English
Create a Kubernetes Cluster on Amazon Web Services (AWS)
Contributors ebarcott
Learn how to create a Kubernetes cluster on AWS using NetApp Kubernetes Service (NKS).
To create an Amazon Web Services (AWS) cluster, you will need:
For more details, see our Requirements page.
Step 1: Choose a Provider
Log in to NetApp Kubernetes Service (NKS). Click CLUSTERS then click + ADD CLUSTER.
Create Kubernetes Cluster on AWS
Click the AWS tile to select AWS as a provider.
Choose:
  • Your cluster build version (Classic or Experimental)
  • SSH credentials
  • The Workspace (if applicable)
  • The AWS credentials. You can click Add Credentials to add a new set of credentials.
Then click NEXT to proceed.
Step 2: Configure Provider
We choose sensible defaults for basic Amazon Web Services Cluster builds to get you going quickly. On this step, you can modify these settings to meet your requirements:
  • Number, type, and size of master and worker nodes.
  • Region, Zone, Virtual Network, and Subnet.
  • GPU support. Click to add the power of NVIDIA Tesla GPUs to your cluster.
When the provider configurations are correct, click NEXT.
Step 3: Configure Cluster
On the third step, you can make any desired changes to your cluster configuration:
  • Edit or refresh the randomly-generated cluster name.
  • Change the orchestration version.
  • Change the Pod Network CIDR.
  • Change the Service Network CIDR.
When your cluster configurations are ready, click NEXT.
Step 4: Review and Confirm
Review and confirm all of the settings for your Kubernetes cluster. You can click "edit" in any section to make changes.
When you have verified that everything is correct, click CREATE. Your cluster will begin building, and will soon be ready for use.
Did this article answer your question? If not, contact us.
