Application Lifecycle Management: Projects Edit on GitHub Request doc changes
Contributors ebarcott
Projects are the top level of Application Lifecycle Management. Projects are created in your desired Workspace, and can contain any combination of Applications, Trackers, and Packages.
Note
Application Lifecycle Management is currently in Functional Preview mode. To enable this feature you will need to create a new cluster, and "Enable experimental features."
NKS app management
Requirements:
  • A cluster created in the desired Workspace, with "Experimental Features" enabled.
Create an Application Lifecycle Management Project
Log in to NKS, then go to App Management. Click View All Workspaces, then click the Workspace you want to use.
NKS app management
Click the Projects tab, then click Add A Project.
NKS app management
Name Your Project
Fill out the project’s name. The Kubernetes name will be automatically created, according to Kubernetes naming conventions. Select the cluster you want to use for your Application. Then click Next.
NKS app management
Configure Your Project
Customize Project Quotas, Pod Limits, and Container Limits to suit your needs. Click the lock button to unlock each section for editing. When you are ready to continue, click Next.
NKS app management
Invite Your Team:
By default, the project will use the same Roles and Permissions as the Workspace to which it is assigned. To accept the settings and create the project, click Create Project.
NKS app management
This creates the Project, and directs you to the Project’s landing page.
NKS app management
Did this article answer your question? If not, contact us.
