NetApp Storage Overview
NetApp has several storage platforms that are qualified with our Trident Storage Orchestrator to provision storage for applications deployed as containers.
AFF and FAS systems run NetApp ONTAP and provide storage for both file-based (NFS) and block-based (iSCSI) use cases.
Cloud Volumes ONTAP and ONTAP Select provide the same benefits in the cloud and virtual space respectively.
Google Cloud NetApp Volumes (GCP) and Azure NetApp Files provide file-based storage in the cloud.
Amazon FSx ONTAP is a fully managed service on AWS that provides storage for file-based use cases.
Each storage system in the NetApp portfolio can ease both data management and movement between on-premises sites and the cloud, ensuring that your data is where your applications are. |
