5. Solution Design and Storage Architecture Detail
Contributors nkarthik
Karthikeyan Nagalingam, NetApp
5.1 Design Principles
Configuration over code changes; explicit stage boundaries with typed contracts; consistent artifact routing; fail-fast validation with actionable errors; storage-tier neutrality.
5.2 Stage Design Summary
Ingestion
ingestion_tool selects s3_direct, none, airbyte, or nifi; returns normalized metadata
Data Preparation
Discovers/accepts raw StorageGRID tabular keys; normalizes Airbyte/plain CSV; produces deterministic train/val/infer splits; writes a run-stamped prepared-data prefix and manifest to the ONTAP NAS bucket
Data Mobility (XCP)
Copies prepared data from the ONTAP NAS NFS export; xcp_copy_destination drives the XCP target and training read path
Model Training
Trains locally or from XCP destination (S3/LustreFS); multi-format (CSV/Parquet/JSON) discovery
Fine-Tuning
Materializes base model from XCP destination; partial_fit with expanded class set; republishes tuned model
Inference
Materializes tuned artifacts from same XCP destination; configurable split/text scope
Checkpoint/Resume
write_stage_checkpoint persists completion record; _small_resume_guard validates/reuses on subsequent runs
Archival
model_training archives core trained models immediately; inferencing waits for predictions and archives the full result set; optional XCP-input inclusion and raw-folder cleanup
5.3 Configuration-Driven Philosophy
All non-secret storage, engine, and behavioral selections are dag_run.conf parameters — switching between S3 and LustreFS, or Python and Spark, requires no code modification, while Airflow-managed secret storage resolves the required credentials.
5.4 Storage Architecture Detail
The storage architecture separates the AI lifecycle into purpose-built tiers: StorageGRID holds raw and archival objects, the ONTAP NAS bucket holds prepared and run-stamped datasets, and ONTAP S3 or LustreFS provides the selected active training tier. This separation keeps source data, prepared data, model artifacts, and archived evidence independently manageable while preserving lineage through the shared run_stamp.
5.4.1 Storage Layout Diagrams
Tier Logical Storage Path Contents / Artifacts Stored
StorageGRID Raw Tier
s3://raw_bucket/raw_prefix/
Tabular CSV parts (tabular_part_*.csv), text inputs (text_base.json, text_finetune.json, text_infer.json)
ONTAP NAS Prepared Tier
s3://prepared_bucket/prepared_prefix/run_stamp/
Formatted splits (data/tabular_*.csv), text files, data_prep_manifest.json, Lakehouse tables (tables/ Delta/Iceberg)
Active Training Tier (XCP Dest)
<xcp_prefix>/formatted/run_stamp/
Copied data splits, trained model binaries (artifacts/*.bin), evaluation metrics (artifacts/*_metrics.json)
StorageGRID Archival Tier
s3://archive_bucket/archive_prefix/stage/run_stamp/
Stage-scoped baseline or full model artifacts, prediction evidence (tabular_predictions.csv, text_predictions.json)
Inter-Tier Lineage & Flow
Raw → Prepared → Active Tier → Archival
End-to-end data movement and artifact lineage linked across all storage tiers via the shared run_stamp
This diagram maps the logical bucket and prefix layout for a single pipeline run across all storage tiers:
Logical Storage Layout for a Single Pipeline Run
5.4.2 Storage Sizing Guidance
Size each tier independently according to its role and retention policy. The ONTAP NAS and selected XCP destination must accommodate concurrent active runs, whereas StorageGRID capacity is driven primarily by raw-data and archival retention. Include temporary working capacity and growth headroom when planning peak pipeline concurrency.
Tier Sizing Basis
StorageGRID raw bucket
Ingestion volume × retention window
ONTAP NAS prepared-data bucket
Prepared dataset size × number of retained runs
XCP destination (S3 or Lustre)
Peak concurrent training dataset size + model artifact overhead
Archival bucket
Retention policy × archive stage selection (model_training = smaller; inferencing = larger)
5.4.3 Storage Performance Considerations
The XCP destination is selected per run with xcp_copy_destination, allowing storage performance to match the workload instead of forcing every workload onto one tier. Select LustreFS for high-row-count datasets, many concurrent readers, or I/O-intensive training. Select ONTAP S3 for cost-conscious, elastic-access workloads whose performance requirements do not demand a parallel filesystem. In either case, XCP keeps data and model artifacts aligned with the selected training tier.
