8. Configuration Reference
Contributors nkarthik
Karthikeyan Nagalingam, NetApp
The configuration reference describes the runtime parameters that control data ingestion, data preparation, XCP mobility, training, checkpointing, and archival. The ONTAP NAS bucket is used primarily as the prepared-data and XCP staging layer for supportability and portability. In real-time production use, the same prepared data can also be consumed through direct RDMA-capable access paths when that better matches the workload and latency requirements.
All runtime behavior is supplied through dag_run.conf, allowing the same DAG to serve different source systems, transformation engines, storage destinations, recovery policies, and archive scopes. Configure only the parameter groups required for the selected workflow, keep credentials in Airflow Connections or a secrets backend, and use the examples as non-production templates rather than as credential values.
8.1 Ingestion Parameters
Use these settings to select and configure the upstream ingestion mechanism. s3_direct uses the StorageGRID raw-data objects configured in the data-preparation group; Airbyte and NiFi settings are needed only when those respective ingestion tools are selected.
Parameter Default Required Description Example
ingestion_tool
s3_direct
No
Selects ingestion mode
"s3_direct"
airbyte_api_url
None
Airbyte only
Airbyte API endpoint
"http://airbyte:8000"
airbyte_connection_id
None
Airbyte only
Airbyte connection ID
"connection-123"
airbyte_api_token
None
Optional
Bearer token
"<TOKEN>"
airbyte_timeout_secs
30
No
Airbyte timeout
60
nifi_api_url
None
NiFi only
NiFi API endpoint
"http://nifi:8080"
nifi_process_group_id
None
NiFi only
NiFi process group
"abc123"
nifi_timeout_secs
30
No
NiFi timeout
60
8.2 Data Preparation Parameters
These settings control raw-data access, prepared-data output, input discovery, and transformation behavior. The s3_raw_* parameters refer to StorageGRID, while the code-compatible s3_formatted_* parameters identify the ONTAP NAS bucket where prepared, run-stamped data and manifests are written.
Raw StorageGRID / prepared-data ONTAP NAS bucket:
Configure separate endpoints and credentials when StorageGRID and the ONTAP NAS bucket use different S3-compatible services or access policies. The generic fallback keys apply only when a more specific raw or prepared-data setting is absent.
Parameter Default Description Example
s3_raw_bucket
ai-raw-data
StorageGRID raw input bucket
"bucket1"
s3_raw_prefix
example_ai_pipeline/raw
StorageGRID raw-data prefix
"example_ai_pipeline/raw"
s3_raw_endpoint_url
fallback chain
StorageGRID S3 endpoint
"http://10.63.150.62:10444"
s3_raw_access_key_id
fallback chain
Raw access key
"<KEY>"
s3_raw_secret_access_key
fallback chain
Raw secret key
"<SECRET>"
s3_raw_region
aws_region
Raw region
"us-east-1"
s3_formatted_bucket
ai-formatted-data
ONTAP NAS prepared-data output bucket
"prepnasbucket"
s3_formatted_prefix
example_ai_pipeline/formatted
ONTAP NAS prepared-data prefix
"example_ai_pipeline/formatted"
s3_formatted_endpoint_url
fallback chain
ONTAP NAS bucket S3 endpoint
"http://10.63.150.159"
s3_formatted_access_key_id
fallback chain
ONTAP NAS bucket access key
"<KEY>"
s3_formatted_secret_access_key
fallback chain
ONTAP NAS bucket secret key
"<SECRET>"
General fallback: s3_endpoint_url, s3_access_key_id, s3_secret_access_key, s3_session_token, s3_verify, aws_region, aws_access_key_id, aws_secret_access_key, aws_session_token.
Input selection:
Use explicit object-key settings to process known CSV inputs; otherwise, the task discovers eligible tabular objects under the configured StorageGRID raw prefix.
s3_tabular_object_keys
Auto-discovery
Explicit list of CSV keys
["raw/demo/a.csv"]
None
Single explicit CSV key
"raw/demo/a.csv"
Transformation:
Select the Python path for lightweight local preparation or Spark for distributed preparation. Sampling and the seed apply reproducibly to the generated training, validation, and inference splits.
transformation_engine
python
python or spark
"spark"
spark_required
false
Fail instead of fallback
true
table_format
none
none/delta/iceberg
"delta"
table_format_required
false
Fail if format unavailable
true
sample_count
all rows
Row limit (≤0 = all)
14400
seed
7
Reproducible shuffle seed
11
Spark:
These settings apply only to transformation_engine=spark. They control Spark process placement, resource allocation, time limits, and optional Delta Lake or Iceberg runtime dependencies.
spark_submit_bin
spark-submit
Spark binary
"/opt/spark/bin/spark-submit"
spark_master
local[*]
Spark master
"local[*]"
spark_driver_memory
4g
Driver memory
"8g"
spark_executor_memory
4g
Executor memory
"8g"
spark_timeout_secs
900/7200
Timeout (0 = disabled)
0
spark_delta_packages
Delta 3.2.0
Delta runtime package
"io.delta:delta-spark_2.12:3.2.0"
spark_iceberg_packages
Iceberg 1.5.2
Iceberg runtime package
"org.apache.iceberg:iceberg-spark-runtime-3.5_2.12:1.5.2"
spark_iceberg_catalog
local
Iceberg catalog name
"local"
8.3 XCP and Training Destination Parameters
Use this group when enable_xcp=true to validate the ONTAP NAS NFS source, invoke the XCP host, and choose the active training tier. xcp_copy_destination is the controlling switch: it selects either the ONTAP S3-specific or LustreFS-specific settings below, and downstream model stages use the same selected tier.
enable_xcp
false
Yes for XCP
Enables XCP branch
true
s3
No
s3 or lustrefs
"lustrefs"
xcp_nfs_source_ip
10.63.150.159
XCP preflight
NFS server IP
"10.63.150.159"
xcp_nfs_source_path
/prepnasbucket/example_ai_pipeline
XCP preflight
NFS export path
"/prepnasbucket/example_ai_pipeline"
ssh_user
root
No
XCP host SSH user
"root"
ssh_host
10.63.150.178
No
XCP host address
"10.63.150.178"
S3 destination (required when xcp_copy_destination=s3):
Provide these settings only for the ONTAP S3 training path. The profile or direct credentials allow XCP and the model artifact synchronization logic to access the selected ONTAP S3 bucket and prefix.
xcp_s3_endpoint
default
XCP S3 endpoint
"http://10.63.150.161"
xcp_s3_bucket
None
XCP destination bucket
"trainingbucket"
xcp_s3_dest_prefix
example_ai_pipeline
Destination prefix
"example_ai_pipeline"
xcp_s3_training_prefix
xcp_s3_dest_prefix
Training discovery prefix
xcp_s3_profile
ontaps3
Named credential profile
"ontaps3"
xcp_s3_profiles
None
Profile map
{"ontaps3": {…​}}
xcp_s3_access_key_id
None
Direct key fallback
"<KEY>"
xcp_s3_secret_access_key
None
Direct secret fallback
"<SECRET>"
xcp_s3_region
aws_region
XCP S3 region
"us-east-1"
LustreFS destination (required when xcp_copy_destination=lustrefs):
Provide these settings only for the LustreFS training path. The source and destination must be mounted and accessible on the XCP host; the destination must also be accessible to the Airflow worker that runs the model stages.
xcp_lustrefs_source_path
XCP copy source
xcp_lustrefs_dest_path
/mnt/lustre/client
LustreFS mount destination
"/mnt/lustre/client"
xcp_lustrefs_training_subpath
xcp_s3_dest_prefix
Training subdir under mount
xcp_lustrefs_newid
data_prep run stamp
XCP job identifier
"20260901_120000"
Text-source behavior:
These options control how the three text datasets are found after XCP mobility. Explicit keys override discovery; local fallback can be disabled to require that text inputs come from the selected XCP destination.
xcp_text_allow_local_fallback
true
Allow local text fallback
false
xcp_text_base_key
Auto
Explicit base-text location
"…​/text_base.json"
xcp_text_finetune_key
Auto
Explicit fine-tune-text location
"…​/text_finetune.json"
xcp_text_infer_key
Auto
Explicit inference-text location
"…​/text_infer.json"
8.4 Model Training Parameters
These settings select the local or XCP-delivered source, limit training volume, and preserve reproducible data ordering. When XCP is enabled, training reads the selected ONTAP S3 or LustreFS tier and publishes the baseline artifacts back to that same destination.
enable_xcp
false
Selects XCP or local source
true
s3
Selects source tier
"lustrefs"
sample_count
all rows
Training sample limit
14400
seed
7
11
Produces: regression_model.bin, text_vectorizer.bin, text_classifier.bin, train_metrics.json.
8.5 Fine-Tuning Parameters
Fine-tuning materializes the baseline text artifacts from the selected XCP destination, applies incremental learning to the fine-tuning dataset, and republishes the tuned classifier and its metrics. Keep its XCP settings consistent with model training to maintain artifact provenance.
enable_xcp
false
Enables artifact materialize/publish
true
s3
Selects artifact source/destination
"lustrefs"
Consumes: text_vectorizer.bin, text_classifier.bin, text_finetune.json. Produces: text_classifier_tuned.bin, fine_tune_metrics.json.
8.6 Inference Parameters
These flags control the scope of scoring after the tuned model is materialized from the selected training tier. Enable either option when validation or business requirements call for outputs beyond the default inference split and inference text input.
infer_all_splits
false
Score train/val/infer splits
true
infer_all_text
false
Score base/finetune/infer text
true
Consumes: regression_model.bin, text_vectorizer.bin, text_classifier_tuned.bin. Produces: tabular_predictions.csv, text_predictions.json.
8.7 Checkpoint Parameters
Checkpointing is scoped to model_training. These settings determine whether the training completion record is created, where it is stored, how upload failures are handled, and whether a later run verifies or reuses a valid completed training result.
checkpoint_enabled
true
Enables checkpoint file creation
true
checkpoint_store
local
local or formatted_s3
"formatted_s3"
checkpoint_upload_fail_mode
warn
warn or fail
"fail"
training_checkpoint_reuse_mode
off
off/verify_only/resume_if_exists
"resume_if_exists"
off
Backward-compatible alias
"verify_only"
8.8 Manual Archive Parameters
Use this group to enable StorageGRID archival, identify the destination bucket and credentials, and choose the archival point. The selected manual_archive_stage controls both the archive timing and whether the archive contains only baseline training artifacts or the complete inference result set.
manual_archive_enabled
false
No
Enables archival
true
inferencing
No
Archive point and artifact set: model_training for core training artifacts, or inferencing for the full result set
"model_training"
manual_archive_bucket
archivalbucket
Yes when enabled
Archive bucket
"archivalbucket"
manual_archive_prefix
ai-models
No
Archive prefix
"ai-models"
manual_archive_endpoint
default
Custom only
Archive S3 endpoint
manual_archive_profile
sgdlocal
Recommended
Credential profile
"sgdlocal"
manual_archive_profiles
None
Optional
Profile map
{"sgdlocal": {…​}}
manual_archive_include_xcp_inputs
false
No
Include XCP inputs in archive
true
manual_archive_cleanup_raw
false
No
Remove local raw folder post-upload
true
Aliases: fabricpool_archive_* for all manual_archive_* parameters.
8.8.1 Manual Archive Stage Decision
The route_manual_archive_stage branch task reads manual_archive_stage once per DAG run. The selected value determines both when archival runs and which artifacts are uploaded to the StorageGRID archival bucket. Archive objects are stored under s3://<manual_archive_bucket>/<manual_archive_prefix>/<stage>/<run_stamp>/.
manual_archive_stage value Archive timing Artifacts archived Recommended use
model_training
Immediately after model_training; does not wait for fine-tuning or inference
Preserve a reproducible baseline model, minimize archive volume, or retain a checkpoint before later stages
inferencing (default)
After fine_tuning and inferencing complete
All model_training artifacts plus text_classifier_tuned.bin, fine_tune_metrics.json, tabular_predictions.csv, and text_predictions.json
Retain the complete business outcome and prediction evidence for a model run
For either selection, set manual_archive_include_xcp_inputs=true to add locally materialized XCP training inputs when present. Set manual_archive_enabled=false to skip the archival task without changing the training and inference workflow.
8.9 Complete Sample Configuration
This catalog provides starting configurations for the principal deployment and test paths. Every example assumes raw data is in StorageGRID and prepared data is written to the ONTAP NAS bucket. Replace bucket names, endpoint addresses, filesystem paths, and profile names with values from the target environment. Do not place production access keys or secrets in CONF_JSON; configure them through Airflow Connections, Variables, or a secrets backend.
8.9.1 XCP to LustreFS with Spark and Delta Lake
Use this full-throughput example for distributed preparation and high-performance LustreFS model I/O. It processes all eligible tabular files under s3_raw_prefix, writes Delta tables during preparation, persists the training checkpoint to the ONTAP NAS prepared-data bucket, and archives the complete inference result set.
  "ingestion_tool": "s3_direct",
  "s3_raw_bucket": "bucket1",
  "s3_raw_prefix": "example_ai_pipeline/raw",
  "s3_formatted_bucket": "prepnasbucket",
  "s3_formatted_prefix": "example_ai_pipeline/formatted",
  "enable_xcp": true,
  "xcp_copy_destination": "lustrefs",
  "xcp_nfs_source_ip": "10.63.150.159",
  "xcp_nfs_source_path": "/prepnasbucket/example_ai_pipeline",
  "xcp_lustrefs_source_path": "/prepnasbucket/example_ai_pipeline",
  "xcp_lustrefs_dest_path": "/mnt/lustre/client",
  "xcp_lustrefs_training_subpath": "example_ai_pipeline",
  "xcp_text_allow_local_fallback": false,
  "transformation_engine": "spark",
  "spark_required": true,
  "table_format": "delta",
  "table_format_required": true,
  "spark_driver_memory": "8g",
  "spark_executor_memory": "8g",
  "spark_timeout_secs": 0,
  "sample_count": 14400,
  "seed": 11,
  "infer_all_splits": true,
  "infer_all_text": true,
  "checkpoint_enabled": true,
  "checkpoint_store": "formatted_s3",
  "training_checkpoint_reuse_mode": "off",
  "manual_archive_enabled": true,
  "manual_archive_stage": "inferencing",
  "manual_archive_bucket": "archivalbucket",
  "manual_archive_prefix": "ai-models",
  "manual_archive_profile": "sgdlocal",
  "manual_archive_cleanup_raw": true
8.9.2 No XCP with Python Preparation
Use this baseline configuration for a lightweight functional run. Preparation uses the local Python engine and downstream stages use the pipeline’s local prepared-data and artifact paths; XCP, Spark, table formats, checkpoint reuse, and archival are disabled.
    "enable_xcp": false,
    "transformation_engine": "python",
    "table_format": "none",
    "sample_count": 200,
    "seed": 11,
    "checkpoint_enabled": false,
    "manual_archive_enabled": false
8.9.3 Python Preparation with Two Explicit Input Files
Use this focused test when validating the pipeline against two known StorageGRID CSV objects. s3_tabular_object_keys disables automatic tabular-file discovery; the text inputs still use their expected locations under the raw prefix.
    "s3_tabular_object_keys": [
        "example_ai_pipeline/raw/tabular_part_01.csv",
        "example_ai_pipeline/raw/tabular_part_02.csv"
    "seed": 11,
8.9.4 Python Preparation with Automatic All-File Discovery
Omit s3_tabular_object_keys and s3_tabular_object_key to process every eligible tabular object under the StorageGRID raw prefix. This example is suitable for an all-files functional or scale test using the Python preparation engine.
    "sample_count": 0,
    "seed": 11,
sample_count: 0 means that data preparation uses all available rows. Set a positive value for a bounded test run.
8.9.5 XCP to ONTAP S3 with Python Preparation
Use this configuration when prepared data must be copied from the ONTAP NAS NFS export to an ONTAP S3 training bucket. Model training, fine-tuning, and inference materialize and publish artifacts through that same ONTAP S3 destination.
    "enable_xcp": true,
    "xcp_copy_destination": "s3",
    "xcp_s3_endpoint": "https://ontap-s3.example.com",
    "xcp_s3_bucket": "trainingbucket",
    "xcp_s3_dest_prefix": "example_ai_pipeline",
    "xcp_s3_training_prefix": "example_ai_pipeline",
    "xcp_s3_profile": "ontaps3",
    "seed": 11,
    "manual_archive_stage": "model_training",
    "manual_archive_profile": "storagegrid-archive"
8.9.6 XCP to ONTAP S3 with Spark and Iceberg
Use this configuration for distributed preparation with Iceberg table output and ONTAP S3 as the active training destination. Set spark_required and table_format_required to true when a run must fail rather than fall back if Spark or Iceberg is unavailable.
    "enable_xcp": true,
    "table_format": "iceberg",
    "sample_count": 0,
    "seed": 11,
8.9.7 Scenario Selection Summary
Scenario XCP destination Preparation engine Table format Input scope Archive stage
8.9.1
LustreFS
Spark
Delta
All discovered files
inferencing
8.9.2
None
Python
None
Disabled
8.9.3
None
Python
None
Two explicit files
Disabled
8.9.4
None
Python
None
Disabled
8.9.5
ONTAP S3
Python
None
model_training
8.9.6
ONTAP S3
Spark
Iceberg
inferencing
8.9.8 Execution Walkthroughs
Run the examples from the Airflow workspace. The trigger script generates a unique manual__<UTC timestamp> run ID, waits for completion, and returns a nonzero exit code for a failed or timed-out run. The following full configurations use the same CONF_JSON="$(python3 - <<'PY' …​)" pattern as the operational examples. Configure the referenced Airflow-managed connections, XCP profiles, and archive profiles in your secrets backend before running them, and keep CONF_JSON limited to non-secret bucket, endpoint, path, and profile identifiers.
The valid table format name is iceberg. Do not use icerberg, which is not a supported value.
All files, Spark, Iceberg, XCP to ONTAP S3, checkpoint to prepared-data S3, archive after inference:
import json
print(json.dumps({
    "enable_xcp": True,
    "xcp_text_allow_local_fallback": True,
    "s3_raw_endpoint_url": "https://storagegrid.example.com",
    "s3_raw_region": "us-east-1",
    "s3_formatted_endpoint_url": "https://ontap-nas.example.com",
    "s3_formatted_region": "us-east-1",
    "spark_required": True,
    "table_format_required": True,
    "sample_count": 0,
    "seed": 11,
    "infer_all_splits": True,
    "infer_all_text": True,
    "checkpoint_enabled": True,
    "manual_archive_enabled": True,
    "manual_archive_endpoint": "https://storagegrid.example.com",
    "manual_archive_cleanup_raw": True,
    "manual_archive_include_xcp_inputs": True,
}, separators=(",", ":")))
PY
CONF_JSON="$CONF_JSON" AIRFLOW_BIN=./.venv/bin/airflow INGESTION_TOOL=s3_direct \
  ./trigger_and_wait_ai_pipeline_sklearn.sh
All files, Spark, Iceberg, XCP to LustreFS, checkpoint to prepared-data S3, archive after inference:
import json
print(json.dumps({
    "enable_xcp": True,
    "ssh_user": "root",
    "ssh_host": "10.63.150.178",
    "sample_count": 0,
    "seed": 11,
PY
For ONTAP S3 mode, pass only the non-secret xcp_s3_profile name in CONF_JSON and define the corresponding credentials on the XCP host or through Airflow-managed secret storage before the run. For LustreFS mode, the xcp_s3_profiles map is intentionally omitted because the training route does not resolve ONTAP S3 credentials. In both examples, define the StorageGRID raw-data, ONTAP NAS prepared-data, and archive credentials through Airflow-managed secret storage rather than inline JSON. Omitting s3_tabular_object_keys and setting sample_count to 0 requests automatic discovery of all eligible tabular files and use of all available rows.
Python, no XCP, two-file test:
CONF_JSON='{"s3_raw_bucket":"bucket1","s3_raw_prefix":"example_ai_pipeline/raw","s3_tabular_object_keys":["example_ai_pipeline/raw/tabular_part_01.csv","example_ai_pipeline/raw/tabular_part_02.csv"],"s3_formatted_bucket":"prepnasbucket","s3_formatted_prefix":"example_ai_pipeline/formatted","enable_xcp":false,"transformation_engine":"python","table_format":"none","sample_count":200,"manual_archive_enabled":false}' \
Spark, Delta Lake, XCP to LustreFS:
CONF_JSON='{"enable_xcp":true,"xcp_copy_destination":"lustrefs","xcp_nfs_source_ip":"10.63.150.159","xcp_nfs_source_path":"/prepnasbucket/example_ai_pipeline","xcp_lustrefs_source_path":"/prepnasbucket/example_ai_pipeline","xcp_lustrefs_dest_path":"/mnt/lustre/client","xcp_lustrefs_training_subpath":"example_ai_pipeline","transformation_engine":"spark","spark_required":true,"table_format":"delta","table_format_required":true,"sample_count":14400,"manual_archive_enabled":true,"manual_archive_stage":"inferencing"}' \
Spark, Iceberg, XCP to ONTAP S3:
CONF_JSON='{"enable_xcp":true,"xcp_copy_destination":"s3","xcp_nfs_source_ip":"10.63.150.159","xcp_nfs_source_path":"/prepnasbucket/example_ai_pipeline","xcp_s3_bucket":"trainingbucket","xcp_s3_dest_prefix":"example_ai_pipeline","xcp_s3_profile":"ontaps3","transformation_engine":"spark","spark_required":true,"table_format":"iceberg","table_format_required":true,"sample_count":0,"manual_archive_enabled":true,"manual_archive_stage":"inferencing"}' \
Before an XCP run, verify the configured ONTAP NAS NFS path and destination accessibility from the XCP host. After a successful run, review task logs for [data_prep] effective_config, [xcp_copy] effective_config, [model_training] effective_config, and [manual_archive] to confirm the selected engine, input scope, destination, and archive stage.
