Versions of various components used in the solution validation
Contributors banum-netapp kevin-hoke
The solution tests and validates Migration & Centralized Data Protection with OpenShift container platform, OpenShift Advanced Cluster Manager, NetApp ONTAP, and NetApp Trident Protect.
Scenarios 1, 2 and 3 of the solution were validated using the versions as shown in the table below:
Component
Version
VMware
vSphere Client version 8.0.0.10200
VMware ESXi, 8.0.0, 20842819
Hub Cluster
OpenShift 4.11.34
Source and Destination Clusters
OpenShift 4.12.9
on-premises and in AWS
NetApp Trident
Trident Server and Client 23.04.0
Trident Protect 22.11.0-82
NetApp ONTAP
ONTAP 9.12.1
AWS FSx ONTAP
Single AZ
Scenario 4 of the solution was validated using the versions as shown in the table below:
Component
Version
VMware
vSphere Client version 8.0.2.00000
VMware ESXi, 8.0.2, 22380479
Hub Cluster
OpenShift 4.13.13
OpenShift 4.13.12
on-premises and in Google Cloud
NetApp Trident
Trident Server and Client 23.07.0
NetApp ONTAP
ONTAP 9.12.1
Cloud Volumes ONTAP
Single AZ, Single node,9.14.0
Scenario 5 of the solution was validated using the versions as shown in the table below:
Component
Version
VMware
OpenShift 4.13.25
on-premises and in Azure
NetApp Trident
Trident Server and Client 23.10.0
Trident Protect 23.10
NetApp ONTAP
ONTAP 9.12.1
Cloud Volumes ONTAP
