English
Test Your Istio Cross-Cluster Mesh
Contributors ebarcott
Warning
This functionality has been deprecated.
Learn how to deploy a custom demo to visually test out your Istio cross-cluster mesh.
This tutorial will walk you through the process of setting up and demonstrating a two-cluster Istio cross-cluster mesh. The clusters can be created on the same service, or across different services (like AWS and GKE).
To demonstrate the mesh, we will install a customized version of Istio’s Bookinfo example application. The Bookinfo app creates a book review on a web page, which you can view at the provided URL.
The Bookinfo app comes in three versions. Each version has a different decoration on the book rating:
  • Version 1: No stars.
  • Version 2: Black stars.
  • Version 3: Red stars.
We will install version 1 on cluster A, and version 3 on cluster B. Thus, when you see a “no stars” review, you know you are looking at cluster A. If you see a “red stars” review, you are looking at cluster B.
Requirements
Prep Cluster A
In this section, you will set up cluster A to serve version 1 (no stars) of the Bookinfo application.
Push Bookinfo to Cluster A
Go to the NKS Control Plane and click on cluster A to go to the Cluster Details page. On the left-hand side of the screen, click to download the kubeconfig file for this cluster. Move the kubeconfig file to your Kubectl home directory.
Push the custom Bookinfo manifest to cluster A:
kubectl apply -f cluster-a-bookinfo-manifests.yaml
Customize Cluster A
In the next steps you will check the egress rule on cluster A to find the host info for cluster B. You then add the host info for cluster B to the destinationrule.yaml and splitter.yaml files, so that cluster A knows where to send traffic.
Get Cluster B Host Info
On cluster A, check the egress rule to find the host info for cluster B:
kubectl describe serviceentry spccc-egress-service-entry
Look for the section which reads:
    Spec:
      Endpoints:
        Address:  35.199.144.87
      Hosts:
        svc.netpgcxz4x.remote
Just to double-check, the IP address here should match the Istio IP of cluster B.
Get the Hosts name for cluster B (in this example, svc.netpgcxz4x.remote).
Create the DestinationRule
Paste the host info for cluster B into destinationrule.yaml under host so that it reads:
    spec:
      host: svc.netpgcxz4x.remote
Save the file. Push it to cluster A:
kubectl apply -f destinationrule.
Create the Splitter
Paste the host info for cluster B into the splitter.yaml file. The host info needs to be added in two places:
  http:
  - rewrite:
      authority: reviews.default.[Cluster B host info]
    route:
    - destination:
        host: [Cluster B host info]
In this example, you would change this to read:
http:
- rewrite:
    authority: reviews.default.svc.netpgcxz4x.remote
  route:
  - destination:
Save this file. Push it to cluster A:
kubectl apply -f splitter.yaml
Prep Cluster B
Now you will set up cluster B to serve version 3 (red stars) of the Bookinfo application.
Get the kubeconfig file for cluster B and update your kubectl environment. Then push the custom Bookinfo manifest to cluster B:
kubectl apply -f cluster-b-bookinfo-manifests.yaml
View the Demo
From the main NKS Control Plane, click to view the details of cluster A. Find the Istio Ingress URL, and append it with /productpage to view Bookinfo, like:
Repeatedly refresh the page. You will see the same review with either no stars or red stars. This demonstrates that traffic is being split between the two clusters.
