TR-4974: Oracle 19c in Standalone Restart on AWS FSx/EC2 with NFS/ASM
This solution provides overview and details for Oracle database deployment and protection in AWS FSx ONTAP storage and EC2 compute instance with NFS protocol and Oracle database configured in standalone ReStart using asm as volume manager.
Purpose
ASM (Automatic Storage Management) is a popular Oracle storage volume manager that is employed in many Oracle installations. It is also Oracle's recommended storage management solution. It provides an alternative to conventional volume managers and file systems. Since Oracle version 11g, ASM has been packaged with grid infrastructure rather than a database. As a result, in order to utilize Oracle ASM for storage management without RAC, you must install Oracle grid infrastructure in a standalone server, also known as Oracle Restart. Doing so certainly adds more complexity in an otherwise simpler Oracle database deployment. However, as the name implies, when Oracle is deployed in Restart mode, any failed Oracle services are restarted after a host reboot without user intervention, which provides a certain degree of high availability or HA functionality.
Oracle ASM is generally deployed in FC, iSCSI storage protocols and luns as raw storage devices. However, ASM on NFS protocol and NFS file system is also supported configuration by Oracle. In this documentation, we demonstrate how to deploy an Oracle 19c database with the NFS protocol and Oracle ASM in an Amazon FSx ONTAP storage environment with EC2 compute instances. We also demonstrate how to use the NetApp SnapCenter service through the NetApp BlueXP console to backup, restore, and clone your Oracle database for dev/test or other use cases for storage-efficient database operation in the AWS public cloud.
This solution addresses the following use cases:
Oracle database deployment in Amazon FSx ONTAP storage and EC2 compute instances with NFS/ASM
Testing and validating an Oracle workload in the public AWS cloud with NFS/ASM
Testing and validating Oracle database Restart functionalities deployed in AWS
Audience
This solution is intended for the following people:
A DBA who would like to deploy Oracle in an AWS public cloud with NFS/ASM.
A database solution architect who would like to test Oracle workloads in the AWS public cloud.
The storage administrator who would like to deploy and manage an Oracle database deployed to AWS FSx storage.
The application owner who would like to stand up an Oracle database in AWS FSx/EC2.
Solution test and validation environment
The testing and validation of this solution was performed in an AWS FSx and EC2 environment that might not match the final deployment environment. For more information, see the section Key factors for deployment consideration.
Architecture
Hardware and software components
Hardware |
FSx ONTAP storage |
Current version offered by AWS |
One FSx HA cluster in the same VPC and availability zone |
EC2 instance for compute |
t2.xlarge/4vCPU/16G |
Two EC2 T2 xlarge EC2 instances, one as primary DB server and the other as a clone DB server |
Software |
RedHat Linux |
RHEL-8.6.0_HVM-20220503-x86_64-2-Hourly2-GP2 |
Deployed RedHat subscription for testing |
Oracle Grid Infrastructure |
Version 19.18 |
Applied RU patch p34762026_190000_Linux-x86-64.zip |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
SnapCenter Service |
Version |
v2.3.1.2324 |
EC2 compute instances. In these tests and validations, we used an AWS EC2 t2.xlarge instance type for the Oracle database compute instance. NetApp recommends using an M5 type EC2 instance as the compute instance for Oracle in production deployment because it is optimized for database workloads. You need to size the EC2 instance appropriately for the number of vCPUs and the amount of RAM based on actual workload requirements.
FSx storage HA clusters single- or multi-zone deployment. In these tests and validations, we deployed an FSx HA cluster in a single AWS availability zone. For production deployment, NetApp recommends deploying an FSx HA pair in two different availability zones. An FSx HA cluster is alway provisioned in a HA pair that is sync mirrored in a pair of active-passive file systems to provide storage-level redundancy. Multi-zone deployment further enhances high availability in the event of failure in a single AWS zone.
FSx storage cluster sizing. An Amazon FSx ONTAP storage file system provides up to 160,000 raw SSD IOPS, up to 4GBps throughput, and a maximum of 192TiB capacity. However, you can size the cluster in terms of provisioned IOPS, throughput, and the storage limit (minimum 1,024 GiB) based on your actually requirements at the time of deployment. The capacity can be adjusted dynamically on the fly without affecting application availability.
Oracle data and logs layout. In our tests and validations, we deployed two ASM disk groups for data and logs respectively. Within the +DATA asm disk group, we provisioned four disks in a data NFS file system mount point. Within the +LOGS asm disk group, we provisioned two disks in a logs NFS file system mount point. For large database deployment, ASM disk groups can be built to span multiple FSx file systems with ASM NFS disks distributed through multiple NFS mount points anchored on FSx file systems. This particular setup is designed to meet database throughput over 4GBps throughput and 160,000 raw SSD IOPS requirement.
dNFS configuration. dNFS is built into Oracle kernel and is known to dramatically increase Oracle database performance when Oracle is deployed to NFS storage. dNFS is packaged into Oracle binary but is not turned on by default. It should be turned on for any Oracle database deployment on NFS. For multiple FSx file systems deployment for large database, dNFS multi-path should be properly configured.
Oracle ASM redundancy level to use for each Oracle ASM disk group that you create. Because FSx already mirrors the storage on the FSx cluster level, you should
ONLYuse External Redundancy, which means that the option does not allow Oracle ASM to mirror the contents of the disk group. This is particularly important as NFS for Oracle database data storage requires HARD NFS mount option which is NOT desirable for mirroring ASM contents on the Oracle level. -
Database backup. NetApp provides a SaaS version of SnapCenter software service for database backup, restore, and clone in the cloud that is available through the NetApp BlueXP console UI. NetApp recommends implementing such a service to achieve fast (under a minute) SnapShot backup, quick (few minutes) database restore, and database cloning.
Solution deployment
The following section provides step-by-step deployment procedures.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
An AWS account has been set up, and the necessary VPC and network segments have been created within your AWS account.
From the AWS EC2 console, you must deploy two EC2 Linux instances, one as the primary Oracle DB server and an optional alternative clone target DB server. See the architecture diagram in the previous section for more details about the environment setup. Also review the User Guide for Linux instances for more information.
From the AWS EC2 console, deploy Amazon FSx ONTAP storage HA clusters to host the Oracle database volumes. If you are not familiar with the deployment of FSx storage, see the documentation Creating FSx ONTAP file systems for step-by-step instructions.
Steps 2 and 3 can be performed using the following Terraform automation toolkit, which creates an EC2 instance named
ora_01and an FSx file system namedfsx_01. Review the instruction carefully and change the variables to suit your environment before execution.git clone https://github.com/NetApp-Automation/na_aws_fsx_ec2_deploy.git
Ensure that you have allocated at least 50G in EC2 instance root volume in order to have sufficient space to stage Oracle installation files. |
EC2 instance kernel configuration
Details
With the prerequisites provisioned, log into the EC2 instance as ec2-user and sudo to root user to configure the Linux kernel for Oracle installation.
Create a staging directory
/tmp/archivefolder and set the777permission.mkdir /tmp/archive chmod 777 /tmp/archive
Download and stage the Oracle binary installation files and other required rpm files to the
/tmp/archivedirectory.See the following list of installation files to be stated in
/tmp/archiveon the EC2 instance.[ec2-user@ip-172-30-15-58 ~]$ ls -l /tmp/archive total 10537316 -rw-rw-r--. 1 ec2-user ec2-user 19112 Mar 21 15:57 compat-libcap1-1.10-7.el7.x86_64.rpm -rw-rw-r-- 1 ec2-user ec2-user 3059705302 Mar 21 22:01 LINUX.X64_193000_db_home.zip -rw-rw-r-- 1 ec2-user ec2-user 2889184573 Mar 21 21:09 LINUX.X64_193000_grid_home.zip -rw-rw-r--. 1 ec2-user ec2-user 589145 Mar 21 15:56 netapp_linux_unified_host_utilities-7-1.x86_64.rpm -rw-rw-r--. 1 ec2-user ec2-user 31828 Mar 21 15:55 oracle-database-preinstall-19c-1.0-2.el8.x86_64.rpm -rw-rw-r-- 1 ec2-user ec2-user 2872741741 Mar 21 22:31 p34762026_190000_Linux-x86-64.zip -rw-rw-r-- 1 ec2-user ec2-user 1843577895 Mar 21 22:32 p34765931_190000_Linux-x86-64.zip -rw-rw-r-- 1 ec2-user ec2-user 124347218 Mar 21 22:33 p6880880_190000_Linux-x86-64.zip -rw-r--r-- 1 ec2-user ec2-user 257136 Mar 22 16:25 policycoreutils-python-utils-2.9-9.el8.noarch.rpm
Install Oracle 19c preinstall RPM, which satisfies most kernel configuration requirements.
yum install /tmp/archive/oracle-database-preinstall-19c-1.0-2.el8.x86_64.rpm
Download and install the missing
compat-libcap1in Linux 8.yum install /tmp/archive/compat-libcap1-1.10-7.el7.x86_64.rpm
From NetApp, download and install NetApp host utilities.
yum install /tmp/archive/netapp_linux_unified_host_utilities-7-1.x86_64.rpm
Install
policycoreutils-python-utils, which is not available in the EC2 instance.yum install /tmp/archive/policycoreutils-python-utils-2.9-9.el8.noarch.rpm
Install open JDK version 1.8.
yum install java-1.8.0-openjdk.x86_64
Install nfs-utils.
yum install nfs-utils
Disable transparent hugepages in the current system.
echo never > /sys/kernel/mm/transparent_hugepage/enabled echo never > /sys/kernel/mm/transparent_hugepage/defrag
Add the following lines in
/etc/rc.localto disabletransparent_hugepageafter reboot:# Disable transparent hugepages if test -f /sys/kernel/mm/transparent_hugepage/enabled; then echo never > /sys/kernel/mm/transparent_hugepage/enabled fi if test -f /sys/kernel/mm/transparent_hugepage/defrag; then echo never > /sys/kernel/mm/transparent_hugepage/defrag fi -
Disable selinux by changing
SELINUX=enforcingtoSELINUX=disabled. You must reboot the host to make the change effective.vi /etc/sysconfig/selinux
Add the following lines to
limit.confto set the file descriptor limit and stack size without quotes" ".vi /etc/security/limits.conf "* hard nofile 65536" "* soft stack 10240"
Add swap space to EC2 instance by following this instruction: How do I allocate memory to work as swap space in an Amazon EC2 instance by using a swap file? The exact amount of space to add depends on the size of RAM up to 16G.
Add the ASM group to be used for the asm sysasm group
groupadd asm
Modify the oracle user to add ASM as a secondary group (the oracle user should have been created after Oracle preinstall RPM installation).
usermod -a -G asm oracle
Reboot the EC2 instance.
Provision and export NFS volumes to be mounted to EC2 instance host
Details
Provision three volumes from the command line by login to FSx cluster via ssh as fsxadmin user with FSx cluster management IP to host the Oracle database binary, data, and logs files.
Log into the FSx cluster through SSH as the fsxadmin user.
ssh fsxadmin@172.30.15.53
Execute the following command to create a volume for the Oracle binary.
vol create -volume ora_01_biny -aggregate aggr1 -size 50G -state online -type RW -junction-path /ora_01_biny -snapshot-policy none -tiering-policy snapshot-only
Execute the following command to create a volume for Oracle data.
vol create -volume ora_01_data -aggregate aggr1 -size 100G -state online -type RW -junction-path /ora_01_data -snapshot-policy none -tiering-policy snapshot-only
Execute the following command to create a volume for Oracle logs.
vol create -volume ora_01_logs -aggregate aggr1 -size 100G -state online -type RW -junction-path /ora_01_logs -snapshot-policy none -tiering-policy snapshot-only
Validate the DB volumes created.
vol show
This is expected to return:
FsxId02ad7bf3476b741df::> vol show (vol show) FsxId06c3c8b2a7bd56458::> vol show Vserver Volume Aggregate State Type Size Available Used% --------- ------------ ------------ ---------- ---- ---------- ---------- ----- svm_ora ora_01_biny aggr1 online RW 50GB 47.50GB 0% svm_ora ora_01_data aggr1 online RW 100GB 95.00GB 0% svm_ora ora_01_logs aggr1 online RW 100GB 95.00GB 0% svm_ora svm_ora_root aggr1 online RW 1GB 972.1MB 0% 4 entries were displayed.
Database storage configuration
Details
Now, import and set up the FSx storage for the Oracle grid infrastructure and database installation on the EC2 instance host.
Log into the EC2 instance via SSH as the ec2-user with your SSH key and EC2 instance IP address.
ssh -i ora_01.pem ec2-user@172.30.15.58
Create /u01 directory to mount Oracle binary file system
sudo mkdir /u01
Mount the binary volume to
/u01, changed to your FSx NFS lif IP address. If you deployed FSx cluster via NetApp automation toolkit, FSx virtual storage server NFS lif IP address will be listed in the output at the end of resources provision execution. Otherwise, it can be retrieved from AWS FSx console UI.sudo mount -t nfs 172.30.15.19:/ora_01_biny /u01 -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536
Change
/u01mount point ownership to the Oracle user and it's associated primary group.sudo chown oracle:oinstall /u01
Create /oradata directory to mount Oracle data file system
sudo mkdir /oradata
Mount the data volume to
/oradata, changed to your FSx NFS lif IP addresssudo mount -t nfs 172.30.15.19:/ora_01_data /oradata -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536
Change
/oradatamount point ownership to the Oracle user and it's associated primary group.sudo chown oracle:oinstall /oradata
Create /oralogs directory to mount Oracle logs file system
sudo mkdir /oralogs
Mount the log volume to
/oralogs, changed to your FSx NFS lif IP addresssudo mount -t nfs 172.30.15.19:/ora_01_logs /oralogs -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536
Change
/oralogsmount point ownership to the Oracle user and it's associated primary group.sudo chown oracle:oinstall /oralogs
Add a mount point to
/etc/fstab.sudo vi /etc/fstab
Add the following line.
172.30.15.19:/ora_01_biny /u01 nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0 172.30.15.19:/ora_01_data /oradata nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0 172.30.15.19:/ora_01_logs /oralogs nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0
sudo to oracle user, create asm folders to store asm disk files
sudo su su - oracle mkdir /oradata/asm mkdir /oralogs/asm
As the oracle user, create asm data disk files, change the count to match to the disk size with block size.
dd if=/dev/zero of=/oradata/asm/nfs_data_disk01 bs=1M count=20480 oflag=direct dd if=/dev/zero of=/oradata/asm/nfs_data_disk02 bs=1M count=20480 oflag=direct dd if=/dev/zero of=/oradata/asm/nfs_data_disk03 bs=1M count=20480 oflag=direct dd if=/dev/zero of=/oradata/asm/nfs_data_disk04 bs=1M count=20480 oflag=direct
Change data disk file permission to 640
chmod 640 /oradata/asm/*
AS the oracle user, create asm logs disk files, change to count to match to the disk size with block size.
dd if=/dev/zero of=/oralogs/asm/nfs_logs_disk01 bs=1M count=40960 oflag=direct dd if=/dev/zero of=/oralogs/asm/nfs_logs_disk02 bs=1M count=40960 oflag=direct
Change logs disk file permission to 640
chmod 640 /oralogs/asm/*
Reboot the EC2 instance host.
Oracle grid infrastructure installation
Details
Log into the EC2 instance as the ec2-user via SSH and enable password authentication by uncommenting
PasswordAuthentication yesand then commenting outPasswordAuthentication no.sudo vi /etc/ssh/sshd_config
Restart the sshd service.
sudo systemctl restart sshd
Reset the Oracle user password.
sudo passwd oracle
Log in as the Oracle Restart software owner user (oracle). Create an Oracle directory as follows:
mkdir -p /u01/app/oracle mkdir -p /u01/app/oraInventory
Change the directory permission setting.
chmod -R 775 /u01/app
Create a grid home directory and change to it.
mkdir -p /u01/app/oracle/product/19.0.0/grid cd /u01/app/oracle/product/19.0.0/grid
Unzip the grid installation files.
unzip -q /tmp/archive/LINUX.X64_193000_grid_home.zip
From grid home, delete the
OPatchdirectory.rm -rf OPatch
From grid home, copy
p6880880_190000_Linux-x86-64.zipto the grid_home, and then unzip it.cp /tmp/archive/p6880880_190000_Linux-x86-64.zip . unzip p6880880_190000_Linux-x86-64.zip
From grid home, revise
cv/admin/cvu_config, uncomment and replaceCV_ASSUME_DISTID=OEL5withCV_ASSUME_DISTID=OL7.vi cv/admin/cvu_config
Prepare a
gridsetup.rspfile for silent installation and place the rsp file in the/tmp/archivedirectory. The rsp file should cover sections A, B, and G with the following infomation:INVENTORY_LOCATION=/u01/app/oraInventory oracle.install.option=HA_CONFIG ORACLE_BASE=/u01/app/oracle oracle.install.asm.OSDBA=dba oracle.install.asm.OSOPER=oper oracle.install.asm.OSASM=asm oracle.install.asm.SYSASMPassword="SetPWD" oracle.install.asm.diskGroup.name=DATA oracle.install.asm.diskGroup.redundancy=EXTERNAL oracle.install.asm.diskGroup.AUSize=4 oracle.install.asm.diskGroup.disks=/oradata/asm/nfs_data_disk01,/oradata/asm/nfs_data_disk02,/oradata/asm/nfs_data_disk03,/oradata/asm/nfs_data_disk04 oracle.install.asm.diskGroup.diskDiscoveryString=/oradata/asm/*,/oralogs/asm/* oracle.install.asm.monitorPassword="SetPWD" oracle.install.asm.configureAFD=false
Log into the EC2 instance as the root user.
Install
cvuqdisk-1.0.10-1.rpm.rpm -ivh /u01/app/oracle/product/19.0.0/grid/cv/rpm/cvuqdisk-1.0.10-1.rpm
Log into the EC2 instance as the Oracle user and extract the patch in the
/tmp/archivefolder.unzip p34762026_190000_Linux-x86-64.zip
From grid home /u01/app/oracle/product/19.0.0/grid and as the oracle user, launch
gridSetup.shfor grid infrastructure installation../gridSetup.sh -applyRU /tmp/archive/34762026/ -silent -responseFile /tmp/archive/gridsetup.rsp
Ignore the warnings about wrong groups for grid infrastructure. We are using a single Oracle user to manage Oracle Restart, so this is expected.
As root user, execute the following script(s):
/u01/app/oraInventory/orainstRoot.sh /u01/app/oracle/product/19.0.0/grid/root.sh
As the Oracle user, execute the following command to complete the configuration:
/u01/app/oracle/product/19.0.0/grid/gridSetup.sh -executeConfigTools -responseFile /tmp/archive/gridsetup.rsp -silent
As the Oracle user, create the LOGS disk group.
bin/asmca -silent -sysAsmPassword 'yourPWD' -asmsnmpPassword 'yourPWD' -createDiskGroup -diskGroupName LOGS -disk '/oralogs/asm/nfs_logs_disk*' -redundancy EXTERNAL -au_size 4
As the Oracle user, validate grid services after installation configuration.
bin/crsctl stat res -t + Name Target State Server State details Local Resources ora.DATA.dg ONLINE ONLINE ip-172-30-15-58 STABLE ora.LISTENER.lsnr ONLINE ONLINE ip-172-30-15-58 STABLE ora.LOGS.dg ONLINE ONLINE ip-172-30-15-58 STABLE ora.asm ONLINE ONLINE ip-172-30-15-58 Started,STABLE ora.ons OFFLINE OFFLINE ip-172-30-15-58 STABLE Cluster Resources ora.cssd ONLINE ONLINE ip-172-30-15-58 STABLE ora.diskmon OFFLINE OFFLINE STABLE ora.driver.afd ONLINE ONLINE ip-172-30-15-58 STABLE ora.evmd ONLINE ONLINE ip-172-30-15-58 STABLE
Oracle database installation
Details
Log in as the Oracle user and unset
$ORACLE_HOMEand$ORACLE_SIDif it is set.unset ORACLE_HOME unset ORACLE_SID
Create the Oracle DB home directory and change to it.
mkdir /u01/app/oracle/product/19.0.0/db1 cd /u01/app/oracle/product/19.0.0/db1
Unzip the Oracle DB installation files.
unzip -q /tmp/archive/LINUX.X64_193000_db_home.zip
From the DB home, delete the
From DB home, copy
p6880880_190000_Linux-x86-64.ziptogrid_home, and then unzip it.cp /tmp/archive/p6880880_190000_Linux-x86-64.zip . unzip p6880880_190000_Linux-x86-64.zip
From DB home, revise
cv/admin/cvu_config, and uncomment and replaceCV_ASSUME_DISTID=OEL5withCV_ASSUME_DISTID=OL7.vi cv/admin/cvu_config
From the
/tmp/archivedirectory, unpack the DB 19.18 RU patch.unzip p34765931_190000_Linux-x86-64.zip
Prepare the DB silent install rsp file in
/tmp/archive/dbinstall.rspdirectory with the following values:oracle.install.option=INSTALL_DB_SWONLY UNIX_GROUP_NAME=oinstall INVENTORY_LOCATION=/u01/app/oraInventory ORACLE_HOME=/u01/app/oracle/product/19.0.0/db1 ORACLE_BASE=/u01/app/oracle oracle.install.db.InstallEdition=EE oracle.install.db.OSDBA_GROUP=dba oracle.install.db.OSOPER_GROUP=oper oracle.install.db.OSBACKUPDBA_GROUP=oper oracle.install.db.OSDGDBA_GROUP=dba oracle.install.db.OSKMDBA_GROUP=dba oracle.install.db.OSRACDBA_GROUP=dba oracle.install.db.rootconfig.executeRootScript=false
From db1 home /u01/app/oracle/product/19.0.0/db1, execute silent software-only DB installation.
./runInstaller -applyRU /tmp/archive/34765931/ -silent -ignorePrereqFailure -responseFile /tmp/archive/dbinstall.rsp
As root user, run the
root.shscript after sofware-only installation./u01/app/oracle/product/19.0.0/db1/root.sh
As Oracle user, create the
dbca.rspfile with the following entries:gdbName=db1.demo.netapp.com sid=db1 createAsContainerDatabase=true numberOfPDBs=3 pdbName=db1_pdb useLocalUndoForPDBs=true pdbAdminPassword="yourPWD" templateName=General_Purpose.dbc sysPassword="yourPWD" systemPassword="yourPWD" dbsnmpPassword="yourPWD" storageType=ASM diskGroupName=DATA characterSet=AL32UTF8 nationalCharacterSet=AL16UTF16 listeners=LISTENER databaseType=MULTIPURPOSE automaticMemoryManagement=false totalMemory=8192
Set the total memory based on available memory in EC2 instance host. Oracle allocates 75% of totalMemoryto DB instance SGA or buffer cache. -
As Oracle user, lauch DB creation with dbca.
bin/dbca -silent -createDatabase -responseFile /tmp/archive/dbca.rsp output: Prepare for db operation 7% complete Registering database with Oracle Restart 11% complete Copying database files 33% complete Creating and starting Oracle instance 35% complete 38% complete 42% complete 45% complete 48% complete Completing Database Creation 53% complete 55% complete 56% complete Creating Pluggable Databases 60% complete 64% complete 69% complete 78% complete Executing Post Configuration Actions 100% complete Database creation complete. For details check the logfiles at: /u01/app/oracle/cfgtoollogs/dbca/db1. Database Information: Global Database Name:db1.demo.netapp.com System Identifier(SID):db1 Look at the log file "/u01/app/oracle/cfgtoollogs/dbca/db1/db1.log" for further details.
As Oracle user, validate Oracle Restart HA services after DB creation.
[oracle@ip-172-30-15-58 db1]$ ../grid/bin/crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE ip-172-30-15-58 STABLE ora.LISTENER.lsnr ONLINE ONLINE ip-172-30-15-58 STABLE ora.LOGS.dg ONLINE ONLINE ip-172-30-15-58 STABLE ora.asm ONLINE ONLINE ip-172-30-15-58 Started,STABLE ora.ons OFFLINE OFFLINE ip-172-30-15-58 STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.cssd 1 ONLINE ONLINE ip-172-30-15-58 STABLE ora.db1.db 1 ONLINE ONLINE ip-172-30-15-58 Open,HOME=/u01/app/o racle/product/19.0.0 /db1,STABLE ora.diskmon 1 OFFLINE OFFLINE STABLE ora.evmd 1 ONLINE ONLINE ip-172-30-15-58 STABLE -------------------------------------------------------------------------------- [oracle@ip-172-30-15-58 db1]$ -
Set the Oracle user
.bash_profile.vi ~/.bash_profile
Add following entries:
export ORACLE_HOME=/u01/app/oracle/product/19.0.0/db1 export ORACLE_SID=db1 export PATH=$PATH:$ORACLE_HOME/bin alias asm='export ORACLE_HOME=/u01/app/oracle/product/19.0.0/grid;export ORACLE_SID=+ASM;export PATH=$PATH:$ORACLE_HOME/bin'
Validate the CDB/PDB created.
. ~/.bash_profile sqlplus / as sysdba SQL> select name, open_mode from v$database; NAME OPEN_MODE DB1 READ WRITE SQL> select name from v$datafile; NAME +DATA/DB1/DATAFILE/system.256.1132176177 +DATA/DB1/DATAFILE/sysaux.257.1132176221 +DATA/DB1/DATAFILE/undotbs1.258.1132176247 +DATA/DB1/86B637B62FE07A65E053F706E80A27CA/DATAFILE/system.265.1132177009 +DATA/DB1/86B637B62FE07A65E053F706E80A27CA/DATAFILE/sysaux.266.1132177009 +DATA/DB1/DATAFILE/users.259.1132176247 +DATA/DB1/86B637B62FE07A65E053F706E80A27CA/DATAFILE/undotbs1.267.1132177009 +DATA/DB1/F7852758DCD6B800E0533A0F1EAC1DC6/DATAFILE/system.271.1132177853 +DATA/DB1/F7852758DCD6B800E0533A0F1EAC1DC6/DATAFILE/sysaux.272.1132177853 +DATA/DB1/F7852758DCD6B800E0533A0F1EAC1DC6/DATAFILE/undotbs1.270.1132177853 +DATA/DB1/F7852758DCD6B800E0533A0F1EAC1DC6/DATAFILE/users.274.1132177871 NAME +DATA/DB1/F785288BBCD1BA78E0533A0F1EACCD6F/DATAFILE/system.276.1132177871 +DATA/DB1/F785288BBCD1BA78E0533A0F1EACCD6F/DATAFILE/sysaux.277.1132177871 +DATA/DB1/F785288BBCD1BA78E0533A0F1EACCD6F/DATAFILE/undotbs1.275.1132177871 +DATA/DB1/F785288BBCD1BA78E0533A0F1EACCD6F/DATAFILE/users.279.1132177889 +DATA/DB1/F78529A14DD8BB18E0533A0F1EACB8ED/DATAFILE/system.281.1132177889 +DATA/DB1/F78529A14DD8BB18E0533A0F1EACB8ED/DATAFILE/sysaux.282.1132177889 +DATA/DB1/F78529A14DD8BB18E0533A0F1EACB8ED/DATAFILE/undotbs1.280.1132177889 +DATA/DB1/F78529A14DD8BB18E0533A0F1EACB8ED/DATAFILE/users.284.1132177907 19 rows selected. SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED 2 PDB$SEED READ ONLY NO 3 DB1_PDB1 READ WRITE NO 4 DB1_PDB2 READ WRITE NO 5 DB1_PDB3 READ WRITE NO SQL> -
As oracle user, change to Oracle database home directory /u01/app/oracle/product/19.0.0/db1 and Enable dNFS
cd /u01/app/oracle/product/19.0.0/db1 mkdir rdbms/lib/odm cp lib/libnfsodm19.so rdbms/lib/odm/
Configure oranfstab file in ORACLE_HOME
vi $ORACLE_HOME/dbs/oranfstab add following entries: server: fsx_01 local: 172.30.15.58 path: 172.30.15.19 nfs_version: nfsv3 export: /ora_01_biny mount: /u01 export: /ora_01_data mount: /oradata export: /ora_01_logs mount: /oralogs
As oracle user, login to database from sqlplus and set the DB recovery size and location to the +LOGS disk group.
. ~/.bash_profile sqlplus / as sysdba alter system set db_recovery_file_dest_size = 80G scope=both; alter system set db_recovery_file_dest = '+LOGS' scope=both;
Enable archive log mode and reboot Oracle DB instance
shutdown immediate; startup mount; alter database archivelog; alter database open; alter system switch logfile;
Validate DB log mode and dNFS after instance reboot
SQL> select name, log_mode from v$database; NAME LOG_MODE --------- ------------ DB1 ARCHIVELOG SQL> select svrname, dirname from v$dnfs_servers; SVRNAME -------------------------------------------------------------------------------- DIRNAME -------------------------------------------------------------------------------- fsx_01 /ora_01_data fsx_01 /ora_01_biny fsx_01 /ora_01_logs
Validate Oracle ASM
[oracle@ip-172-30-15-58 db1]$ asm [oracle@ip-172-30-15-58 db1]$ sqlplus / as sysasm SQL*Plus: Release 19.0.0.0.0 - Production on Tue May 9 20:39:39 2023 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> set lin 200 SQL> col path form a30 SQL> select name, path, header_status, mount_status, state from v$asm_disk; NAME PATH HEADER_STATU MOUNT_S STATE ------------------------------ ------------------------------ ------------ ------- -------- DATA_0002 /oradata/asm/nfs_data_disk01 MEMBER CACHED NORMAL DATA_0000 /oradata/asm/nfs_data_disk02 MEMBER CACHED NORMAL DATA_0001 /oradata/asm/nfs_data_disk03 MEMBER CACHED NORMAL DATA_0003 /oradata/asm/nfs_data_disk04 MEMBER CACHED NORMAL LOGS_0000 /oralogs/asm/nfs_logs_disk01 MEMBER CACHED NORMAL LOGS_0001 /oralogs/asm/nfs_logs_disk02 MEMBER CACHED NORMAL 6 rows selected. SQL> select name, state, ALLOCATION_UNIT_SIZE, TOTAL_MB, FREE_MB from v$asm_diskgroup; NAME STATE ALLOCATION_UNIT_SIZE TOTAL_MB FREE_MB ------------------------------ ----------- -------------------- ---------- ---------- DATA MOUNTED 4194304 81920 73536 LOGS MOUNTED 4194304 81920 81640 This completes Oracle 19c version 19.18 Restart deployment on an Amazon FSx ONTAP and EC2 compute instance with NFS/ASM. If desired, NetApp recommends relocating the Oracle control file and online log files to the +LOGS disk group.
Automated deployment option
NetApp will release a fully automated solution deployment toolkit with Ansible to facilitate the implementation of this solution. Please check back for the availability of the toolkit. After it is released, a link will be posted here.
Oracle Database backup, restore, and clone with SnapCenter Service
At this moment, Oracle database with NFS and ASM storage option is only supported by traditional SnapCenter Server UI tool See Hybrid Cloud Database Solutions with SnapCenter for details on Oracle database backup, restore, and clone with NetApp SnapCenter UI tool.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
Installing Oracle Grid Infrastructure for a Standalone Server with a New Database Installation
Installing and Configuring Oracle Database Using Response Files
Amazon FSx ONTAP
Amazon EC2
