NetApp container solutions
NVA-1165: Anthos with NetApp
Contributors banum-netapp kevin-hoke
Banu Sundhar and Suresh Thoppay, NetApp
This reference document provides deployment validation of the Anthos with NetApp solution by NetApp and our engineering partners when it is deployed in multiple data-center environments. It also details storage integration with NetApp storage systems by using the Trident storage orchestrator for the management of persistent storage. Lastly, we explore and document a number of solution validations and real-world use cases.
Use cases
The Anthos with NetApp solution is architected to deliver exceptional value for customers with the following use cases:
  • Easy to deploy and manage Anthos environment deployed using the provided bmctl tool on bare metal or the gkectl tool on VMware vSphere.
  • Combined power of enterprise container and virtualized workloads with Anthos deployed virtually on vSphere or on bare metal with kubevirt.
  • Real-world configuration and use cases highlighting Anthos features when used with NetApp storage and Trident, the open-source storage orchestrator for Kubernetes.
Business value
Enterprises are increasingly adopting DevOps practices to create new products, shorten release cycles, and rapidly add new features. Because of their innate agile nature, containers and microservices play a crucial role in supporting DevOps practices. However, practicing DevOps at a production scale in an enterprise environment presents its own challenges and imposes certain requirements on the underlying infrastructure, such as the following:
  • High availability at all layers in the stack
  • Ease of deployment procedures
  • Non-disruptive operations and upgrades
  • API-driven and programmable infrastructure to keep up with microservices agility
  • Multitenancy with performance guarantees
  • The ability to run virtualized and containerized workloads simultaneously
  • The ability to scale infrastructure independently based on workload demands
The Anthos with NetApp solution acknowledges these challenges and presents a solution that helps address each concern by implementing the fully automated deployment of Anthos on prem in the customer's data center environment of choice.
Technology overview
The Anthos with NetApp solution is comprised of the following major components:
Anthos On Prem
Anthos On Prem is a fully supported enterprise Kubernetes platform that can be deployed in the VMware vSphere hypervisor, or on a bare metal infrastructure of your choosing.
For more information about Anthos, see the Anthos website located here.
NetApp has several storage systems perfect for enterprise data centers and hybrid cloud deployments. The NetApp portfolio includes NetApp ONTAP, Cloud Volumes ONTAP, Google Cloud NetApp Volumes, Azure NetApp Files, FSx ONTAP for NetApp ONTAP storage systems, all of which can provide persistent storage for containerized applications.
For more information, visit the NetApp website.
NetApp storage integrations
Trident is an open-source and fully-supported storage orchestrator for containers and Kubernetes distributions, including Anthos.
For more information, visit the Trident documentation.
Advanced configuration options
This section is dedicated to customizations that real world users would likely need to perform when deploying this solution into production, such as creating a dedicated private image registry or deploying custom load balancer instances.
Current support matrix for validated releases
See Anthos storage partner support matrix for validated releases.
