Part 2 - Leveraging AWS Amazon FSx for NetApp ONTAP (FSx ONTAP) as a Data Source for Model Training in SageMaker
Contributors netapp-jsnyder kevin-hoke
This article is a tutorial on using Amazon FSx for NetApp ONTAP (FSx ONTAP) for training PyTorch models in SageMaker, specifically for a tire quality classification project.
Introduction
This tutorial offers a practical example of a computer vision classification project, providing hands-on experience in building ML models that utilize FSx ONTAP as the data source within the SageMaker environment. The project focuses on using PyTorch, a deep learning framework, to classify tire quality based on tire images. It emphasizes the development of machine learning models using FSx ONTAP as the data source in Amazon SageMaker.
What is FSx ONTAP
Amazon FSx ONTAP is indeed a fully managed storage solution offered by AWS. It leverages NetApp's ONTAP file system to provide reliable and high-performance storage. With support for protocols like NFS, SMB, and iSCSI, it allows seamless access from different compute instances and containers. The service is designed to deliver exceptional performance, ensuring fast and efficient data operations. It also offers high availability and durability, ensuring that your data remains accessible and protected. Additionally, the storage capacity of Amazon FSx ONTAP is scalable, allowing you to easily adjust it according to your needs.
Prerequisite
Network Environment
Network environment
FSx ONTAP (Amazon FSx ONTAP) is an AWS storage service. It includes a file system running on the NetApp ONTAP system and an AWS-managed system virtual machine (SVM) that connects to it. In the provided diagram, the NetApp ONTAP server managed by AWS is located outside the VPC. The SVM serves as the intermediary between SageMaker and the NetApp ONTAP system, receiving operation requests from SageMaker and forwarding them to the underlying storage. To access FSx ONTAP, SageMaker must be placed within the same VPC as the FSx ONTAP deployment. This configuration ensures communication and data access between SageMaker and FSx ONTAP.
Data Access
In real-world scenarios, data scientists typically utilize the existing data stored in FSx ONTAP to build their machine learning models. However, for demonstration purposes, since the FSx ONTAP file system is initially empty after creation, it is necessary to manually upload the training data. This can be achieved by mounting FSx ONTAP as a volume to SageMaker. Once the file system is successfully mounted, you can upload your dataset to the mounted location, making it accessible for training your models within the SageMaker environment. This approach allows you to leverage the storage capacity and capabilities of FSx ONTAP while working with SageMaker for model development and training.
The data reading process involves configuring FSx ONTAP as a private S3 bucket. To learn the detailed configuration instructions, please refer to Part 1 - Integrating Amazon FSx for NetApp ONTAP (FSx ONTAP) as a private S3 bucket into AWS SageMaker
Integration Overview
Training workflow
The workflow of using training data in FSx ONTAP to build a deep learning model in SageMaker can be summarized into three main steps: data loader definition, model training, and deployment. At a high level, these steps form the foundation of an MLOps pipeline. However, each step involves several detailed sub-steps for a comprehensive implementation. These sub-steps encompass various tasks such as data preprocessing, dataset splitting, model configuration, hyperparameter tuning, model evaluation, and model deployment. These steps ensure a thorough and effective process for building and deploying deep learning models using training data from FSx ONTAP within the SageMaker environment.
Step-by-Step Integration
Data Loader
In order to train a PyTorch deep learning network with data, a data loader is created to facilitate the feeding of data. The data loader not only defines the batch size but also determines the procedure for reading and preprocessing each record within the batch. By configuring the data loader, we can handle the processing of data in batches, enabling training of the deep learning network.
The data loader consists of 3 parts.
Preprocessing Function
from torchvision import transforms
preprocess = transforms.Compose([
    transforms.ToTensor(),
    transforms.Resize((224,224)),
    transforms.Normalize(
        mean=[0.485, 0.456, 0.406],
        std=[0.229, 0.224, 0.225]
The above code snippet demonstrates the definition of image preprocessing transformations using the torchvision.transforms module. In this turtorial, the preprocess object is created to apply a series of transformations. Firstly, the ToTensor() transformation converts the image into a tensor representation. Subsequently, the Resize224,224 transformation resizes the image to a fixed size of 224x224 pixels. Finally, the Normalize() transformation normalizes the tensor values by subtracting the mean and dividing by the standard deviation along each channel. The mean and standard deviation values used for normalization are commonly employed in pre-trained neural network models. Overall, this code prepares the image data for further processing or input into a pre-trained model by converting it to a tensor, resizing it, and normalizing the pixel values.
The PyTorch Dataset Class
import torch
from io import BytesIO
from PIL import Image
class FSxNImageDataset(torch.utils.data.Dataset):
    def __init__(self, bucket, prefix='', preprocess=None):
        self.image_keys = [
            s3_obj.key
            for s3_obj in list(bucket.objects.filter(Prefix=prefix).all())
        self.preprocess = preprocess
    def __len__(self):
        return len(self.image_keys)
    def __getitem__(self, index):
        key = self.image_keys[index]
        response = bucket.Object(key)
        label = 1 if key[13:].startswith('defective') else 0
        image_bytes = response.get()['Body'].read()
        image = Image.open(BytesIO(image_bytes))
        if image.mode == 'L':
            image = image.convert('RGB')
        if self.preprocess is not None:
            image = self.preprocess(image)
        return image, label
This class provides functionality to obtain the total number of records in the dataset and defines the method for reading data for each record. Within the getitem function, the code utilizes the boto3 S3 bucket object to retrieve the binary data from FSx ONTAP. The code style for accessing data from FSx ONTAP is similar to reading data from Amazon S3. The subsequent explanation delves into the creation process of the private S3 object bucket.
FSx ONTAP as a private S3 repository
seed = 77                                                   # Random seed
bucket_name = '<Your ONTAP bucket name>'                    # The bucket name in ONTAP
aws_access_key_id = '<Your ONTAP bucket key id>'            # Please get this credential from ONTAP
aws_secret_access_key = '<Your ONTAP bucket access key>'    # Please get this credential from ONTAP
fsx_endpoint_ip = '<Your FSx ONTAP IP address>'                  # Please get this IP address from FSXN
import boto3
# Get session info
region_name = boto3.session.Session().region_name
# Initialize Fsxn S3 bucket object
# --- Start integrating SageMaker with FSXN ---
# This is the only code change we need to incorporate SageMaker with FSXN
s3_client: boto3.client = boto3.resource(
    's3',
    region_name=region_name,
    aws_access_key_id=aws_access_key_id,
    aws_secret_access_key=aws_secret_access_key,
    use_ssl=False,
    endpoint_url=f'http://{fsx_endpoint_ip}',
    config=boto3.session.Config(
        signature_version='s3v4',
        s3={'addressing_style': 'path'}
# s3_client = boto3.resource('s3')
bucket = s3_client.Bucket(bucket_name)
# --- End integrating SageMaker with FSXN ---
To read data from FSx ONTAP in SageMaker, a handler is created that points to the FSx ONTAP storage using the S3 protocol. This allows FSx ONTAP to be treated as a private S3 bucket. The handler configuration includes specifying the IP address of the FSx ONTAP SVM, the bucket name, and the necessary credentials. For a comprehensive explanation on obtaining these configuration items, please refer to the document at Part 1 - Integrating Amazon FSx for NetApp ONTAP (FSx ONTAP) as a private S3 bucket into AWS SageMaker.
In the example mentioned above, the bucket object is used to instantiate the PyTorch dataset object. The dataset object will be further explained in the subsequent section.
The PyTorch Data Loader
from torch.utils.data import DataLoader
torch.manual_seed(seed)
# 1. Hyperparameters
batch_size = 64
# 2. Preparing for the dataset
dataset = FSxNImageDataset(bucket, 'dataset/tyre', preprocess=preprocess)
train, test = torch.utils.data.random_split(dataset, [1500, 356])
data_loader = DataLoader(dataset, batch_size=batch_size, shuffle=True)
In the example provided, a batch size of 64 is specified, indicating that each batch will contain 64 records. By combining the PyTorch Dataset class, the preprocessing function, and the training batch size, we obtain the data loader for training. This data loader facilitates the process of iterating through the dataset in batches during the training phase.
Model Training
from torch import nn
class TyreQualityClassifier(nn.Module):
    def __init__(self):
        super().__init__()
        self.model = nn.Sequential(
            nn.Conv2d(3,32,(3,3)),
            nn.ReLU(),
            nn.Conv2d(32,32,(3,3)),
            nn.ReLU(),
            nn.Conv2d(32,64,(3,3)),
            nn.ReLU(),
            nn.Flatten(),
            nn.Linear(64*(224-6)*(224-6),2)
    def forward(self, x):
        return self.model(x)
import datetime
num_epochs = 2
device = torch.device('cuda' if torch.cuda.is_available() else 'cpu')
model = TyreQualityClassifier()
fn_loss = torch.nn.CrossEntropyLoss()
optimizer = torch.optim.Adam(model.parameters(), lr=1e-3)
model.to(device)
for epoch in range(num_epochs):
    for idx, (X, y) in enumerate(data_loader):
        X = X.to(device)
        y = y.to(device)
        y_hat = model(X)
        loss = fn_loss(y_hat, y)
        optimizer.zero_grad()
        loss.backward()
        optimizer.step()
        current_time = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
        print(f"Current Time: {current_time} - Epoch [{epoch+1}/{num_epochs}]- Batch [{idx + 1}] - Loss: {loss}", end='\r')
This code implements a standard PyTorch training process. It defines a neural network model called TyreQualityClassifier using convolutional layers and a linear layer to classify tire quality. The training loop iterates over data batches, computes the loss, and updates the model's parameters using backpropagation and optimization. Additionally, it prints the current time, epoch, batch, and loss for monitoring purposes.
Model Deployment
Deployment
import io
import os
import tarfile
import sagemaker
# 1. Save the PyTorch model to memory
buffer_model = io.BytesIO()
traced_model = torch.jit.script(model)
torch.jit.save(traced_model, buffer_model)
# 2. Upload to AWS S3
sagemaker_session = sagemaker.Session()
bucket_name_default = sagemaker_session.default_bucket()
model_name = f'tyre_quality_classifier.pth'
# 2.1. Zip PyTorch model into tar.gz file
buffer_zip = io.BytesIO()
with tarfile.open(fileobj=buffer_zip, mode="w:gz") as tar:
    # Add PyTorch pt file
    file_name = os.path.basename(model_name)
    file_name_with_extension = os.path.split(file_name)[-1]
    tarinfo = tarfile.TarInfo(file_name_with_extension)
    tarinfo.size = len(buffer_model.getbuffer())
    buffer_model.seek(0)
    tar.addfile(tarinfo, buffer_model)
# 2.2. Upload the tar.gz file to S3 bucket
buffer_zip.seek(0)
boto3.resource('s3') \
    .Bucket(bucket_name_default) \
    .Object(f'pytorch/{model_name}.tar.gz') \
    .put(Body=buffer_zip.getvalue())
The code saves the PyTorch model to Amazon S3 because SageMaker requires the model to be stored in S3 for deployment. By uploading the model to Amazon S3, it becomes accessible to SageMaker, allowing for the deployment and inference on the deployed model.
import time
from sagemaker.pytorch import PyTorchModel
from sagemaker.predictor import Predictor
from sagemaker.serializers import IdentitySerializer
from sagemaker.deserializers import JSONDeserializer
class TyreQualitySerializer(IdentitySerializer):
    CONTENT_TYPE = 'application/x-torch'
    def serialize(self, data):
        transformed_image = preprocess(data)
        tensor_image = torch.Tensor(transformed_image)
        serialized_data = io.BytesIO()
        torch.save(tensor_image, serialized_data)
        serialized_data.seek(0)
        serialized_data = serialized_data.read()
        return serialized_data
class TyreQualityPredictor(Predictor):
    def __init__(self, endpoint_name, sagemaker_session):
        super().__init__(
            endpoint_name,
            sagemaker_session=sagemaker_session,
            serializer=TyreQualitySerializer(),
            deserializer=JSONDeserializer(),
sagemaker_model = PyTorchModel(
    model_data=f's3://{bucket_name_default}/pytorch/{model_name}.tar.gz',
    role=sagemaker.get_execution_role(),
    framework_version='2.0.1',
    py_version='py310',
    predictor_cls=TyreQualityPredictor,
    entry_point='inference.py',
    source_dir='code',
timestamp = int(time.time())
pytorch_endpoint_name = '{}-{}-{}'.format('tyre-quality-classifier', 'pt', timestamp)
sagemaker_predictor = sagemaker_model.deploy(
    initial_instance_count=1,
    instance_type='ml.p3.2xlarge',
    endpoint_name=pytorch_endpoint_name
This code facilitates the deployment of a PyTorch model on SageMaker. It defines a custom serializer, TyreQualitySerializer, which preprocesses and serializes input data as a PyTorch tensor. The TyreQualityPredictor class is a custom predictor that utilizes the defined serializer and a JSONDeserializer. The code also creates a PyTorchModel object to specify the model's S3 location, IAM role, framework version, and entry point for inference. The code generates a timestamp and constructs an endpoint name based on the model and timestamp. Finally, the model is deployed using the deploy method, specifying the instance count, instance type, and generated endpoint name. This enables the PyTorch model to be deployed and accessible for inference on SageMaker.
Inference
image_object = list(bucket.objects.filter('dataset/tyre'))[0].get()
image_bytes = image_object['Body'].read()
with Image.open(with Image.open(BytesIO(image_bytes)) as image:
    predicted_classes = sagemaker_predictor.predict(image)
    print(predicted_classes)
This is the example of using the deployed endpoint to do the inference.
