Deploy hybrid AI training with Union.ai and NetApp FlexCache
Contributors sathyaga netapp-jsnyder
Learn how to deploy a hybrid AI training environment using Union.ai orchestration with NetApp FlexCache and Trident for Kubernetes storage provisioning.
David Espejo, Union.ai
Sathish Thyagarajan, NetApp
Overview
Union.ai’s hybrid orchestration platform integrates seamlessly with NetApp ONTAP and FlexCache to accelerate AI/ML training workflows. This solution allows data to remain securely on-premises while leveraging cloud-based GPU compute for AI training workloads. NetApp FlexCache ensures only necessary data is cached in the cloud, enabling efficient, secure, and scalable hybrid AI/ML pipelines.
Customer Use Case: Hybrid Cloud AI Training
  • On-premises data: Stored on NetApp ONTAP for compliance and security.
  • Cloud compute: Scalable GPU training on EKS/GKE/AKS.
  • AI/ML orchestration: Union.ai coordinates data processing and training
    across environments.
  • Storage provisioning: NetApp Trident automates PVC/PV provisioning.
Customer Value
  • Run AI workloads on massive datasets using NetApp ONTAP’s scale-out
    capabilities.
  • Move and sync data across on-prem and cloud using NetApp’s hybrid
    cloud features.
  • Quickly cache on-prem data in the cloud using FlexCache.
  • Union.ai simplifies orchestration across environments with versioning,
    lineage tracking, and artifact management.
  • Execute training in the cloud while keeping sensitive data
    on-premises.
Enabling the Plugin – Prerequisites
Requirement
Details
ONTAP Version
ONTAP 9.7+ (FlexCache license not required)
FlexCache License
Required on ONTAP 9.6 and earlier
Kubernetes
On-prem and cloud clusters (EKS/GKE/AKS)
Trident
Installed on both on-prem and cloud clusters
Union.ai
Control plane deployed (Union Cloud or self-hosted)
Networking
Inter-cluster connectivity (if ONTAP clusters are separate)
Permissions
Admin access to ONTAP and Kubernetes clusters.
✅ Use correct ONTAP credentials (e.g., vsadmin)
New to Union.ai?
See the companion guide at the end of this doc
Reference Architecture
The following figure shows the Union.ai control plane integrated with NetApp storage for hybrid AI training.
Hybrid AI training architecture with Union.ai and NetApp
  • Union.ai Control Plane: Orchestrates workflows, manages data movement,
    and integrates with NetApp APIs.
  • NetApp ONTAP + FlexCache: Provides efficient data caching from on-prem
    to cloud.
  • Hybrid Training Clusters: Training jobs run in cloud K8s clusters
    (e.g., EKS) with data cached from on-prem.
Step 1: Create a FlexCache Volume
Using ONTAP System Manager
  1. Navigate to Storage > Volumes.
  2. Click Add.
  3. Select More Options.
  4. Enable Add as cache for a remote volume.
  5. Choose your source (on-prem) and destination (cloud) volumes.
  6. Define QoS or performance level (optional).
  7. Click Create.
💡If the NetApp DataOps Toolkit is not working due to permission or aggregate issues, create the FlexCache volume directly using ONTAP System Manager or CLI.
Step 2: Configure Trident
Install Trident on both clusters:
Create Trident Backend
kind: TridentBackendConfig
metadata:
spec:
version: 1
storageDriverName: ontap-nas
managementLIF: <ONTAP-MGMT-IP>
dataLIF: <ONTAP-DATA-IP>
svm: <SVM-NAME>
username: vsadmin
password: <password>
Apply: kubectl apply -f backend-flexcache.yaml
If you receive a 401 Unauthorized error, verify that the ONTAP user has sufficient API permissions and that the correct username (vsadmin) and password are used.
Define StorageClass
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
backendType: "ontap-nas"
Apply:
kubectl apply -f storageclass-flexcache.yaml
Step 3: Deploy Union.ai Workflows
Union uses PVCs to mount FlexCache volumes into training jobs.
Example PodTemplate
apiVersion: v1
kind: PodTemplate
metadata:
namespace: flytesnacks-development
template:
metadata:
labels:
default-storage: netapp
spec:
containers:
- name: primary
volumeMounts:
- name: flexcache-storage
mountPath: /data/flexcache
volumes:
persistentVolumeClaim:
claimName: flexcache-pvc
Example Workflow
from union import task, workflow
@task(pod_template="netapp-podtemplate")
def train_model(pvc_path: str):
Load and train on data from the PVC
@workflow
def training_pipeline():
train_model(pvc_path="/data/flexcache")
Union Operator will:
  • Create the PVC
  • Mount the FlexCache volume
  • Schedule the job in the cloud K8s cluster
Step 4: Validate Integration_
Task Validation
PVC Mount
Training pods should mount /data/flexcache successfully
Data Access
Training jobs can read/write from FlexCache
Cache Behavior
Monitor cache hit/miss in ONTAP. Ensure aggregates
support FlexCache
Performance
Validate latency and throughput for training workloads
Use NetApp BlueXP or ONTAP CLI to monitor performance.
Security Considerations
  • Use VPC endpoints for FSx for NetApp ONTAP
  • Enable encryption in transit and at rest
  • Apply RBAC/IAM for ONTAP access
  • Union.ai does not access or store customer data
Monitoring and Optimization
Tool
Purpose
NetApp BlueXP
Monitor FlexCache usage and performance
Union.ai UI
Track pipeline status and metrics
Trident Logs
Debug PVC or backend issues
Optional Enhancements
  • Automate FlexCache creation using BlueXP APIs
  • Use Union SDK to warm up cache before training
  • Add batch inference or model serving pipelines post-training
  • If DataOps Toolkit fails, fall back to manual FlexCache creation via
    System Manager
Troubleshooting
Issue Resolution
PVC stuck in Pending
Check Trident logs and backend config
401 Unauthorized from ONTAP API
Use vsadmin and verify permissions
Job failed: No suitable storage
Ensure ONTAP aggregate supports
FlexCache/FabricPool
Slow training performance
Check cache hit ratio and network latency
Data not syncing
Validate FlexCache relationship health in ONTAP
  1. Validate FlexCache with test data
  2. Deploy Union.ai training pipelines
  3. Monitor and optimize performance
  4. Document customer-specific setup
Conclusion
You now have a validated hybrid AI training environment using Union.ai and NetApp FlexCache. Training jobs can run in the cloud while accessing on-premises data securely and efficiently—without replicating entire datasets or compromising governance.
Union.ai - Companion Guide
Step 1: Choose Deployment Model
Option A: Union Cloud
Option B: Self-hosted
helm install union unionai/union -n union-system -f values.yaml
Step 2: Install Union Operator
kubectl get pods -n union-system
Step 3: Install Union CLI
pip install unionai
union login
Step 4: Register Workflow
union project create hybrid-ai
union register training_pipeline.py --project hybrid-ai
Step 5: Run & Monitor
union run training_pipeline --project hybrid-ai
union watch training_pipeline
View logs in the Union UI
Step 6: Register Compute Cluster (Optional)
union cluster register --name cloud-k8s --kubeconfig ~/.kube/config
Step 7: Track Artifacts & Lineage
Union automatically tracks:
  • Input/output parameters
  • Data versions
  • Logs and metrics
  • Execution lineage
