7. Deployment Architecture
Contributors nkarthik
Karthikeyan Nagalingam, NetApp
This section defines the infrastructure placement, software dependencies, and network connectivity required to operate the pipeline. The deployment separates Airflow orchestration from the XCP data-mobility host while connecting both components to StorageGRID, ONTAP NAS, and the selected ONTAP S3 or LustreFS training destination.
7.1 Reference Infrastructure Requirements
The following components establish the minimum functional deployment footprint. Size the Airflow host for the selected preparation engine and concurrent task load; place the XCP host where it can access the ONTAP NAS NFS export and the selected destination without unnecessary network hops. LustreFS mode requires compatible mounts on both the XCP host and the Airflow worker.
Component Requirement
Airflow host
CPU/memory sized to Spark or Python transform load
XCP host
Network access to NFS/Lustre and NetApp ONTAP S3 endpoints
LustreFS clients
Mounted on XCP host and Airflow host when selected as destination
7.1.1 Reference Validation Environment
The following environment was used as a representative single-node validation profile. It is a starting point for functional and performance evaluation, not a production sizing recommendation; customers must size compute, network, storage capacity, and protection according to their dataset volume, concurrency, retention, recovery, and service-level requirements.
Layer Reference Hardware / Software
Compute and network
One server with 256 GB RAM, 64 CPU cores, and 10 GbE connectivity
ONTAP active storage
One NetApp A800 system with 48 x 1.8 TB SSDs
Object storage
One NetApp StorageGRID SG5864 appliance
High-throughput training storage
One NetApp E2812 system with LustreFS
Platform software
Kubernetes, Apache Airflow, Apache Airbyte, single-node Apache Spark, NetApp XCP, and LustreFS
7.2 Software Version Matrix
This matrix identifies the runtime software used by the validated pipeline. Keep the Airflow and Python environments compatible with the deployed providers and packages. Spark, Delta Lake, and Iceberg are optional and are required only when data_prep uses the Spark transformation path or a corresponding table format.
Software Version/Notes
Apache Airflow
2.x
Python
3.11
boto3
Latest stable
scikit-learn
Latest stable
PySpark (optional)
Compatible with Delta 3.2.0 / Iceberg 1.5.2 runtime packages
NetApp XCP
Installed on remote host, e.g. /usr/src/xcp/linux/xcp
7.3 Network Requirements
These network flows must be permitted by routing, firewall, and name-resolution policies. HTTPS is recommended for every S3-compatible endpoint in production; use the configured custom port where an endpoint does not use the default HTTPS port. Confirm Lustre client connectivity according to the deployed LustreFS implementation.
Flow Protocol/Port
Airflow → ONTAP S3
HTTPS/HTTP (443/80 or custom)
Airflow → XCP host
SSH (22)
XCP host → NFS source
NFS (2049)
XCP host → LustreFS
Lustre client ports
XCP host → ONTAP S3 (S3 mode)
HTTPS/HTTP
7.4 Deployment Notes
Section / Topic Guidance / Operational Practice
SSH Connection Setup
Configure Airflow connection ssh_default to target the XCP host over port 22 with restricted SSH key permissions (600).
Service Lifecycle Management
Use tools/airflow_ctl.sh to manage the local Airflow scheduler and webserver lifecycle during deployment and maintenance.
Credential & Secret Storage
Store credentials, API tokens, and access keys in Airflow Connections, Variables, or a secrets backend rather than inline in dag_run.conf.
Infrastructure & Task Observability
Monitor scheduler heartbeat and task execution independently so orchestration availability issues are distinguished from DAG failures.
7.5 Installation and Prerequisites
This subsection defines the baseline installation steps required to build, configure, and run the NetApp AI validated pipeline in a fresh environment. It is intended for operators, architects, and engineers setting up the Airflow workspace before running any DAGs.
7.5.1 Prerequisites
Before installing the solution, confirm that the target host meets the following minimum requirements:
  • Linux operating system, preferably Ubuntu 22.04/24.04 or RHEL 8+.
  • Python 3.11 with pip, venv, and build tooling available.
  • Git installed on the host for source retrieval and version management.
  • Apache Airflow 2.x deployed in a dedicated Python virtual environment.
  • SSH access from the Airflow host to the NetApp XCP host.
  • Network connectivity from the Airflow host to StorageGRID, ONTAP NAS, and the selected ONTAP S3 or LustreFS destination.
  • S3-compatible endpoint access for raw data, prepared-data staging, and archival storage.
  • Optional: Java runtime and Spark 3.x if the spark preparation path is used.
  • Optional: Delta Lake and Iceberg runtime packages when table_format=delta or table_format=iceberg is selected.
  • Optional: Lustre client mount when xcp_copy_destination=lustrefs is used.
7.5.2 Software Package Acquisition and Repository Access
To obtain the software package, automation DAGs, deployment scripts, and validation artifacts for this solution, contact the NetApp AI & Data Mobility engineering team at ng-data-mobility-in-ai-pipeline@netapp.com.
Once access is granted, download or clone the project source from GitHub into the target working directory:
# Example GitHub clone
mkdir -p /opt/netapp-ai
cd /opt/netapp-ai
git clone https://github.com/<your-org>/<your-repo>.git
cd <your-repo>
git checkout main
ls -la
If you already cloned the repository under /opt/netapp-ai/<your-repo>, continue from that working directory instead of downloading another copy.
7.5.3 Create the Python Environment
Create a dedicated virtual environment and install the base dependencies for Airflow and the pipeline.
export REPO_ROOT=/opt/netapp-ai/<your-repo>
cd "$REPO_ROOT"
python3 -m venv "$REPO_ROOT/.venv"
source "$REPO_ROOT/.venv/bin/activate"
python -m pip install --upgrade pip setuptools wheel
pip install "apache-airflow>=2.8,<3.0" boto3 scikit-learn
For Spark-based preparation and Lakehouse table formats, install the optional packages as needed:
pip install pyspark==3.5.*
pip install delta-spark==3.2.0
pip install apache-iceberg==1.5.2
Use the exact package versions supported by your Spark runtime and cluster topology. Do not mix incompatible Spark, Delta, and Iceberg combinations.
7.5.4 Configure Airflow and the Repository
From the cloned repository root, initialize the Airflow metadata database and verify that the DAG files are visible to Airflow.
export AIRFLOW_HOME="$REPO_ROOT/.airflow"
export AIRFLOW__CORE__DAGS_FOLDER="$REPO_ROOT"
export AIRFLOW__CORE__LOAD_EXAMPLES=False
airflow db init
airflow dags list | grep -E "example_ai_pipeline|example_ai_pipeline_sklearn"
The workspace includes the Airflow configuration file and DAGs needed for the validated pipeline. If the repository contains a helper script for local lifecycle management, use it to start the scheduler and webserver instead of invoking Airflow manually.
# Start the Airflow scheduler and webserver with the deployment's service manager.
# or, if using the standard commands:
# airflow scheduler
# airflow webserver
7.5.5 Required Connectivity and Secret Configuration
Before running the pipeline, confirm that the following resources are reachable from the Airflow host:
  • StorageGRID raw-data S3 endpoint.
  • ONTAP NAS prepared-data bucket endpoint.
  • ONTAP S3 target endpoint when xcp_copy_destination=s3.
  • LustreFS mount when xcp_copy_destination=lustrefs.
  • XCP host over SSH using ssh_default or the configured SSH connection.
Store credentials in Airflow Connections, Variables, or a secrets backend rather than embedding them in shell history or DAG code. Set the required access keys, endpoints, and profile mappings before triggering a pipeline run.
7.5.6 Verify the Installation
A successful installation is confirmed when the Airflow scheduler and DAGs are running and the example pipeline can be listed and triggered without configuration errors.
airflow dags list
airflow tasks list example_ai_pipeline_sklearn
If the installation is correct, the DAG should be present in Airflow and ready for a CONF_JSON-driven run using the trigger script in the repository root.
./trigger_and_wait_ai_pipeline_sklearn.sh
At this point, the environment is ready for the configuration examples in Section 8 and the deployment scenarios described in the operational guide.
