NetApp Storage options for Public Cloud Providers
Contributors kevin-hoke
Explore the options for NetApp as storage in the three major hyperscalers.
AWS / VMC
AWS supports NetApp storage in the following configurations:
  • FSx ONTAP as guest connected storage
  • Cloud Volumes ONTAP (CVO) as guest connected storage
  • FSx ONTAP as a supplemental NFS datastore
Azure / AVS
Azure supports NetApp storage in the following configurations:
  • Azure NetApp Files (ANF) as guest connected storage
  • Azure NetApp Files (ANF) as a supplemental NFS datastore
GCP / GCVE
Google Cloud supports NetApp storage in the following configurations:
  • Google Cloud NetApp Volumes (NetApp Volumes) as guest connected storage
  • Google Cloud NetApp Volumes (NetApp Volumes) as a supplemental NFS datastore
