Validation
To validate the multitenant architecture that was configured in the previous steps, complete the following steps:
Validate access to create PVCs or pods in assigned project
Log in as ocp-project-1-user, developer in project-1.
Check access to create a new project.
oc create ns sub-project-1
Create a PVC in project-1 using the storageclass that is assigned to project-1.
cat << EOF | oc create -f -
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
namespace: project-1
annotations:
trident.netapp.io/reclaimPolicy: Retain
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
storageClassName: project-1-sc
EOF
Check the PV associated with the PVC.
oc get pv
Validate that the PV and its volume is created in an SVM dedicated to project-1 on NetApp ONTAP.
volume show -vserver project-1-svm
Create a pod in project-1 and mount the PVC created in previous step.
kind: Pod
apiVersion: v1
metadata:
spec:
volumes:
- name: test-pvc-project-1
persistentVolumeClaim:
claimName: test-pvc-project-1
containers:
- name: test-container
image: nginx
ports:
- containerPort: 80
volumeMounts:
- mountPath: "/usr/share/nginx/html"
EOF
Check if the pod is running and whether it mounted the volume.
oc describe pods test-pvc-pod -n project-1
Validate access to create PVCs or pods in another project or use resources dedicated to another project
Create a PVC in project-1 using the storageclass that is assigned to project-2.
apiVersion: v1
metadata:
annotations:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
storageClassName: project-2-sc
EOF
Create a PVC in project-2.
apiVersion: v1
metadata:
namespace: project-2
annotations:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
EOF
Make sure that PVCs
test-pvc-project-1-sc-2andtest-pvc-project-2-sc-1were not created.
oc get pvc -n project-1 oc get pvc -n project-2
Create a pod in project-2.
kind: Pod
apiVersion: v1
metadata:
spec:
containers:
image: nginx
ports:
- containerPort: 80
EOF
Validate access to view and edit Projects, ResourceQuotas, and StorageClasses
Check access to create new projects.
Validate access to view projects.
oc get ns
Check if the user can view or edit ResourceQuotas in project-1.
oc get resourcequotas -n project-1 oc edit resourcequotas project-1-sc-rq -n project-1
Validate that the user has access to view the storageclasses.
oc get sc
Check access to describe the storageclasses.
Validate the user's access to edit the storageclasses.
oc edit sc project-1-sc
