Contributors ebarcott
Trackers provide a method to visualize the state of Kubernetes objects that were created by directly applying manifests. This is accomplished by tracking Kubernetes labels and presenting that information in the NKS UI.
Note
Application Management is currently in Functional Preview mode. To enable this feature you will need to create a new cluster, and "Enable experimental features."
NKS app management
Understanding Trackers
By creating Trackers, you can get a customized view of related objects in a Kubernetes cluster. This view is based on Kubernetes labels, which are key-value pairs of metadata. These labels can be specified in YAML or JSON manifests to help cluster operators organize the workloads running in a cluster.
Trackers can be especially useful when you have an application that was deployed directly to the cluster from manifests. Perhaps using kubectl apply, or another tool outside of the NKS UI. This could also include Helm charts that were installed without using the Solutions - Packages feature of NKS.
Many applications are made up of multiple parts such as a frontend webserver, a backend database, and additional custom components. Applying labels and configuring a Tracker can provide a unified picture of the entire application stack.
Note
Trackers will only be able to see labels in the project’s namespace.
You can see available labels that can be used with a tracker by looking in the Kubernetes Dashboard for your cluster, and then choosing the namespace that matches your project.
You can also use kubectl to get information about labels. To see the labels on pods in the "exploration" namespace, run kubectl get pods --namespace exploration --show-labels. The output will contain a column of labels.
Using Trackers
This section will walk you through creating and using your first Tracker. Following along requires that you have already created a workspace with a cluster and a project.
Create a Tracker
Go to App Management and select a pinned workspace or View All Workspaces.
NKS app management
Select a workspace by clicking on its name.
Note
You may use also utilize the Search feature to find a specific workspace.)
NKS select workspace
You will be taken to the workspace overview page.
NKS workspace overview
Go to the Projects tab.
NKS workspace projects
Select a project by clicking its underlined name. This will take you to the overview page for that specific project.
NKS project overview
At the bottom of the page, press the blue + Add Solution button.
NKS add solution button
Press the + ADD A NEW TRACKER button.
This takes to you the Create Solution Tracker screen.
NKS create solution tracker screen
Give the Tracker a name in the Tracker Name field, and provide at least one key:value pair in place of Type labels to track.
NKS create solution tracker example
As instructed, you’ll need to press enter to add the key:value pair to the list of tracked labels. When you have finished adding labels to track, press the Create Tracker button.
Note
The new Tracker will NOT be active immediately.
It takes some time (~15 mintues) for the NKS system to register a new tracker.
NKS tracker not active
When the tracker is ready, the red icon will change to green.
Access a Tracker
Once you have created one or more Trackers, you can access them from inside their associated Project on the Solutions tab. The installed solutions can be filtered to just display Trackers by using the Tracker tab.
NKS project solutions filter trackers
Clicking the name of a Tracker will take you to the detail page.
NKS tracker detail
If the Tracker has associated deployments, you will see them at the bottom of the detail page and can interact with them by modifying replica counts, or utilizing the Actions menu.
NKS tracker deployments
Update a Tracker
  1. Navigate to the Tracker. Project→Solutions→Trackers
  2. Make changes to the Tracker name or labels.
Note
You can remove an existing label from the tracker by clicking the X next to it. 1. Save the changes by pressing the Update button.
NKS edit tracker
Delete a Tracker
At the moment, a tracker cannot be deleted from inside the NKS UI.
More Information
More information about Kubernetes labels can be found at this link.
