Monitor NetApp storage from Cisco Intersight
After targets are claimed, NetApp storage widgets, storage inventory, and virtualization tabs become available if you have an Advantage tier license. Orchestration tabs are available if you have a Premier tier license.
Storage inventory overview
The following screenshot displays the Operate > Storage screen.
The following screenshot shows the storage cluster overview.
The following performance metric summary information will only display if the storage array is monitored through NetApp Active IQ Unified Manager 9.9 or above. |
Storage widgets
To view storage widgets, navigate to Monitoring > Dashboards > View NetApp storage widgets.
The following screenshot shows the Storage Version Summary widget.
This screenshot shows the Top 5 Storage Arrays by Capacity Utilization widget.
This screenshot shows the Top 5 Storage Volumes by Capacity Utilization widget.
