Add an Application from Bitbucket Edit on GitHub Request doc changes
Contributors ebarcott
Learn how to deploy an application on your NetApp Kubernetes Services (NKS) Solution from a Bitbucket repository.
Requirements
  • An NKS account. If you don’t have one already, you can sign up for a free 30-day trial with no credit card required at https://nks.netapp.io.
  • A Project set up and configured on your NKS account.
  • An NKS cluster with Build Version: Classic.
  • An application in a Bitbucket repository.
  • An SSH key pair for use as the deploy key. IMPORTANT: Create this key pair without a passphrase.
For instructions on how to create an SSH key pair, follow the instructions in this article.
If you have problems getting your application up and running, you may need to customize your Procfile. Learn more about using a Procfile.
Add the Application
The first step is to add the application to your NKS account.
Select Application Type
Click Projects then select the Project you want to use.
Select your Project
Click + Add Solution. Click Application as the Solution type.
Click Application Solution type
Select the Workspace, Cluster, and Project you want to use, then click Next.
Define Version Control
In this step you will set two items:
  • NKS: The Remote URL
  • Bitbucket: The Private Deploy Key
Remote URL
To get this URL, visit your project’s Bitbucket repository page and click the Clone link in the upper right-hand corner.
Note
You must clone with SSH. If the pop-up says HTTPS, click the drop-down menu in the upper right-hand corner of the pop-up to switch to SSH.
Clone with SSH
Click to copy the SSH URL. Paste this in to NKS as the Remote URL.
Add the Remote URL
Private Deploy Key
For this step you will need an SSH key pair. IMPORTANT: Create this key pair without a passphrase.
For more information on how to create an SSH key pair, see this article.
Use caution when copying the SSH key. For instructions on how to copy the SSH key, see this article.
  • Mac: Use pbcopy.
  • Linux: Use xclip.
  • Windows: Use Notepad. If you have Git BASH, use the clip command.
Paste the private key into the Private Deploy Key field on NKS. You will add the public key to BitBucket in the next section.
Add your private key
Click Next to continue.
Configure Application
Set the application’s name, update strategy, and scaling. Click Next to continue.
Review and Confirm
Review and confirm all your settings. To change a setting, click the Edit button.
When you are sure that everything is correct, click Create to create the Solution. This creates your Solution and redirects you to the Application’s page.
Deploy and Update Code
Next, you will add configurations to your Bitbucket repository. To do this, you will give Bitbucket:
  • The Deploy Key. This is the public key you created.
  • The Payload URL (webhook) from NKS.
Add the Deploy Key
Go to the Bitbucket page for your repository and click Settings.
bitbucket Settings
Click Access Keys then click Add key. Add the public SSH key you created.
Add the Webhook
From the Bitbucket Settings page, click Webhooks then click Add webhook.
Return to the NKS application page, where you will find the Payload URL.
Deploy the code
Paste this in to the URL field on Bitbucket. Set the events you want to trigger the webhook, then click Add webhook to add it.
Trigger the Webhook if Necessary
When you add your webhook, Bitbucket gives you a list of choices for events which trigger the webhook. By default, a repository push is the webhook trigger. If this is the case for your webhook, you will need to do a git push to trigger the webhook.
Check Your Application
At this point everything is configured, although it make take a few minutes for the deployment to complete. You can monitor the process on the Solution’s Metrics tab.
When the deployment is ready, you can view your application by visiting the ingress URL which NKS automatically created for your application.
Get your ingress URL
