Installing MetalLB load balancers: Red Hat OpenShift with NetApp
This page lists the installation and configuration instructions for the MetalLB load balancer.
MetalLB is a self-hosted network load balancer installed on your OpenShift cluster that allows the creation of OpenShift services of type load balancer in clusters that do not run on a cloud provider. The two main features of MetalLB that work together to support LoadBalancer services are address allocation and external announcement.
MetalLB configuration options
Based on how MetalLB announces the IP address assigned to LoadBalancer services outside of the OpenShift cluster, it operates in two modes:
Layer 2 mode. In this mode, one node in the OpenShift cluster takes ownership of the service and responds to ARP requests for that IP to make it reachable outside of the OpenShift cluster. Because only the node advertises the IP, it has a bandwidth bottleneck and slow failover limitations. For more information, see MetalLB Layer 2 mode documentation.
BGP mode. In this mode, all nodes in the OpenShift cluster establish BGP peering sessions with a router and advertise the routes to forward traffic to the service IPs. The prerequisite for this is to integrate MetalLB with a router in that network. Owing to the hashing mechanism in BGP, it has certain limitation when IP-to-Node mapping for a service changes. For more information, refer to MetalLB BGP mode documentation.
For the purpose of this document, we are configuring MetalLB in layer-2 mode. |
Installing The MetalLB Load Balancer
Download the MetalLB resources.
[netapp-user@rhel7 ~]$ wget https://raw.githubusercontent.com/metallb/metallb/v0.10.2/manifests/namespace.yaml [netapp-user@rhel7 ~]$ wget https://raw.githubusercontent.com/metallb/metallb/v0.10.2/manifests/metallb.yaml
Edit file
metallb.yamland removespec.template.spec.securityContextfrom controller Deployment and the speaker DaemonSet.Lines to be deleted:
securityContext: runAsNonRoot: true runAsUser: 65534
Create the
metallb-systemnamespace.[netapp-user@rhel7 ~]$ oc create -f namespace.yaml namespace/metallb-system created
Create the MetalLB CR.
[netapp-user@rhel7 ~]$ oc create -f metallb.yaml podsecuritypolicy.policy/controller created podsecuritypolicy.policy/speaker created serviceaccount/controller created serviceaccount/speaker created clusterrole.rbac.authorization.k8s.io/metallb-system:controller created clusterrole.rbac.authorization.k8s.io/metallb-system:speaker created role.rbac.authorization.k8s.io/config-watcher created role.rbac.authorization.k8s.io/pod-lister created role.rbac.authorization.k8s.io/controller created clusterrolebinding.rbac.authorization.k8s.io/metallb-system:controller created clusterrolebinding.rbac.authorization.k8s.io/metallb-system:speaker created rolebinding.rbac.authorization.k8s.io/config-watcher created rolebinding.rbac.authorization.k8s.io/pod-lister created rolebinding.rbac.authorization.k8s.io/controller created daemonset.apps/speaker created deployment.apps/controller created
Before configuring the MetalLB speaker, grant the speaker DaemonSet elevated privileges so that it can perform the networking configuration required to make the load balancers work.
[netapp-user@rhel7 ~]$ oc adm policy add-scc-to-user privileged -n metallb-system -z speaker clusterrole.rbac.authorization.k8s.io/system:openshift:scc:privileged added: "speaker"
Configure MetalLB by creating a
ConfigMapin themetallb-systemnamespace.[netapp-user@rhel7 ~]$ vim metallb-config.yaml apiVersion: v1 kind: ConfigMap metadata: namespace: metallb-system name: config data: config: | address-pools: - name: default protocol: layer2 addresses: - 10.63.17.10-10.63.17.200 [netapp-user@rhel7 ~]$ oc create -f metallb-config.yaml configmap/config created -
Now when loadbalancer services are created, MetalLB assigns an externalIP to the services and advertises the IP address by responding to ARP requests.
If you wish to configure MetalLB in BGP mode, skip step 6 above and follow the procedure in MetalLB BGP mode documentation.
