English
Storage classes with NetApp Kubernetes Service on NetApp HCI
Contributors amgrissino
After you enable cloud services on NetApp HCI and enable NetApp Kubernetes Service (NKS), Kubernetes storage classes are created.
When you add applications in NKS, you need to know the storage class and its provisioner.
Storage classes with NKS
The following table lists the storage classes and the associated provisioners and IOPS values.
Storage class Provisioner IOPS minimum IOPS maximum IOPS burst
solidfire-bronze
netapp.io/trident
1000
4000
6000
solidfire-silver
netapp.io/trident
5000
25,000
40,000
solidfire-gold
netapp.io/trident
15,000
180,000
200,000
vsphere (default)
kubernetes.io/vsphere-volume
NA
NA
NA
Storage class impact
Storage classes affect storage pools, QoS values, and persistent volume claims in the following ways:
  • Each NetApp Element storage class uses a unique storage pool.
  • Storage pools are identified by a set of unique QoS (IOPS) values.
  • When a Persistent Volume Claim (PVC) uses one of the "solidfire" storage classes, a volume within the referred storage pool is created on Element.
  • Trident creates the PV with the storage class and the storage pool attributes.
  • Kubernetes mounts the volume to the pod.
Example of PVC using a storage class
This example shows a volume created with the solidfire-gold storage class IOPS values on Element.
When a pod uses this PVC, the new volume with the solidfire-gold IOPS values is mounted to the pod.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
  - ReadWriteOnce
  resources:
	requests:
	  storage: 10Gi
  storageClassName: solidfire-gold
Find more information
