Solution Overview
This page describes the Automated method for deploying Oracle19c on NetApp ONTAP storage.
Automated Data Protection for Oracle Databases
Organizations are automating their environments to gain efficiencies, accelerate deployments, and reduce manual effort. Configuration management tools like Ansible are being used to streamline enterprise database operations. In this solution, we demonstrate how you can use Ansible to automate the data protection of Oracle with NetApp ONTAP. By enabling storage administrators, systems administrators, and DBAs to consistently and rapidly setup data replication to an offsite data center or to public cloud, you achieve the following benefits:
Eliminate design complexities and human errors, and implement a repeatable consistent deployment and best practices
Decrease time for configuration of Intercluster replication, CVO instantiation, and recovery of Oracle databases
Increase database administrators, systems and storage administrators productivity
Provides database recovery workflow for ease of testing a DR scenario.
NetApp provides customers with validated Ansible modules and roles to accelerate deployment, configuration, and lifecycle management of your Oracle database environment. This solution provides instruction and Ansible playbook code, to help you:
On Prem to on prem replication
Create intercluster lifs on source and destination
Establish cluster and vserver peering
Create and initialize SnapMirror of Oracle volumes
Create a replication schedule through AWX/Tower for Oracle binaries, databases, and logs
Restore Oracle DB on the destination, and bring database online
On Prem to CVO in AWS
Create AWS connector
Create CVO instance in AWS
Add On-Prem cluster to Cloud Manager
After you are ready, click here for getting started with the solution.
