English
Add a Project
Contributors ebarcott
Learn how to add a project to your NetApp Kubernetes Service (NKS) account. Projects let you organize workloads and simplify deployment. Each Project is assigned to a single Workspace. Projects can have multiple cluster and any combination of Solutions (including Applications, Trackers, and Packages).
Requirements:
  • An NKS account. If you don’t have one already, you can sign up for a free 30-day trial with no credit card required at https://nks.netapp.io.
  • A cluster created in the desired Workspace.
To begin, click Projects then + Project.
Click to add a project
Step 1: Name Your Project
The Kubernetes name will be automatically created, according to Kubernetes naming conventions. Select the Workspace and Cluster you want to use, then click Next to continue.
Set project details
Step 2: Configure your Project
Customize Project Quotas, Pod Limits, and Container Limits to suit your needs. When you are ready to continue, click Next.
Configure your project
Step 3: Invite Members
By default, the project will use the same roles and permissions as the Workspace to which it is assigned. Click Next.
Step 4: Review and Confirm
Review and confirm all your settings. To change a setting, click the Edit button. When you are sure that everything is correct, click Create Project to create the Project.
