FlexPod
Other requirements
Contributors LuiMK1 netapp-jyhshing
Additional requirements for FlexPod Express include the following:
  • If you plan to use VMware ESXi as the hypervisor, refer to the Broadcom Compatibility Guide to verify that your hardware and software components are supported.
  • For an OpenShift based deployment, ensure that you have the necessary hardware and software components that are compatible with OpenShift. Refer to the OpenShift Catalog for more information.
