NetApp container solutions
Scaling: Adding more projects
Contributors banum-netapp kevin-hoke
In a multitenant configuration, adding new projects with storage resources requires additional configuration to make sure that multitenancy is not violated. For adding more projects in a multitenant cluster, complete the following steps:
  1. Log into the NetApp ONTAP cluster as a storage admin.
  2. Navigate to Storage → Storage VMs and click Add. Create a new SVM dedicated to project-3. Also create a vsadmin account to manage the SVM and its resources.
Create SVM for scaling
  1. Log into the Red Hat OpenShift cluster as cluster admin.
  2. Create a new project.
oc create ns project-3
  1. Make sure that the user group for project-3 is created on IdP and synchronized with the OpenShift cluster.
oc get groups
  1. Create the developer role for project-3.
cat << EOF | oc create -f -
apiVersion: rbac.authorization.k8s.io/v1
kind: Role
metadata:
  namespace: project-3
rules:
  - verbs:
    apiGroups:
      - apps
      - batch
      - autoscaling
      - extensions
      - networking.k8s.io
      - policy
      - apps.openshift.io
      - build.openshift.io
      - image.openshift.io
      - ingress.operator.openshift.io
      - route.openshift.io
      - snapshot.storage.k8s.io
      - template.openshift.io
    resources:
  - verbs:
    apiGroups:
    resources:
      - bindings
      - configmaps
      - endpoints
      - events
      - persistentvolumeclaims
      - pods
      - pods/log
      - pods/attach
      - podtemplates
      - replicationcontrollers
      - services
      - limitranges
      - namespaces
      - componentstatuses
      - nodes
  - verbs:
    apiGroups:
      - trident.netapp.io
    resources:
      - tridentsnapshots
EOF
Note The role definition provided in this section is just an example. The developer role must be defined based on the end-user requirements.
  1. Create RoleBinding for developers in project-3 binding the developer-project-3 role to the corresponding group (ocp-project-3) in project-3.
kind: RoleBinding
metadata:
subjects:
  - kind: Group
    apiGroup: rbac.authorization.k8s.io
roleRef:
  kind: Role
EOF
  1. Login to the Red Hat OpenShift cluster as storage admin
  2. Create a Trident backend and map it to the SVM dedicated to project-3. NetApp recommends using the SVM's vsadmin account to connect the backend to the SVM instead of using the ONTAP cluster administrator.
cat << EOF | tridentctl -n trident create backend -f
    "version": 1,
    "storageDriverName": "ontap-nas",
    "backendName": "nfs_project_3",
    "managementLIF": "172.21.224.210",
    "dataLIF": "10.61.181.228",
    "svm": "project-3-svm",
    "username": "vsadmin",
    "password": "NetApp!23"
EOF
Note We are using the ontap-nas driver for this example. Use the appropriate driver for creating the backend based on the use-case.
Note We assume that Trident is installed in the trident project.
  1. Create the storage class for project-3 and configure it to use the storage pools from backend dedicated to project-3.
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
  backendType: ontap-nas
  storagePools: "nfs_project_3:.*"
EOF
  1. Create a ResourceQuota to restrict resources in project-3 requesting storage from storageclasses dedicated to other projects.
kind: ResourceQuota
apiVersion: v1
metadata:
spec:
  hard:
    project-1-sc.storageclass.storage.k8s.io/persistentvolumeclaims: 0
    project-2-sc.storageclass.storage.k8s.io/persistentvolumeclaims: 0
EOF
  1. Patch the ResourceQuotas in other projects to restrict resources in those projects from accessing storage from the storageclass dedicated to project-3.
oc patch resourcequotas project-1-sc-rq -n project-1 --patch '{"spec":{"hard":{ "project-3-sc.storageclass.storage.k8s.io/persistentvolumeclaims": 0}}}'
oc patch resourcequotas project-2-sc-rq -n project-2 --patch '{"spec":{"hard":{ "project-3-sc.storageclass.storage.k8s.io/persistentvolumeclaims": 0}}}'
