NetApp container solutions
Governance and risk
Contributors banum-netapp kevin-hoke
This feature allows you to define the compliance policies for different clusters and make sure that the clusters adhere to it. You can configure the policies to either inform or remediate any deviations or violations of the rules.
  1. Navigate to Governance and Risk from the sidebar.
  2. To create compliance policies, click Create Policy, enter the details of the policy standards, and select the clusters that should adhere to this policy. If you want to automatically remediate the violations of this policy, select the checkbox Enforce if Supported and click Create.
    Create compliance policy
  3. After all the required policies are configured, any policy or cluster violations can be monitored and remediated from Advanced Cluster Management.
    Policy monitoring
