Use Subscription
The Subscription link allows you to subscribe to Storage Solution, Category, or Component. If you have subscribed to a particular storage solution, category, or component, you will receive an email only if changes are made in the subscribed solutions, categories, or components.
You will receive emails for the following subscriptions:
  1. Storage Solution: When the changes are made in the status update, categories associated or disassociated, and configurations added or deleted.
  2. Category: When the components are added or deleted from the category.
  3. Component: When the changes are made in the display name of the component or state of the component.
    Note You will receive an email depending on the frequency type you select. The two frequency types are as follows:
    • Immediate: You will receive an email immediately when any changes are made to the subscribed solutions, categories, or components.
    • Digest: You will receive an accumulated email every seven days reflecting all the changes that are made to the subscribed solutions, categories, or components.
