NetApp container solutions
NetApp ONTAP NFS configuration
Contributors kevin-hoke
To enable Trident integration with the NetApp ONTAP storage system, you must create a backend that enables communication with the storage system.
  1. There are sample backend files available in the downloaded installation archive in the sample-input folder hierarchy. For NetApp ONTAP systems serving NFS, copy the backend-ontap-nas.json file to your working directory and edit the file.
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ cp sample-input/backends-samples/ontap-nas/backend-ontap-nas.json ./
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ vi backend-ontap-nas.json
  2. Edit the backendName, managementLIF, dataLIF, svm, username, and password values in this file.
        "version": 1,
        "storageDriverName": "ontap-nas",
        "backendName": "ontap-nas+10.61.181.221",
        "managementLIF": "172.21.224.201",
        "dataLIF": "10.61.181.221",
        "svm": "trident_svm",
        "username": "cluster-admin",
        "password": "password"
    Note It is a best practice to define the custom backendName value as a combination of the storageDriverName and the dataLIF that is serving NFS for easy identification.
  3. With this backend file in place, run the following command to create your first backend.
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ ./tridentctl -n trident create backend -f backend-ontap-nas.json
    |          NAME           | STORAGE DRIVER |                 UUID                 | STATE  | VOLUMES |
    | ontap-nas+10.61.181.221 | ontap-nas      | be7a619d-c81d-445c-b80c-5c87a73c5b1e | online |       0 |
  4. With the backend created, you must next create a storage class. Just as with the backend, there is a sample storage class file that can be edited for the environment available in the sample-inputs folder. Copy it to the working directory and make necessary edits to reflect the backend created.
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ cp sample-input/storage-class-samples/storage-class-csi.yaml.templ ./storage-class-basic.yaml
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ vi storage-class-basic.yaml
  5. The only edit that must be made to this file is to define the backendType value to the name of the storage driver from the newly created backend. Also note the name-field value, which must be referenced in a later step.
    apiVersion: storage.k8s.io/v1
    kind: StorageClass
    metadata:
    parameters:
      backendType: "ontap-nas"
    Note There is an optional field called fsType that is defined in this file. This line can be deleted in NFS backends.
  6. Run the kubectl command to create the storage class.
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ kubectl create -f storage-class-basic.yaml
    storageclass.storage.k8s.io/basic-csi created
  7. With the storage class created, you must then create the first persistent volume claim (PVC). There is a sample pvc-basic.yaml file that can be used to perform this action located in sample-inputs as well.
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ cp sample-input/pvc-samples/pvc-basic.yaml ./
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ vi pvc-basic.yaml
  8. The only edit that must be made to this file is ensuring that the storageClassName field matches the one just created. The PVC definition can be further customized as required by the workload to be provisioned.
    kind: PersistentVolumeClaim
    apiVersion: v1
    metadata:
    spec:
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 1Gi
      storageClassName: basic-csi
  9. Create the PVC by issuing the kubectl command. Creation can take some time depending on the size of the backing volume being created, so you can watch the process as it completes.
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ kubectl create -f pvc-basic.yaml
    persistentvolumeclaim/basic created
    [ubuntu@gke-admin-ws-2022-05-03 trident-installer]$ kubectl get pvc
    NAME    STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS   AGE
    basic   Bound    pvc-b4370d37-0fa4-4c17-bd86-94f96c94b42d   1Gi        RWO            basic-csi      7s
