NetApp Element iSCSI configuration
To enable Trident integration with the NetApp Element storage system, you must create a backend that enables communication with the storage system using the iSCSI protocol.
There are sample backend files available in the downloaded installation archive in the
sample-inputfolder hierarchy. For NetApp Element systems serving iSCSI, copy thebackend-solidfire.jsonfile to your working directory and edit the file.[netapp-user@rhel7 trident-installer]$ cp sample-input/backends-samples/solidfire/backend-solidfire.json ./ [netapp-user@rhel7 trident-installer]$ vi ./backend-solidfire.json
Edit the user, password, and MVIP value on the
EndPointline. -
Edit the
SVIPvalue.{ "version": 1, "storageDriverName": "solidfire-san", "Endpoint": "https://trident:password@172.21.224.150/json-rpc/8.0", "SVIP": "10.61.180.200:3260", "TenantName": "trident", "Types": [{"Type": "Bronze", "Qos": {"minIOPS": 1000, "maxIOPS": 2000, "burstIOPS": 4000}}, {"Type": "Silver", "Qos": {"minIOPS": 4000, "maxIOPS": 6000, "burstIOPS": 8000}}, {"Type": "Gold", "Qos": {"minIOPS": 6000, "maxIOPS": 8000, "burstIOPS": 10000}}] }
With this back-end file in place, run the following command to create your first backend.
[netapp-user@rhel7 trident-installer]$ ./tridentctl -n trident create backend -f backend-solidfire.json +-------------------------+----------------+--------------------------------------+--------+---------+ | NAME | STORAGE DRIVER | UUID | STATE | VOLUMES | +-------------------------+----------------+--------------------------------------+--------+---------+ | solidfire_10.61.180.200 | solidfire-san | b90783ee-e0c9-49af-8d26-3ea87ce2efdf | online | 0 | +-------------------------+----------------+--------------------------------------+--------+---------+
With the backend created, you must next create a storage class. Just as with the backend, there is a sample storage class file that can be edited for the environment available in the sample-inputs folder. Copy it to the working directory and make necessary edits to reflect the backend created.
[netapp-user@rhel7 trident-installer]$ cp sample-input/storage-class-samples/storage-class-csi.yaml.templ ./storage-class-basic.yaml [netapp-user@rhel7 trident-installer]$ vi storage-class-basic.yaml
The only edit that must be made to this file is to define the
backendTypevalue to the name of the storage driver from the newly created backend. Also note the name-field value, which must be referenced in a later step.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: basic-csi provisioner: csi.trident.netapp.io parameters: backendType: "solidfire-san"
There is an optional field called fsTypethat is defined in this file. In iSCSI backends, this value can be set to a specific Linux filesystem type (XFS, ext4, and so on), or it can be deleted to allow OpenShift to decide what filesystem to use. -
Run the
occommand to create the storage class.[netapp-user@rhel7 trident-installer]$ oc create -f storage-class-basic.yaml storageclass.storage.k8s.io/basic-csi created
With the storage class created, you must then create the first persistent volume claim (PVC). There is a sample
pvc-basic.yamlfile that can be used to perform this action located in sample-inputs as well.[netapp-user@rhel7 trident-installer]$ cp sample-input/pvc-samples/pvc-basic.yaml ./ [netapp-user@rhel7 trident-installer]$ vi pvc-basic.yaml
The only edit that must be made to this file is ensuring that the
storageClassNamefield matches the one just created. The PVC definition can be further customized as required by the workload to be provisioned.kind: PersistentVolumeClaim apiVersion: v1 metadata: name: basic spec: accessModes: - ReadWriteOnce resources: requests: storage: 1Gi storageClassName: basic-csi -
Create the PVC by issuing the
occommand. Creation can take some time depending on the size of the backing volume being created, so you can watch the process as it completes.[netapp-user@rhel7 trident-installer]$ oc create -f pvc-basic.yaml persistentvolumeclaim/basic created [netapp-user@rhel7 trident-installer]$ oc get pvc NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE basic Bound pvc-3445b5cc-df24-453d-a1e6-b484e874349d 1Gi RWO basic-csi 5s
