Automated Oracle HA/DR in AWS FSx ONTAP
NetApp Solutions Engineering Team
This solution provides an Ansible based automation toolkit for configuring Oracle database High Availability and Disaster Recovery (HA/DR) with AWS FSx ONTAP as Oracle database storage and EC2 instances as the compute instances in AWS.
Purpose
This toolkit automates the tasks of setting up and managing a High Availability and Disaster Recovery (HR/DR) environment for Oracle database deployed in AWS cloud with FSx ONTAP storage and EC2 compute instances.
This solution addresses the following use cases:
Setup HA/DR target host - kernel configuration, Oracle configuration to match up with source server host.
Setup FSx ONTAP - cluster peering, vserver peering, Oracle volumes snapmirror relationship setup from source to target.
Backup Oracle database data via snapshot - execute off crontab
Backup Oracle database archive log via snapshot - execute off crontab
Run failover and recovery on HA/DR host - test and validate HA/DR environment
Run resync after failover test - re-establish database volumes snapmirror relationship in HA/DR mode
Audience
This solution is intended for the following people:
A DBA who set up Oracle database in AWS for high availability, data protection, and disaster recovery.
A database solution architect who is interested in storage level Oracle HA/DR solution in the AWS cloud.
A storage administrator who manages AWS FSx ONTAP storage that supports Oracle databases.
An application owner who like to stand up Oracle database for HA/DR in AWS FSx/EC2 environment.
License
By accessing, downloading, installing or using the content in this GitHub repository, you agree the terms of the License laid out in License file.
There are certain restrictions around producing and/or sharing any derivative works with the content in this GitHub repository. Please make sure you read the terms of the License before using the content. If you do not agree to all of the terms, do not access, download or use the content in this repository. |
Solution deployment
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
Ansible v.2.10 and higher ONTAP collection 21.19.1 Python 3 Python libraries: netapp-lib xmltodict jmespath
AWS FSx storage as is available
AWS EC2 Instance RHEL 7/8, Oracle Linux 7/8 Network interfaces for NFS, public (internet) and optional management Existing Oracle environment on source, and the equivalent Linux operating system at the target
Download the toolkit
Details
git clone https://github.com/NetApp/na_ora_hadr_failover_resync.git
Global variables configuration
Details
The Ansible playbooks are variable driven. An example global variable file fsx_vars_example.yml is included to demonstrate typical configuration. Following are key considerations:
ONTAP - retrieve FSx storage parameters using AWS FSx console for both source and target FSx clusters. cluster name: source/destination cluster management IP: source/destination inter-cluster IP: source/destination vserver name: source/destination vserver management IP: source/destination NFS lifs: source/destination cluster credentials: fsxadmin and vsadmin pwd to be updated in roles/ontap_setup/defaults/main.yml file
Oracle database volumes - they should have been created from AWS FSx console, volume naming should follow strictly with following standard:
Oracle binary: {{ host_name }}_bin, generally one lun/volume
Oracle data: {{ host_name }}_data, can be multiple luns/volume, add additional line for each additional lun/volume in variable such as {{ host_name }}_data_01, {{ host_name }}_data_02 ...
Oracle log: {{ host_name }}_log, can be multiple luns/volume, add additional line for each additional lun/volume in variable such as {{ host_name }}_log_01, {{ host_name }}_log_02 ...
host_name: as defined in hosts file in root directory, the code is written to be specifically matched up with host name defined in host file.
Linux and DB specific global variables - keep it as is. Enter redhat subscription if you have one, otherwise leave it black.
Host variables configuration
Details
Host variables are defined in host_vars directory named as {{ host_name }}.yml. An example host variable file host_name.yml is included to demonstrate typical configuration. Following are key considerations:
Oracle - define host specific variables when deploying Oracle in multiple hosts concurrently ansible_host: IP address of database server host log_archive_mode: enable archive log archiving (true) or not (false) oracle_sid: Oracle instance identifier pdb: Oracle in a container configuration, name pdb_name string and number of pdbs (Oracle allows 3 pdbs free of multitenant license fee) listener_port: Oracle listener port, default 1521 memory_limit: set Oracle SGA size, normally up to 75% RAM host_datastores_nfs: combining of all Oracle volumes (binary, data, and log) as defined in global vars file. If multi luns/volumes, keep exactly the same number of luns/volumes in host_var file
Linux - define host specific variables at Linux level hugepages_nr: set hugepage for large DB with large SGA for performance swap_blocks: add swap space to EC2 instance. If swap exist, it will be ignored.
DB server host file configuration
Details
AWS EC2 instance use IP address for host naming by default. If you use different name in hosts file for Ansible, setup host naming resolution in /etc/hosts file for both source and target servers. Following is an example.
127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4 ::1 localhost localhost.localdomain localhost6 localhost6.localdomain6 172.30.15.96 db1 172.30.15.107 db2
Playbook execution - executed in sequence
Details
Install Ansible controller prerequsites.
ansible-playbook -i hosts requirements.ymlansible-galaxy collection install -r collections/requirements.yml --force -
Setup target EC2 DB instance.
ansible-playbook -i hosts ora_dr_setup.yml -u ec2-user --private-key db2.pem -e @vars/fsx_vars.yml -
Setup FSx ONTAP snapmirror relationship between source and target database volumes.
ansible-playbook -i hosts ontap_setup.yml -u ec2-user --private-key db2.pem -e @vars/fsx_vars.yml -
Backup Oracle database data volumes via snapshot from crontab.
10 * * * * cd /home/admin/na_ora_hadr_failover_resync && /usr/bin/ansible-playbook -i hosts ora_replication_cg.yml -u ec2-user --private-key db1.pem -e @vars/fsx_vars.yml >> logs/snap_data_`date +"%Y-%m%d-%H%M%S"`.log 2>&1 -
Backup Oracle database archive log volumes via snapshot from crontab.
0,20,30,40,50 * * * * cd /home/admin/na_ora_hadr_failover_resync && /usr/bin/ansible-playbook -i hosts ora_replication_logs.yml -u ec2-user --private-key db1.pem -e @vars/fsx_vars.yml >> logs/snap_log_`date +"%Y-%m%d-%H%M%S"`.log 2>&1 -
Run failover and recover Oracle database on target EC2 DB instance - test and validate HA/DR configuration.
ansible-playbook -i hosts ora_recovery.yml -u ec2-user --private-key db2.pem -e @vars/fsx_vars.yml -
Run resync after failover test - re-establish database volumes snapmirror relationship in replication mode.
ansible-playbook -i hosts ontap_ora_resync.yml -u ec2-user --private-key db2.pem -e @vars/fsx_vars.yml
Where to find additional information
To learn more about the NetApp solution automation, review the following website NetApp Solution Automation^
