1. Executive Summary
Contributors nkarthik
Karthikeyan Nagalingam, NetApp
1.1 Purpose of this Document
This NetApp Validated Architecture (NVA) documents a production-grade AI data pipeline that ingests raw data, prepares it for machine learning, moves it at high speed between storage tiers using NetApp XCP, trains and incrementally fine-tunes models, generates predictions, and archives results for governance and reproducibility. It is intended to guide architects and infrastructure teams through design rationale, deployment, configuration, and operations.
1.2 Audience
Solution architects, storage/infrastructure engineers, data platform engineers, ML engineers, and IT decision-makers evaluating NetApp storage and data mobility technology for AI/ML workloads.
1.3 Business Challenge Overview
AI teams need data that lands in object storage to be reliably transformed and then delivered to whichever compute-storage tier best serves training — elastic S3 for general workloads, or high-performance parallel filesystems (LustreFS) for I/O-intensive training. Without a governed data mobility and orchestration layer, teams resort to fragile, single-purpose scripts lacking retries, checkpointing, storage flexibility, and audit trails.
Enterprise AI programs are stalling — not because of model or compute limitations, but because legacy storage was not designed for AI. Moving massive datasets, keeping GPUs fed during training, managing checkpoint overhead, and controlling storage costs consume more effort than the AI work itself. Single-tier architectures force a performance-versus-cost trade-off that compounds as models and datasets grow.
1.4 NetApp Solution Summary
The solution orchestrates ingestion, preparation, data mobility, training, fine-tuning, inference, and archival as an Apache Airflow DAG (Directed Acyclic Graph). StorageGRID anchors the raw-data and long-term archival object tiers. Data preparation writes run-stamped datasets and manifests to an ONTAP NAS bucket, exposed by NFS as the XCP source. NetApp XCP then moves the prepared data to a runtime-selectable training destination — NetApp ONTAP S3 or LustreFS — with no code changes required to switch tiers.
Note
In this design, the ONTAP NAS bucket is used primarily from an XCP supportability and validation perspective, because it provides a consistent NFS source for the mobility workflow. In real production environments, the same active data can also be served directly over high-performance RDMA-capable paths, so the ONTAP NAS layer should be viewed as an operationally convenient and supportable staging pattern rather than the only runtime access method.
This pipeline is a concrete implementation of the broader NetApp AI Storage Architecture — a purpose-built, three-tier storage framework that aligns performance and cost to each AI workload phase:
  • E-Series (LustreFS): Ultra-high-throughput parallel storage for GPU-intensive model training and checkpointing.
  • ONTAP (AFF/AFX): High-performance active storage for training, fine-tuning, inference, vector/RAG workloads, and selected data preparation use cases, with FAS and NAS bucket support.
  • StorageGRID: Scalable S3-compatible object storage for data ingestion, governance, and long-term retention.
Data movement across tiers is fully automated via Apache Airflow and NetApp XCP, eliminating manual operations from the critical path entirely.
The NetApp storage architecture helps enterprises support distributed data preparation, model training, fine-tuning, inferencing, and lifecycle governance without forcing all data into a single centralized lake. By reducing unnecessary data movement, it is a natural fit for hybrid AI workflows.
1.5 Why NetApp
Dimension Conventional Approach NetApp AI Storage Architecture
GPU Productivity
Storage bottlenecks idle expensive compute
GPUDirect Storage over RDMA helps keep GPU clusters fully utilized
Data Mobility
Manual scripts delay pipelines
Automated inter-tier movement via Airflow + XCP
Cost Control
All data on high-cost flash
FabricPool auto-demotes cold data to low-cost object storage
Multi-Tenancy
Shared namespaces risk data leakage
Dedicated ONTAP SVMs enforce strict tenant isolation
Workload Breadth
Separate stacks for training vs. inference
Single unified architecture spanning the full AI lifecycle
1.6 The Business Case
GPU compute is typically the largest capital expense in an AI infrastructure budget. Every hour a cluster sits idle waiting for data is direct, measurable financial loss. NetApp ensures the right data is on the right tier at the right time — automatically — delivering higher AI throughput, lower TCO, and an architecture that scales from POC to enterprise production without redesign.
1.7 Key Benefits at a Glance
Benefit Description
Unified orchestration
Single DAG spans ingest → archive
Storage-tier flexibility
S3 or LustreFS selected per run via configuration
Reduced retraining cost
Incremental fine-tuning via partial_fit
Faster recovery
Checkpoint-based training resume
Full lineage
Manifests, effective-config logs, archival records
No storage lock-in
Multi-protocol: NFS, S3, Lustre
GPU utilization
Tiered storage keeps compute fed, avoiding idle-GPU cost
Cost-optimized retention
FabricPool auto-tiers cold data to object storage
