco UCS X410c M8 Compute Node
Cisco UCS X-Series Direct Modules Part number Technical specifications
Cisco UCS 9108 Intelligent Fabric Module
UCSX-I-9108-100G
Cisco UCS X9416 X-Fabric Module
UCSX-FS-9416
Cisco UCS X440p PCIe Node
UCSX-440P
Cisco Unified Edge
Cisco Unified Edge is an AI-ready system that redefines computing at the edge by converging compute, networking, storage, and security. The modular design is future-ready, energy-efficient, and easy-to-service and can be tailored to support today’s workloads and use cases while remaining adaptable to the rapidly evolving AI landscape.
For a quick overview of Cisco Unified Edge capabilities and features, see Cisco Unified Edge At-a-Glance.
Cisco Unified Edge consists of the following components:
  • Cisco UCS XE9305 Chassis
  • Two Cisco Unified Edge Management Controllers with embedded 25G switches
  • Compute Nodes - Choice of
    • Cisco UCS XE130c M8 Compute Node
    • Cisco UCS XE150c M8 Compute Node
The tables below list the Cisco Unified Edge chassis and compute nodes options.
Cisco Unified Edge chassis Part number Technical specifications
UCSXE-9305-U
Cisco Unified Edge compute nodes Part number Technical specifications
UCSXE-130C-M8
UCSXE-150C-M8
Cisco UCS C-Series rack server options
Cisco UCS C-Series Rack Servers are available in one, two and four rack-unit (RU) varieties, with various CPU, memory, and I/O options. The part numbers that are listed in the following table are for the base servers. They do not include CPUs, memory, drives, Peripheral Component Interconnect Express (PCIe) cards. Multiple configuration options are available and are supported in the FlexPod architecture.
The following table lists the Cisco UCS C-Series Rack Server options.
Cisco UCS C-Series rack server Part number Technical specifications
Cisco UCS C220 M7
UCSC-C220-M7
Cisco UCS C220 M7 Rack Server
Cisco UCS C220 M8
UCSC-C220-M8
Cisco UCS C220 M8 Rack Server
Cisco UCS C225 M8
UCSC-C225-M8
Cisco UCS C225 M8 Rack Server
Cisco UCS C240 M7
UCSC-C240-M7
Cisco UCS C240 M7 Rack Server
Cisco UCS C240 M8
UCSC-C240-M8
Cisco UCS C240 M8 Rack Server
Cisco UCS C245 M8
UCSC-C245-M8
Cisco UCS C245 M8 Rack Server
Cisco Nexus Switches
Redundant Cisco Nexus Switches are required in the FlexPod architecture.
Cisco Nexus switch Technical specifications
Cisco Nexus 9200 series switch
Cisco Nexus 9200 Series Switches
Cisco Nexus 9300 series switch
Cisco Nexus 9300 Series Switches
Cisco Support licensing options
Note It is recommended to confirm licensing requirements with your Cisco or NetApp sales representative prior to ordering.
Cisco Solution Support is a Technical Support Service offer that applies to Cisco solutions that include both Hardware and Software from Cisco only or from Cisco and Solution Support Alliance Partners and are comprised of solely Cisco Products and products provided by third party vendors (Solution Support Alliance Partner(s)).
Cisco supports complex customer environments through its Technical Assistance Center. Cisco Solution Support entitles customer access to a team of TAC engineers, who provide a primary point of contact for issues found within the solution, as well as Product support for the Hardware and Software that comprise the solution.
Cisco leverages the TSANet Partner Program framework to onboard Solution Support Partners into a private group on the TSANet Connect system. TSANet Connect provides a consistent method for Support Engineers to collaborate with Partners’ technical teams, ensuring efficient communication and accelerated problem resolution without the friction caused by informal efforts to work with partners.
