NetApp AIPod Mini for ERAG - Deployment Steps
Contributors Arpitamahajan01 netapp-jsnyder
This paper provides a comprehensive, step-by-step guide for deploying NetApp AIPod Mini for Enterprise RAG(ERAG) 2.0. It covers end-to-end installation and configuration of all core components, including the Kubernetes platform, NetApp Trident for storage orchestration, and the ERAG 2.0 stack using ansible playbooks. In addition to the deployment workflow, the document includes a dedicated troubleshooting guide that captures common issues encountered during installation, their root causes, and recommended resolutions to support a smooth and reliable deployment experience.
Intel Logo
Sathish Thyagarajan, Michael Oglesby, Arpita Mahajan NetApp
Assumptions:
  • The deployment user has sufficient permissions to create namespace and install Helm charts.
  • The Xeon servers run Ubuntu 22.04.
  • The same username is configured across all Xeon servers.
  • DNS Administrative access is available.
  • ONTAP 9.16 deployed with a SVM configured for S3 access.
  • S3 bucket is created and configured.
Prerequisites
Install Git, Python3.11, and pip for Python3.11
On Ubuntu 22.04:
add-apt-repository ppa:deadsnakes/ppa
apt update
apt upgrade
apt install python3.11
python3.11 --version
apt install python3.11-pip
python3.11 -m pip --version
ERAG 2.0/2.0.1 Deployment Steps
1. Pull Enterprise RAG 2.0 release from GitHub
git clone https://github.com/opea-project/Enterprise-RAG.git
cd Enterprise-RAG/
git checkout tags/release-2.0.0
For ERAG 2.0.1, Use the below command
git checkout tags/release-2.0.1
2. Install prerequisites
cd deployment/
sudo apt-get install python3.11-venv
python3 -m venv erag-venv
source erag-venv/bin/activate
pip install --upgrade pip
pip install -r requirements.txt
ansible-galaxy collection install -r requirements.yaml --upgrade
3. Create inventory file
cp -a inventory/sample inventory/<cluster-name>
vi inventory/<cluster-name>/inventory.ini
# Control plane nodes
kube-3 ansible_host=<control_node_ip_address>
# Worker nodes
kube-1 ansible_host=<worker_node1_ip_address>
kube-2 ansible_host=<worker_node2_ip_address>
# Define node groups
[kube_control_plane]
kube-1
kube-2
kube-3
[kube_node]
kube-1
kube-2
[etcd:children]
kube_control_plane
[k8s_cluster:children]
kube_control_plane
kube_node
# Vars
[k8s_cluster:vars]
ansible_become=true
ansible_user=<ssh_username>
ansible_connection=ssh
4. Set up passwordless SSH to each node
ssh-copy-id REMOTE_USER@MACHINE_IP
Note: If a deploy node is used to deploy the ERAG, ensure that passwordless SSH is also configured on the deploy node.
5. Verify connectivity
ansible all -i inventory/<cluster-name>/inventory.ini -m ping
Note: If you do not have passwordless sudo set up on your nodes, then you will need to add --ask-become-pass to this command. When using --ask-become-pass, it is critical that the ssh user have the SAME password on each node.
6. Edit config.yaml file
Prepare the deployment by editing inventory/<cluster-name>/config.yaml to reflect your environment specifics.
vi inventory/<cluster-name>/config.yaml
Sample Snippet:
deploy_k8s: true
install_csi: "netapp-trident"
local_registry: false
trident_operator_version: "2510.0"    # Trident operator version (becomes 100.2506.0 in Helm chart)
trident_namespace: "trident"          # Kubernetes namespace for Trident
trident_storage_class: "netapp-trident" # StorageClass name for Trident
trident_backend_name: "ontap-nas"     # Backend configuration name
ontap_management_lif: "<ontap_mgmt_lif>"              # ONTAP management LIF IP address
ontap_data_lif: "<ontap_nfs_data_lif>"                    # ONTAP data LIF IP address
ontap_svm: "<ontap_svm>"                         # Storage Virtual Machine (SVM) name
ontap_username: "<ontap_username>"                    # ONTAP username with admin privileges
ontap_password: "<redacted>"                    # ONTAP password
ontap_aggregate: "<ontap_aggr>"                   # ONTAP aggregate name for volume creation
kubeconfig: "<repository path>/deployment/inventory/<cluster-name>/artifacts/admin.conf"
7. Deploy the K8s cluster (with Trident)
Execute ansible-playbook playbooks/infrastructure.yaml with the configure and install tags to deploy the cluster and Trident CSI.
ansible-playbook playbooks/infrastructure.yaml --tags configure,install -i inventory/<cluster-name>/inventory.ini -e @inventory/<cluster-name>/config.yaml
Note:
- If you do not have passwordless sudo set up on your nodes, then you will need to add --ask-become-pass to this command. When using --ask-become-pass, it is critical that the ssh user have the SAME password on each node.
- Refer to the NetApp Trident CSI Integration for Enterprise RAG for details.
Refer to the Trident installation documentation for further details.
8. Change the number of iwatch open descriptors
Refer to the iwatch open descriptors for details.
9. Install kubectl
Refer to the Install Kubectl if it is not already installed.
Retrieve the kubeconfig file from <repository path>/deployment/inventory/<cluster-name>/artifacts/admin.conf.
10. Install MetalLB in Kubernetes cluster
Install MetalLB using helm on your Kubernetes cluster.
helm repo add metallb https://metallb.github.io/metallb
helm -n metallb-system install metallb metallb/metallb --create-namespace
Refer to the MetalLB Installation for details.
11. Configure MetalLB
MetalLB was configured in Layer 2 mode, and the required IPAddressPool and L2Advertisement resources were created in accordance with the documented configuration guidelines.
vi metallb-ipaddrpool-l2adv.yaml
kubectl apply -f metallb-ipaddrpool-l2adv.yaml
Sample Snippet:
apiVersion: metallb.io/v1beta1
kind: IPAddressPool
metadata:
  namespace: metallb-system
spec:
  addresses:
  - <IPAddressPool>
kind: L2Advertisement
metadata:
Note:
- Use metallb-system as namespace for MetalLB IPAddressPool and L2Advertisement.
- The IP address pool may include any unused IPs within the same subnet as the Kubernetes nodes. Only a single IP address is required for ERAG.
- Refer to the MetalLB Layer2 configuration for details.
12. Update config.yaml with FQDN, volume access mode, ingress, and S3 details.
Modify the config.yaml file located at inventory/<cluster-name>/config.yaml to define the deployment FQDN, set the volume access modes, configure ingress exposure, and integrate ONTAP S3.
Edit config.yaml and apply the following configuration changes:
  • FQDN: Specify the fully qualified domain name used to access the deployment.
  • Volume access mode: Under the gmc.pvc section, set accessMode: ReadWriteMany to support concurrent access to model volumes across multiple pods.
  • Ingress configuration: Configure the ingress service_type as LoadBalancer to enable external access to the application.
  • S3 storage details: Set storageType to s3compatible and configure ONTAP S3 parameters, including region, access credentials, internal and external endpoints.
  • SSL certificate verification: Set edpInternalCertVerify and edpExternalCertVerify to false only when ONTAP S3 is configured with self-signed certificates. If certificates are issued by a publicly trusted CA, these parameters should remain enabled.
Sample Snippet:
FQDN: "<FQDN>" # Provide the FQDN for the deployment
gmc:
  enabled: true
  pvc:
    accessMode: ReadWriteMany # AccessMode
    models:
      modelLlm:
        storage: 100Gi
      modelEmbedding:
        storage: 20Gi
      modelReranker:
        storage: 10Gi
ingress:
  service_type: LoadBalancer
edp:
  storageType: s3compatible
  s3compatible:
    region: "us-east-1"
    accessKeyId: "<your_access_key>"
    secretAccessKey: "<your_secret_key>"
    internalUrl: "https://<IP-address>"
    externalUrl: "https://<IP-address>"
    bucketNameRegexFilter: ".*"
    edpExternalCertVerify: false
    edpInternalCertVerify: false
Note:
- By default, the Intel® AI for Enterprise RAG application ingests data from all existing buckets in your SVM. If you have multiple buckets in your SVM, you can modify the bucketNameRegexFilter field so that data is ingested only from certain buckets.
- Refer to the Intel® AI for Enterprise RAG deployment documentation for details.
13. Configure scheduled synchronization settings
When installing the OPEA for Intel® AI for Enterprise RAG application, enable scheduledSync so that the application automatically ingests new or updated files from your S3 buckets.
When scheduledSync is enabled, the application automatically checks your source S3 buckets for new or updated files. Any new or updated files that are found as part of this synchronization process are automatically ingested and added to the RAG knowledge base. The application checks your source buckets based on a preset time interval. The default time interval is 60 seconds, meaning that the application checks for changes every 60 seconds. You might want to change this interval to suit your specific needs.
To enable scheduledSync and set the synchronization interval, set the following values in deployment/components/edp/values.yaml:
vi components/edp/values.yaml
presignedUrlCredentialsSystemFallback: "true"
celery:
  config:
    scheduledSync:
      enabled: true
      syncPeriodSeconds: "60"
14. Deploy Enterprise RAG 2.0/2.0.1
Before installation, validate the infrastructure readiness by following the procedures outlined in the Intel® AI for Enterprise RAG Application Deployment Guide. This step ensures that the underlying infrastructure is configured correctly and meets all prerequisites required for a successful Enterprise RAG Application installation.
Run the Installation using:
ansible-playbook -u $USER playbooks/application.yaml --tags configure,install -e @inventory/<cluster-name>/config.yaml
Note: If you do not have passwordless sudo set up on your deploy node (the laptop or jump host where you are running the ansible-playbook command), then you will need to add --ask-become-pass to this command. When using --ask-become-pass, it is critical that the ssh user have the SAME password on each node.
15. Create a DNS entry
Create a DNS Entry for the Enterprise RAG web dashboard in your DNS server. To proceed, retrieve external IP address assigned to Enterprise RAG's ingress LoadBalancer:
kubectl -n ingress-nginx get svc ingress-nginx-controller
Create DNS entry pointing to this IP address for the FQDN that you used in Step 12.
Note:
- FQDN used for the DNS entry MUST match the FQDN from the config file.
16. Access Enterprise RAG UI
Access Enterprise RAG UI by navigating to that FQDN in your browser.
Note: You can retrieve default UI credentials from cat ansible-logs/default_credentials.txt
Troubleshooting Guide
1. Issue: Keycloak Helm Installation Conflict
Scenario:
While deploying ERAG, Keycloak installation may fail with the following error:
FAILED - RETRYING: [localhost]: Install Keycloak Helm chart (5 retries left).
Failure when executing Helm command. Exited 1.
    stdout:
    stderr: Error: UPGRADE FAILED: another operation (install/upgrade/rollback) is in progress
Action:
If the failure persists after retries – Uninstall the ERAG deployment, Delete the existing auth namespace using below commands and Re-run the deployment.
ansible-playbook playbooks/application.yaml --tags uninstall -e @inventory/<cluster-name>/config.yaml
helm -n auth uninstall keycloak
kubectl -n auth get pvc # confirm all PVCs are gone; if any are left, delete them
kubectl delete ns auth
Note: Stale Helm release state can block subsequent install or upgrade operations.
2. Issue: Trident Operator Helm Chart Version Not Found
Scenario:
During the ERAG deployment, the Trident operator installation may fail due to a Helm chart version mismatch. The following error may be observed:
TASK [netapp_trident_csi_setup : Install Trident operator via Helm]
fatal: [localhost]: FAILED! => changed=false
  command: /usr/local/bin/helm --version=100.2510.0 show chart 'netapp-trident/trident-operator'
  msg: |-
    stdout:
    stderr: Error: chart "trident-operator" matching 100.2510.0 not found in netapp-trident index.
            (try 'helm repo update'): no chart version found for trident-operator-100.2510.0
Action:
If this error occurs, update the Helm repository index and re-run the deployment playbook.
helm repo update
ansible-playbook playbooks/application.yaml -e @inventory/<cluster-name>/config.yaml
Note: This is a known issue in ERAG version 2.0. A fix has been submitted and will be included in a future release.
