Legacy equipment
The following table lists the NetApp legacy storage controller options.
| Storage controller | FAS part number | Technical specifications |
FAS2520 |
Based on individual options chosen |
http://www.netapp.com/us/products/storage-systems/fas2500/fas2500-tech-specs.aspx |
FAS2552 |
FAS2554 |
FAS8020 |
http://www.netapp.com/us/products/storage-systems/fas8000/fas8000-tech-specs.aspx |
The following table lists the NetApp legacy disk shelf options for NetApp FAS.
| Disk shelf | Part number | Technical specifications |
DE1600 |
E-X5682A-DM-0E-R6-C |
Disk Shelves Technical Specifications Supported Drives on NetApp Hardware Universe |
DE5600 |
E-X4041A-12-R6 |
DE6600 |
X-48564-00-R6 |
NetApp legacy FAS controllers
The following table lists the legacy NetApp FAS controller options.
| Current component | FAS2554 | FAS2552 | FAS2520 |
Configuration |
2 controllers in a 4U chassis |
2 controllers in a 2U chassis |
Maximum raw capacity |
576TB |
509TB |
336TB |
Internal drives |
24 |
24 |
12 |
Maximum number of drives (internal plus external) |
144 |
144 |
84 |
Maximum volume size |
60TB |
Maximum aggregate size |
120TB |
Maximum number of LUNs |
2,048 per controller |
Storage networking supported |
iSCSI, FC, FCoE, NFS, and CIFS |
iSCSI, NFS, and CIFS |
Maximum number of NetApp FlexVol volumes |
1,000 per controller |
Maximum number of NetApp Snapshot copies |
255,000 per controller |
For more NetApp FAS models, see the FAS models section in the Hardware Universe. |
