Minimum hardware requirements
This section describes the minimum hardware requirements for the different versions of FlexPod Express.
FlexPod Express with NetApp AFF/ ASA/ FAS
The hardware requirements for FlexPod Express solutions that use NetApp AFF, ASA, or FAS controllers for underlying storage include the configurations described in this section.
The minimum hardware requirement for FlexPod Express is listed below:
Two 10Gbps standard Ethernet switches in a redundant configuration (Cisco Nexus 9200 and 9300 models)
Two Cisco UCS C-Series standalone rack servers with CIMC based standalone rack server configuration or Intersight standalone configuration, or the Cisco UCS X-Series Direct with Cisco Intersight-managed configuration(IMM).
Two entry-level NetApp AFF (A20, A30, or C30), NetApp ASA (A20, A30, or C30), or NetApp FAS (2750, 2820, or 50) controllers in a high-availability (HA) pair configuration deployed as a two-node cluster
