Modify the search criteria
From the Refine Search Criteria page, you can choose to modify the search criteria to add a solution, component, or category to the criteria.
Steps
  1. In the Refine Search Criteria page, click Change Criteria.
  2. In the search criteria page, you can add a solution, component, or category using the search text box.
  3. Click Next, to view the compatible configurations in the Refine Search Criteria page.
