Automated Oracle Migration
NetApp Solutions Engineering Team
This solution provides an Ansible based automation toolkit for migrating Oracle database using PDB relocation with maximum availability methodology. The migration can be any combinations of on-premises and cloud as either source or target.
Purpose
This toolkit automates Oracle database migration from on-premises to AWS cloud with FSx ONTAP storage and EC2 compute instance as target infrastructure. It assumes the customer already has an on-premises Oracle database deployed in the CDB/PDB model. The toolkit will allow the customer to relocate a named PDB from a container database on an Oracle host using the Oracle PDB relocation procedure with a maximum availability option. That means the source PDB on any on-premises storage array relocates to a new container database with minimal service interruption. The Oracle relocation procedure will move the Oracle data files while database is online. It subsequently reroutes user sessions from on-premises to the relocated database services at the time of switching over when all data files move over to AWS cloud. The underlined technology is proven Oracle PDB hot clone methodology.
Although the migration toolkit is developed and validated on AWS cloud infrastructure, it builds on Oracle application-level solutions. Therefore, the toolkit is applicable to other public cloud platforms, such as Azure, GCP, etc. |
This solution addresses the following use cases:
Create migration user and grant required privileges at on-prem source DB server.
Relocate a PDB from on-premises CDB to a target CDB in cloud while the source PDB is online until switch over.
Audience
This solution is intended for the following people:
A DBA who migrates Oracle databases from on-premisses to AWS cloud.
A database solution architect who is interested in Oracle database migration from on-premisses to AWS cloud.
A storage administrator who manages AWS FSx ONTAP storage that supports Oracle databases.
An application owner who likes to migrate Oracle database from on-premisses to AWS cloud.
License
By accessing, downloading, installing or using the content in this GitHub repository, you agree the terms of the License laid out in License file.
There are certain restrictions around producing and/or sharing any derivative works with the content in this GitHub repository. Please make sure you read the terms of the License before using the content. If you do not agree to all of the terms, do not access, download or use the content in this repository. |
Solution deployment
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
Ansible v.2.10 and higher ONTAP collection 21.19.1 Python 3 Python libraries: netapp-lib xmltodict jmespath
Source Oracle CDB with PDBs on-premises Target Oracle CDB in AWS hosted on FSx and EC2 instance Source and target CDB on same version and with same options installed
Network connectivity Ansible controller to source CDB Ansible controller to target CDB Source CDB to target CDB on Oracle listener port (typical 1521)
Download the toolkit
Details
git clone https://github.com/NetApp/na_ora_aws_migration.git
Host variables configuration
Details
Host variables are defined in host_vars directory named as {{ host_name }}.yml. An example host variable file host_name.yml is included to demonstrate typical configuration. Following are key considerations:
Source Oracle CDB - define host specific variables for the on-prem CDB ansible_host: IP address of source database server host source_oracle_sid: source Oracle CDB instance ID source_pdb_name: source PDB name to migrate to cloud source_file_directory: file directory of source PDB data files target_file_directory: file directory of migrated PDB data files
Target Oracle CDB - define host specific variables for the target CDB including some variables for on-prem CDB ansible_host: IP address of target database server host target_oracle_sid: target Oracle CDB instance ID target_pdb_name: target PDB name to be migrated to cloud (for max availability option, the source and target PDB name must be the same) source_oracle_sid: source Oracle CDB instance ID source_pdb_name: source PDB name to be migrated to cloud source_port: source Oracle CDB listener port source_oracle_domain: source Oracle database domain name source_file_directory: file directory of source PDB data files target_file_directory: file directory of migrated PDB data files
DB server host file configuration
Details
AWS EC2 instance use IP address for host naming by default. If you use different name in hosts file for Ansible, setup host naming resolution in /etc/hosts file for both source and target server. Following is an example.
127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4 ::1 localhost localhost.localdomain localhost6 localhost6.localdomain6 172.30.15.96 source_db_server 172.30.15.107 target_db_server
Playbook execution - executed in sequence
Details
Install Ansible controller prerequisites.
ansible-playbook -i hosts requirements.ymlansible-galaxy collection install -r collections/requirements.yml --force -
Execute pre-migration tasks against on-prem server - assuming admin is ssh user for connection to on-prem Oracle host with sudo permission.
ansible-playbook -i hosts ora_pdb_relocate.yml -u admin -k -K -t ora_pdb_relo_onprem -
Execute Oracle PDB relocation from on-prem CDB to target CDB in AWS EC2 instance - assuming ec2-user for EC2 DB instance connection, and db1.pem with ec2-user ssh key pairs.
ansible-playbook -i hosts ora_pdb_relocate.yml -u ec2-user --private-key db1.pem -t ora_pdb_relo_primary
Where to find additional information
To learn more about the NetApp solution automation, review the following website NetApp Solution Automation^
