Run SAP Data HUB on NKS Edit on GitHub Request doc changes
Contributors ebarcott
1. Introduction
In general, the installation of SAP Data Hub Foundation inside an NKS Cluster follows these steps:
  • Deploy an NKS Cluster
  • Install and configure NetApp Trident as storage orchestration solution
  • Validate the prerequisites for installing SAP Data Hub
  • Install SAP Data Hub inside the NKS cluster
2. NKS Cluster validation matrix
The following version combinations of SAP Data Hub 2.X and NetApp Kubernetes Services have been validated:
SAP Data Hub NKS/k8s Version Storage Solution Storage Protocol
2.7
1.14
Trident 19.07.1 or higher
iSCSI
2.7
1.15
iSCSI
3. Requirements
The general sizing of the NKS environment for deploying SAP Data Hub 2.7 or newer must be done according to the SAP Data Hub sizing guide: SAP Data Hub Sizing Guide
The minimum sizing requirements for running non-productive SAP Data Hub installations require at least:
  • 1 master node, which must not run SAP Data Hub pods
  • 3 worker nodes. Each worker node must be configured with 8vCPUs and 32GByte RAM.
The minimum sizing requirements for running productive SAP Data Hub installations require at least:
  • 4 worker nodes. Each worker node must be configured with 16vCPUs and 64GByte RAM.
More details regarding the minimum sizing can be found at the SAP documentation Minimum Sizing for SAP Data Hub
3.1. Master Node
The following are the requirements for the NKS worker nodes
  • NKS/k8s version: 1.14, 1.15
  • CPU: 4vCPUs
  • Memory: 16GByte
  • Diskspace: 100 GByte for /
3.2. Worker Nodes
  • NKS version: 1.14, 1.15
  • CPU: 8vCPUs or 16 vCPUs depending on the SAP Data Hub use case, non-production or production
  • Memory: 32GByte or 64Gbyte depending on the SAP Data Hub use case, non-production or production
3.3. NetApp Trident
The installation of SAP Data Hub on NKS has been tested with Trident version 19.07.1. So, a version of NetApp Trident equal or greater than version 19.07.1 must be used. More details regarding NetApp Trident and the supported NetApp backend storage systems can be found at the official NetApp Trident product documentation.
According to SAP note 2712050 Backend type ontap-nas is not supported, so only backend type ontap-san using iSCSI LUNs are supported in conjunction with NetApp Trident as storage orchestration solution.
SAP Data Hub backend storage requirements: 500Gbyte. The storage can be thin-provisioned
3.4. NetApp StorageGRID
When activating the SAP Data Hub checkpoint store, an object store is required. For on-prem scenarios, NetApp StorageGRID can be used as S3 storage.
NetApp StorageGRID is available as appliance or can also be deployed in a Kubernetes Cluster. Details regarding the deployment in a Kubernetes Cluster can be found at:
For accessing the S3 bucket configured in StorageGRID out of SAP Data Hub, a certificate must be used which has been issued from an official Trust Center.
3.5. Additional SAP Data Hub requirements
The following additional requirements must be fulfilled:
  • Docker Registry: The local Docker registry is needed for storing the SAP Data Hub container images locally. In our environment, we configured the Docker registry using SSL without user authentication, meaning the Docker registry can be accessed without entering a user and a password. For SSL access signed certificates which have been issued from Let’s Encrypt and automatically requested from Cert Manager have been used. The local Docker registry must meet the following requirements: Diskspace: 50GByte
  • An appropriate helm version must be installed i.e. 2.12.1
  • Access to SAP Service Marketplace for downloading the docker images
3.6. Optional components
In addition to the official required components the following solutions have been installed inside the NetApp NKS cluster which simplified the overall installation:
4. Install the NKS Cluster
The following NKS deployment option are currently available:
On https://nks.netapp.io this is reflected during the deployment with the following deployment options:
Deployment options
This chapter describes the installation of two flavors of an NKS cluster.
In addition, the following necessary configuration steps are explained in the following chapters:
4.1. Deploy NKS on HCI
To start an NKS deployment onto an On-Prem HCI system, the HCI system must be configured and register at NetApp Cloud Central. In the following menu you configure the NKS nodes that are going to be installed on the HCI system by pressing EDIT
Configure NKS nodes
By pressing Basic HCI options the configuration of the master and worker nodes can be changed.
Node configuration
Then the node size, number of vCPUs, main memory and hard disk size, as well as the number of master and worker nodes must be configured. The Size of the workers must match the SAP Data Hub sizing, i.e. 8vCPUS, 32GByte RAM and 100GByte for / file system for non-production environments.
Sizing options
Then increase the number of worker nodes as necessary and increase the disk size of the / Filesystem.
File system
After pressing Save the changed configuration is being updated on the overview page.
Save configuration
In the following menu the name of the Kubernetes cluster can be specified (in this example we have adopted the proposed name) as well as the version of Kubernetes that is going to be installed. In the HCI example it is version 1.14.3.
Cluster configs
The deployment will be started by pressing SUBMIT.
4.2. Deploy NKS in Azure
To start an NKS deployment inside an Azure environment, the credentials for the Azure environment must configured according to the documentation Azure Credentials and Permissions
In the following menu you configure the NKS nodes that are going to be installed inside Azure system by pressing EDIT
NKS node configuration
By pressing D-Series an Azure predefined virtual machine type can be selected. This machine Type must match the sizing (i.e. 8vCPUs and 32GByte RAM for no-production environments) for the SAP Data Hub scenario.
Machine configs
D8s v3 has been chosen as the machine type (which determine the number of vCPUs and the size of the main memory).
Machine configs
Then the Azure location, the resource group, the virtual networks, the hard disk size, the number of master and worker nodes and the size of the / filesystem must be configured.
Azure configs
Updated configuration
In the following menu the name of the Kubernetes cluster can be specified (in this example we have chosen DataHub_Azure) as well as the version of Kubernetes that is going to be installed. In the Azure example it is version 1.15.5.
Cluster configs
4.3. Prepare NetApp Trident and the backend storage systems
Install and configure NetApp Trident according to the NetApp Trident documentation. Create a storage class with backend type san, so that iSCSI LUNs can be created. Either ext4 or xfs must be used as filesystem. In the example in “Appendix B: storage-class-basic_iscsi_ext4.yaml” an ONTAP SAN system has been configured as backend system and the default format for LUNs has been set to ext4. Create the storage class with kubectl create -f storage-calss-basic_iscsi_ext4.yaml. If the default format for new iSCSI LUNS should be set to xfs, the line following line in the storage-calss-basic_iscsi_ext4.yaml file
fsType: "ext4"
must be changed to:
fsType: "xfs"
Make sure that the backend systems are properly set up for the iSCSI protocol and that all initiator names from the NKS nodes have been added to the corresponding igroup on the backend system. For an ONTAP based system follow these steps:
  • Log on to each NKS node and perform the following steps
    • Edit /etc/iscsi/iscsid.conf and set “node.startup = automatic”
    • Get the initiator names and make sure, that all initiator names are unique:
      cat /etc/iscsi/initiatorname.iscsi
      The last line should look like this:
      InitiatorName=iqn.1996-04.de.suse:01:86ce8bfdded
      The name you must use is iqn.1996-04.de.suse:01:86ce8bfdded If the initiator names are not unique, create a new one using the command /sbin/iscsi-iname and enter the new initiator name in /etc/iscsi/initiatorname.iscsi. If there is no initiator name in /etc/iscsi/initiatorname.iscsi execute iscsiadm -m discovery -t st -p <IP of ONTAP iSCSi LIF> and recheck the content of /etc/iscsi/initiatorname.iscsi. Now there should be an initiator name in the file.
    • Restart iSCSI service systemctl restart iscsi
  • Make sure that iSCSI for the used SVM is activated according to the documentation Configuring iSCSI on an existing SVM
  • Log on via SSH to your ONTAP operating system and execute the following steps
    • Create trident igroup
      igroup create -vserver <vserver> -igroup trident -protocol iscsi -ostype linux -initiator <initiator from NKS master node>
    • Add initiator names from all NKS worker nodes
      igroup add trident <initiator from NKS workers>
  • Go back to your NKS worker nodes and verify that the iSCSI discovery works using the following command:
4.4. Prepare NetApp StorageGRID
If SAP Data Hub checkpoint store should be used, an object store is necessary. In this case NetApp StorageGRID will be used.
To use NetApp StorageGRID as object store for SAP Data Hub, the following installation steps (if StorageGRID is not be used an appliance) and configuration steps are necessary:
4.5. Install helm
Install helm by executing the following steps:
  • Extract the downloaded helm file (in this example helm version 2.12.1) and move the following files to /usr/local/bin:
    • helm
    • tiller
  • Create a helm service account
    • Create the file helm.yaml with the content described in Appendix A: helm.yaml
    • kubectl apply -f helm.yaml
  • Initialize helm and install tiller
    • helm init --service-account helm
5. Install SAP Data Hub
This chapter describes the installation of SAP Data Hub using the following options:
The installation of SAP Data Hub does not differ whether an On-Prem NKS version is used or NKS deployment in a public cloud environment.
The following installation steps are therefore identical for all NKS deployments.
  • Download SAP Data Hub 2.7 Foundation installation ZIP file: DHFOUNDATION07_<Patch Level>.ZIP
  • Extract the ZIP File
5.1. Install SAP Data Hub using install.sh
Log on to the NKS master node. Set the following two environment variables:
  • export NAMESPACE=nkslocal
    This defines the namespace for the SAP Data Hub installation in the NKS cluster
  • export DOCKER_REGISTRY=registry.nkslocal.com:32120
    This defines the Docker registry which is going to be used for storing the SAP Data Hub images locally
Start the installation:
  • Change the directory to your SAP Data Hub installation source and execute the following command:
    ./install.sh --pv-storage-class ontap-iscsi --vsystem-disable-load-nfs-modules
    This command starts the SAP Data Hub installation setting the default storage class to ontap-iscsi
    If different storage classes should or must be specified, run install.sh with the following arguments:
    ./install.sh --vsystem-storage-class ontap-iscsi --pv-storage-class ontap-iscsi --dlog-storage-class ontap-iscsi --disk-storage-class ontap-iscsi --consul-storage-class ontap-iscsi --hana-storage-class ontap-iscsi --diagnostic-storage-class ontap-iscsi --pv-storage-class ontap-iscsi --vsystem-disable-load-nfs-modules
    This command starts the SAP Data Hub installation setting the storage classes of each component to ontap-iscsi as well as the default storage class.
    More details regarding possible command line parameters can be found in the SAP Data Hub 2.7 installation documentation
  • Specify the following parameters:
    • S-User and Password
    • Hostname for certificates: i.e. datahub.nkslocal.com
    • Password: Abcpoiuz01!
    • Tenant Name: default
    • Vora admin user: voraadm
    • Vora checkpoint store: Depending on your setup either Yes or No. If the vora checkpoint store is being used and StorageGRID is used as object store, the following parameters must be specified in addition
      • Type of checkpoint store: s3
      • Access Key: O7UQ5IF1P156S8ZZ3Q3B
      • Secret: 9oH+cX8O5IM8LyjKlhMdQZ/pSfiZMxzguap3P3UX
      • S3 host: https://s3.nkslocal.com:32182/
      • Region: us-east-1
      • S3 bucket: datahub/
  • Once the installation has been finished, expose the following services i.e. as NodePort:
    • vsystem
      kubectl expose service -n nkslocal vsystem --type=NodePort --name=my-vsystem-nodeport
    • vora-tx-coordinator-ext
      kubectl expose service -n nkslocal vora-tx-coordinator-ext --type=NodePort --name=my-vora-tx-coordinator-ext
    • vora-textanalysis
      kubectl expose service -n nkslocal vora-textanalysis --type=NodePort --name=my-vora-textanalysis`
5.2. Install SAP Data Hub using SL PlugIn
Log on to the NKS master node. Start the installation:
  • Change the directory to your SAP Data Hub installation source.
  • Change into the subdirectory slplugin/workdir and execute the command `./setup.sh
  • Next action: n (for next)
  • Set the Kubernetes namespace: nkslocal
  • Accept the license agreement: y
  • Select Advanced installation: 2
  • Select not to use saved container images: 1
  • S-User name
  • S-User password
  • Choose existing technical user: 1
  • Container registry: registry.nkslocal.com:32120
  • Do not use an image pull secret: 1
    The Docker registry has been configured in our scenario without the need for a user and a password
  • Certificate domain: datahub.nkslocal.com
  • Tenant name: default
  • Username: voraadm
  • Use the same password: 1
  • Do not configure proxy settings: 2
  • Enable checkpoint store: Yes or No. If the vora checkpoint store is being used and StorageGRID is used as object store, the following parameters must be specified in addition
    • Region: us-east-1
  • Configure storage classes: 2
  • Default storage class: ontap-iscsi
  • Confirm ontap-iscsi for all of the following storage classes
    • System Management
    • Dlog
    • Disk
    • Consul
    • SAP HANA
    • SAP Data Hub Diagnostics
  • Do not configure Docker container log path: 1
  • Use default registry for SAP Data Hub Modeler: 2
  • Disable loading NFS modules: 2
  • Disable network policies: 2
  • Helm Timeout: 1800
  • Pod Wait Timeout: 500
  • No Additional Installation Parameters
  • Start the deployment: n (for next)
    • vsystem
    • vora-textanalysis
6. Troubleshooting
After uninstalling and purging an existing SAP Data Hub installation, make sure, all persistent volumes have been deleted.
kubectl get pv | grep <SAP Data Hub namespace>`
If the vsystem-application-runtime-storage persistent volume has not been deleted, remove it with the following command:
kubectl delete pv nkslocal-vsystem-application-runtime-storage
apiVersion: v1
kind: ServiceAccount
metadata:
  namespace: kube-system
apiVersion: rbac.authorization.k8s.io/v1beta1
kind: ClusterRoleBinding
metadata:
roleRef:
  apiGroup: rbac.authorization.k8s.io
  kind: ClusterRole
subjects:
  - kind: ServiceAccount
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: netapp.io/trident
parameters:
  backendType: ontap-san
  fsType: "ext4"
