TR-4990: Quick Recovery of Oracle VLDB with Incremental Merge on ANF
This solution provides overview and details for quick recovery of Oracle VLDB deployed to Azure VM compute instance with NFS mount on Azure NetApp Files capacity pool to stage a standby database copy that is incrementally merged constantly via RMAN.
Purpose
Recovering a Very Large Database (VLDB) in Oracle using the Oracle Recovery Manager (RMAN) backup tool can be a highly challenging task. The database restoration process from backup media in the event of a failure can be time-consuming, delaying the database recovery and potentially impacting your Service Level Agreement (SLA) significantly. However, starting from version 10g, Oracle introduced a RMAN feature that allows users to create staged image copies of the Oracle database data files on additional disk storage located on the DB server host. These image copies can be incrementally updated using RMAN on a daily basis. In the case of a failure, the Database Administrator (DBA) can swiftly switch the Oracle database from the failed media to the image copy, eliminating the need for a complete database media restore. The result is a greatly improved SLA, albeit at the cost of doubling the required database storage.
If you are keen on SLA for your VLDB and contemplating moving the Oracle database to a public cloud such as Azure, you could set up a similar database protection structure using resources such as Microsoft Azure NetApp Files (ANF) for staging your standby database image copy. In this documentation, we demonstrate how to provision and export an NFS file system from ANF capacity pool to be mounted on an Oracle database server for staging a standby database copy for quick recovery in the event of a primary storage failure.
This solution addresses the following use cases:
An Oracle VLDB image copy incremental merge via RMAN on NFS mount point off Microsoft ANF capacity pool storage.
Quick recovery of an Oracle VLDB in the event of a failure on the same Azure database server VM.
Quick recovery of an Oracle VLDB in the event of a failure on a standby Azure database server VM.
Audience
This solution is intended for the following people:
A DBA who sets up Oracle VLDB image copy incremental merge via RMAN in Azure for faster database recovery.
A database solution architect who tests Oracle workloads in the Azure public cloud.
A storage administrator who manages Oracle databases deployed to ANF capacity pool storage.
An application owner who would like to stand up Oracle databases in Azure cloud environment.
Solution test and validation environment
The testing and validation of this solution was performed in a Microsoft ANF capacity pool storage and Azure VM compute environment that might not match the final deployment environment. For more information, see the section Key factors for deployment consideration.
Architecture
Hardware and software components
Hardware |
ANF storage |
Current version offered by Microsoft |
2 TiB ANF capacity pool storage with Premium service level |
Azure VM for DB server |
Standard_B4ms - 4 vCPUs, 16GiB |
2 VMs, one as primary DB server and the other as a standby |
Software |
RedHat Linux |
RHEL Linux 8.6 (LVM) - x64 Gen2 |
Deployed RedHat subscription for testing |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
NFS |
Version 3.0 |
Oracle dNFS enabled |
Oracle VLDB storage layout for RMAN incremental merge. In our tests and validations, the NFS volume for Oracle incremental backup and merge is allocated from a single ANF capacity pool, which has 100 TiB per volume, and 1000 TiB total capacity limit. For deployment over the thresholds, multiple volumes, and ANF capacity pools can be concatenated in parallel with multiple NFS mount points to provide higher capacity.
Oracle recoverability using RMAN incremental merge. The RMAN incremental backup and merge is generally executed at user defined frequency based on your RTO and RPO objectives. If there are total loss of primary data storage and/or archived logs, the data loss can occur. The Oracle database can be recovered up to last incremental backup that is available from ANF database backup image copy. To minimize the data loss, Oracle flash recovery area can be setup on ANF NFS mount point and archived logs are backed up to ANF NFS mount along with database image copy.
Running Oracle VLDB off ANF NFS file system. Unlike other bulk storage for database backup, Microsoft ANF is a cloud enabled production grade storage that delivers high level of performance and storage efficiency. Once Oracle VLDB switches over from primary storage to image copy on ANF NFS file system, database performance can be maintained at high level while the primary storage failure is addressed. You can take comfort to know that user application experience does not suffer as the result of primary storage failure.
Azure compute instances. In these tests and validations, we used Standard_B4ms Azure VMs as the Oracle database servers. There are other Azure VMs that may be optimized and better suited for database workload. You also need to size the Azure VM appropriately for the number of vCPUs and the amount of RAM based on actual workload requirements.
ANF capacity pool service level. ANF capacity pool offers three service level: Standard, Premium, Ultra. By default, an auto QoS applies to a volume created within a capacity pool, which restricts the throughput on the volume. The throughput on a volume can be manually adjusted based on the size of capacity pool and service level.
dNFS configuration. dNFS is built into Oracle kernel and is known to dramatically increase Oracle database performance when Oracle is deployed to NFS storage. dNFS is packaged into Oracle binary but is not turned on by default. It should be turned on for any Oracle database deployment on NFS. For multiple ANF capacity pools deployment for a VLDB, dNFS multi-paths to different ANF capacity pools storage should be properly configured.
Solution deployment
It is assumed that you already have your Oracle VLDB deployed in Azure cloud environment within a VNet. If you need help on Oracle deployment in Azure, please refer to following technical reports for help.
Your Oracle VLDB can be running either on an ANF storage or any other storage of choices within the Azure cloud ecosystem. The following section provides step-by-step deployment procedures for setting up RMAN incremental merge to an image copy of an Oracle VLDB that is staging in an NFS mount off ANF storage.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
An Azure account has been set up, and the necessary Azure VNet and network segments have been created within your Azure account.
From the Azure portal console, you must deploy two Azure VM instances, one as the primary Oracle DB server and an optional standby DB server. See the architecture diagram in the previous section for more details about the environment setup. Also review the Azure Virtual Machine series for more information.
From the Azure portal console, deploy ANF storage to host the NFS volumes that stores the Oracle database standby image copy. If you are not familiar with the deployment of ANF, see the documentation Quickstart: Set up Azure NetApp Files and create an NFS volume for step-by-step instructions.
Ensure that you have allocated at least 128G in Azure VM root volume in order to have sufficient space to stage Oracle installation files. |
Provision and export NFS volume to be mounted on primary Oracle VLDB server
Details
In this section, we show provisioning an NFS volume from an ANF capacity pool via Azure portal console. Repeat the procedures on other ANF capacity pools if more than one ANF capacity pools are set up to accommodate the size of the database.
First, from Azure portal console, navigating to ANF capacity pool that is used to stage Oracle VLDB image copy.
From selected capacity pool -
database, clickVolumesand then,Add volumeto launch add-volume workflow.
Fill in
Volume name,Quota,Virtual network, andDelegated subnetto move toProtocolpage.
Take a note of the file path, enter allowed clients CIDR range, and enable
Root Accessfor the volume.
Add a volume tag if desired.
Review and create the volume.
Login to primary Oracle VLDB server as a user with sudo privilege and mount the NFS volume exported from ANF storage. Change to your ANF NFS server IP address and file path as necessary. The ANF NFS server IP address can be retrieved from ANF volume console page.
sudo mkdir /nfsanfsudo mount 172.30.136.68:/ora-01-u02-copy /nfsanf -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=262144,wsize=262144,nointr -
Change mount point ownership to oracle:oisntall, change to your oracle user name and primary group as necessary.
sudo chown oracle:oinstall /nfsanf
Setup Oracle RMAN incremental merge to image copy on ANF
Details
RMAN incremental merge update the staging database data files image copy continuously at every incremental backup/merge interval. The image copy of database backup will be as up to date as the frequency you execute the incremental backup/merge. So, take into consideration of database performance, your RTO and RPO objectives when deciding the frequency of RMAN incremental backup and merge.
Login to primary Oracle VLDB server as oracle user.
Create an oracopy directory under mount point /nfsanf to store oracle data files image copies and archlog directory for Oracle flash recovery area.
mkdir /nfsanf/oracopymkdir /nfsanf/archlog -
Login to Oracle database via sqlplus, enable block change tracking for faster incremental backup and change Oracle flash recovery area to ANF NFS mount if it is currently on primary storage. This allows the RMAN default control file/spfile autobackup and archived logs to be backed up to ANF NFS mount for recovery.
sqlplus / as sysdbaFrom sqlplus prompt, execute following command.
alter database enable block change tracking using file '/nfsanf/oracopy/bct_ntap1.ctf'alter system set db_recovery_file_dest='/nfsanf/archlog/' scope=both;Expected output:
[oracle@ora-01 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Wed Mar 20 16:44:21 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> alter database enable block change tracking using file '/nfsanf/oracopy/bct_ntap1.ctf'; Database altered. SQL> alter system set db_recovery_file_dest='/nfsanf/archlog/' scope=both; System altered. SQL>
Create a RMAN backup and incremental merge script. The script allocates multiple channels for parallel RMAN backup and merge. First execution would generate the initial full baseline image copy. In a complete run, it first purges obsolete backups that are outside of retention window to keep staging area clean. It then switches current log file before merge and backup. The incremental backup follows the merge so that the database image copy is trailing current database state by one backup/merge cycle. The merge and backup order can be reversed for quicker recovery at user's preference. The RMAN script can be integrated into a simple shell script to be executed from crontab on the primary DB server. Ensure control file autobackup is on in RMAN setting.
vi /home/oracle/rman_bkup_merge.cmd Add following lines: RUN { allocate channel c1 device type disk format '/nfsanf/oracopy/%U'; allocate channel c2 device type disk format '/nfsanf/oracopy/%U'; allocate channel c3 device type disk format '/nfsanf/oracopy/%U'; allocate channel c4 device type disk format '/nfsanf/oracopy/%U'; delete obsolete; sql 'alter system archive log current'; recover copy of database with tag 'OraCopyBKUPonANF_level_0'; backup incremental level 1 copies=1 for recover of copy with tag 'OraCopyBKUPonANF_level_0' database; } -
At the primary Oracle VLDB server, login to RMAN locally as oracle user with or without RMAN catalog. In this demonstration, we are not connecting to a RMAN catalog.
rman target / nocatalog; output: [oracle@ora-01 ~]$ rman target / nocatalog Recovery Manager: Release 19.0.0.0.0 - Production on Wed Mar 20 16:54:24 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2019, Oracle and/or its affiliates. All rights reserved. connected to target database: NTAP1 (DBID=2441823937) using target database control file instead of recovery catalog
From RMAN prompt, execute the script. First execution creates a baseline database image copy and subsequent executions merge and update the baseline image copy incrementally. The following is how to execute the script and the typical output. Set the number of channels to match the CPU cores on the host.
RMAN> @/home/oracle/rman_bkup_merge.cmd RMAN> RUN 2> { 3> allocate channel c1 device type disk format '/nfsanf/oracopy/%U'; 4> allocate channel c2 device type disk format '/nfsanf/oracopy/%U'; 5> allocate channel c3 device type disk format '/nfsanf/oracopy/%U'; 6> allocate channel c4 device type disk format '/nfsanf/oracopy/%U'; 7> delete obsolete; 8> sql 'alter system archive log current'; 9> recover copy of database with tag 'OraCopyBKUPonANF_level_0'; 10> backup incremental level 1 copies=1 for recover of copy with tag 'OraCopyBKUPonANF_level_0' database; 11> } allocated channel: c1 channel c1: SID=142 device type=DISK allocated channel: c2 channel c2: SID=277 device type=DISK allocated channel: c3 channel c3: SID=414 device type=DISK allocated channel: c4 channel c4: SID=28 device type=DISK RMAN retention policy will be applied to the command RMAN retention policy is set to redundancy 1 Deleting the following obsolete backups and copies: Type Key Completion Time Filename/Handle -------------------- ------ ------------------ -------------------- Backup Set 1 18-MAR-24 Backup Piece 1 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163958359__04h19dgr_.bkp Backup Set 2 18-MAR-24 Backup Piece 2 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163961675__07l1m2lg_.bkp Backup Set 3 18-MAR-24 Backup Piece 3 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163962888__08p6y7lx_.bkp Backup Set 4 18-MAR-24 Backup Piece 4 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163963796__09k8g1m4_.bkp Backup Set 5 18-MAR-24 Backup Piece 5 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163964697__0bd3tqg3_.bkp Backup Set 6 18-MAR-24 Backup Piece 6 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163965895__0chx6mzt_.bkp Backup Set 7 18-MAR-24 Backup Piece 7 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163966806__0dbyx344_.bkp Backup Set 8 18-MAR-24 Backup Piece 8 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163968012__0fgvg805_.bkp Backup Set 9 18-MAR-24 Backup Piece 9 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163968919__0g9x5t1v_.bkp Backup Set 10 18-MAR-24 Backup Piece 10 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163969821__0h4rfdzj_.bkp Backup Set 11 18-MAR-24 Backup Piece 11 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163971026__0j8o4wk8_.bkp Backup Set 12 18-MAR-24 Backup Piece 12 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163971931__0k3pnn2o_.bkp Backup Set 13 18-MAR-24 Backup Piece 13 18-MAR-24 /u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163972835__0kyg92t1_.bkp deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163963796__09k8g1m4_.bkp RECID=4 STAMP=1163963804 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163962888__08p6y7lx_.bkp RECID=3 STAMP=1163962897 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163961675__07l1m2lg_.bkp RECID=2 STAMP=1163961683 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163958359__04h19dgr_.bkp RECID=1 STAMP=1163958361 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163964697__0bd3tqg3_.bkp RECID=5 STAMP=1163964705 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163965895__0chx6mzt_.bkp RECID=6 STAMP=1163965906 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163966806__0dbyx344_.bkp RECID=7 STAMP=1163966814 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163968012__0fgvg805_.bkp RECID=8 STAMP=1163968018 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163968919__0g9x5t1v_.bkp RECID=9 STAMP=1163968926 deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163969821__0h4rfdzj_.bkp RECID=10 STAMP=1163969827 Deleted 3 objects deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163971026__0j8o4wk8_.bkp RECID=11 STAMP=1163971032 Deleted 3 objects deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163971931__0k3pnn2o_.bkp RECID=12 STAMP=1163971938 Deleted 3 objects deleted backup piece backup piece handle=/u03/orareco/NTAP1/autobackup/2024_03_18/o1_mf_s_1163972835__0kyg92t1_.bkp RECID=13 STAMP=1163972837 Deleted 4 objects sql statement: alter system archive log current Starting recover at 20-MAR-24 no copy of datafile 1 found to recover no copy of datafile 3 found to recover no copy of datafile 4 found to recover . . no copy of datafile 31 found to recover no copy of datafile 32 found to recover Finished recover at 20-MAR-24 Starting backup at 20-MAR-24 no parent backup or copy of datafile 1 found no parent backup or copy of datafile 3 found no parent backup or copy of datafile 4 found . . no parent backup or copy of datafile 19 found no parent backup or copy of datafile 20 found channel c1: starting datafile copy input datafile file number=00021 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_01.dbf channel c2: starting datafile copy input datafile file number=00022 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_02.dbf channel c3: starting datafile copy input datafile file number=00023 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_03.dbf channel c4: starting datafile copy input datafile file number=00024 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_04.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_0g2m6brl tag=ORACOPYBKUPONANF_LEVEL_0 RECID=4 STAMP=1164132108 channel c2: datafile copy complete, elapsed time: 01:06:39 channel c2: starting datafile copy input datafile file number=00025 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_05.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_0i2m6brl tag=ORACOPYBKUPONANF_LEVEL_0 RECID=5 STAMP=1164132121 channel c4: datafile copy complete, elapsed time: 01:06:45 channel c4: starting datafile copy input datafile file number=00026 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_06.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_0h2m6brl tag=ORACOPYBKUPONANF_LEVEL_0 RECID=6 STAMP=1164132198 channel c3: datafile copy complete, elapsed time: 01:08:05 channel c3: starting datafile copy input datafile file number=00027 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_07.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_0f2m6brl tag=ORACOPYBKUPONANF_LEVEL_0 RECID=7 STAMP=1164132248 channel c1: datafile copy complete, elapsed time: 01:08:57 channel c1: starting datafile copy input datafile file number=00028 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_08.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_0j2m6fol tag=ORACOPYBKUPONANF_LEVEL_0 RECID=9 STAMP=1164136123 channel c2: datafile copy complete, elapsed time: 01:06:46 channel c2: starting datafile copy input datafile file number=00029 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_09.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_0k2m6fot tag=ORACOPYBKUPONANF_LEVEL_0 RECID=8 STAMP=1164136113 channel c4: datafile copy complete, elapsed time: 01:06:36 channel c4: starting datafile copy input datafile file number=00030 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_10.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_0l2m6frc tag=ORACOPYBKUPONANF_LEVEL_0 RECID=10 STAMP=1164136293 channel c3: datafile copy complete, elapsed time: 01:08:10 channel c3: starting datafile copy input datafile file number=00031 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_11.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_0m2m6fsu tag=ORACOPYBKUPONANF_LEVEL_0 RECID=11 STAMP=1164136333 channel c1: datafile copy complete, elapsed time: 01:07:52 channel c1: starting datafile copy input datafile file number=00032 name=/u02/oradata/NTAP1/NTAP1_pdb1/soe_12.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_0n2m6jlr tag=ORACOPYBKUPONANF_LEVEL_0 RECID=12 STAMP=1164140082 channel c2: datafile copy complete, elapsed time: 01:06:01 channel c2: starting datafile copy input datafile file number=00001 name=/u02/oradata/NTAP1/system01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_0o2m6jlr tag=ORACOPYBKUPONANF_LEVEL_0 RECID=13 STAMP=1164140190 channel c4: datafile copy complete, elapsed time: 01:07:49 channel c4: starting datafile copy input datafile file number=00003 name=/u02/oradata/NTAP1/sysaux01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_0r2m6nhk tag=ORACOPYBKUPONANF_LEVEL_0 RECID=14 STAMP=1164140240 channel c2: datafile copy complete, elapsed time: 00:02:38 channel c2: starting datafile copy input datafile file number=00004 name=/u02/oradata/NTAP1/undotbs01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_0t2m6nml tag=ORACOPYBKUPONANF_LEVEL_0 RECID=15 STAMP=1164140372 channel c2: datafile copy complete, elapsed time: 00:02:15 channel c2: starting datafile copy input datafile file number=00011 name=/u02/oradata/NTAP1/NTAP1_pdb1/undotbs01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_0s2m6nl1 tag=ORACOPYBKUPONANF_LEVEL_0 RECID=16 STAMP=1164140377 channel c4: datafile copy complete, elapsed time: 00:03:01 channel c4: starting datafile copy input datafile file number=00010 name=/u02/oradata/NTAP1/NTAP1_pdb1/sysaux01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_0q2m6jsi tag=ORACOPYBKUPONANF_LEVEL_0 RECID=17 STAMP=1164140385 channel c1: datafile copy complete, elapsed time: 01:07:29 channel c1: starting datafile copy input datafile file number=00014 name=/u02/oradata/NTAP1/NTAP1_pdb2/sysaux01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_0p2m6jrb tag=ORACOPYBKUPONANF_LEVEL_0 RECID=18 STAMP=1164140406 channel c3: datafile copy complete, elapsed time: 01:08:31 channel c3: starting datafile copy input datafile file number=00018 name=/u02/oradata/NTAP1/NTAP1_pdb3/sysaux01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_0v2m6nqs tag=ORACOPYBKUPONANF_LEVEL_0 RECID=19 STAMP=1164140459 channel c4: datafile copy complete, elapsed time: 00:01:26 channel c4: starting datafile copy input datafile file number=00006 name=/u02/oradata/NTAP1/pdbseed/sysaux01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_102m6nr3 tag=ORACOPYBKUPONANF_LEVEL_0 RECID=20 STAMP=1164140468 channel c1: datafile copy complete, elapsed time: 00:01:22 channel c1: starting datafile copy input datafile file number=00009 name=/u02/oradata/NTAP1/NTAP1_pdb1/system01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_0u2m6nqs tag=ORACOPYBKUPONANF_LEVEL_0 RECID=21 STAMP=1164140471 channel c2: datafile copy complete, elapsed time: 00:01:33 channel c2: starting datafile copy input datafile file number=00013 name=/u02/oradata/NTAP1/NTAP1_pdb2/system01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_112m6nrt tag=ORACOPYBKUPONANF_LEVEL_0 RECID=22 STAMP=1164140476 channel c3: datafile copy complete, elapsed time: 00:00:57 channel c3: starting datafile copy input datafile file number=00017 name=/u02/oradata/NTAP1/NTAP1_pdb3/system01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_122m6nti tag=ORACOPYBKUPONANF_LEVEL_0 RECID=23 STAMP=1164140488 channel c4: datafile copy complete, elapsed time: 00:00:25 channel c4: starting datafile copy input datafile file number=00005 name=/u02/oradata/NTAP1/pdbseed/system01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_142m6ntp tag=ORACOPYBKUPONANF_LEVEL_0 RECID=24 STAMP=1164140532 channel c2: datafile copy complete, elapsed time: 00:01:06 channel c2: starting datafile copy input datafile file number=00008 name=/u02/oradata/NTAP1/pdbseed/undotbs01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_152m6nts tag=ORACOPYBKUPONANF_LEVEL_0 RECID=25 STAMP=1164140539 channel c3: datafile copy complete, elapsed time: 00:01:03 channel c3: starting datafile copy input datafile file number=00015 name=/u02/oradata/NTAP1/NTAP1_pdb2/undotbs01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_132m6ntm tag=ORACOPYBKUPONANF_LEVEL_0 RECID=26 STAMP=1164140541 channel c1: datafile copy complete, elapsed time: 00:01:13 channel c1: starting datafile copy input datafile file number=00019 name=/u02/oradata/NTAP1/NTAP1_pdb3/undotbs01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_162m6nuc tag=ORACOPYBKUPONANF_LEVEL_0 RECID=27 STAMP=1164140541 channel c4: datafile copy complete, elapsed time: 00:00:41 channel c4: starting datafile copy input datafile file number=00007 name=/u02/oradata/NTAP1/users01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_172m6nvr tag=ORACOPYBKUPONANF_LEVEL_0 RECID=28 STAMP=1164140552 channel c2: datafile copy complete, elapsed time: 00:00:16 channel c2: starting datafile copy input datafile file number=00012 name=/u02/oradata/NTAP1/NTAP1_pdb1/users01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_182m6nvs tag=ORACOPYBKUPONANF_LEVEL_0 RECID=30 STAMP=1164140561 channel c3: datafile copy complete, elapsed time: 00:00:24 channel c3: starting datafile copy input datafile file number=00016 name=/u02/oradata/NTAP1/NTAP1_pdb2/users01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_1a2m6o01 tag=ORACOPYBKUPONANF_LEVEL_0 RECID=29 STAMP=1164140560 channel c4: datafile copy complete, elapsed time: 00:00:16 channel c4: starting datafile copy input datafile file number=00020 name=/u02/oradata/NTAP1/NTAP1_pdb3/users01.dbf output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_192m6nvv tag=ORACOPYBKUPONANF_LEVEL_0 RECID=31 STAMP=1164140564 channel c1: datafile copy complete, elapsed time: 00:00:21 output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_1b2m6o0e tag=ORACOPYBKUPONANF_LEVEL_0 RECID=32 STAMP=1164140564 channel c2: datafile copy complete, elapsed time: 00:00:02 output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_1c2m6o0k tag=ORACOPYBKUPONANF_LEVEL_0 RECID=34 STAMP=1164140565 channel c3: datafile copy complete, elapsed time: 00:00:01 output file name=/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_1d2m6o0k tag=ORACOPYBKUPONANF_LEVEL_0 RECID=33 STAMP=1164140565 channel c4: datafile copy complete, elapsed time: 00:00:01 Finished backup at 20-MAR-24 Starting Control File and SPFILE Autobackup at 20-MAR-24 piece handle=/nfsanf/archlog/NTAP1/autobackup/2024_03_20/o1_mf_s_1164140565__5g56ypks_.bkp comment=NONE Finished Control File and SPFILE Autobackup at 20-MAR-24 released channel: c1 released channel: c2 released channel: c3 released channel: c4 RMAN> **end-of-file** RMAN> -
List database image copy after backup to observe that a database image copy has been created in ANF NFS mount point.
RMAN> list copy of database tag 'OraCopyBKUPonANF_level_0'; List of Datafile Copies ======================= Key File S Completion Time Ckp SCN Ckp Time Sparse ------- ---- - --------------- ---------- --------------- ------ 14 1 A 20-MAR-24 4161498 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_0r2m6nhk Tag: ORACOPYBKUPONANF_LEVEL_0 16 3 A 20-MAR-24 4161568 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_0s2m6nl1 Tag: ORACOPYBKUPONANF_LEVEL_0 15 4 A 20-MAR-24 4161589 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_0t2m6nml Tag: ORACOPYBKUPONANF_LEVEL_0 27 5 A 20-MAR-24 2379694 18-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_162m6nuc Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 2, PDB Name: PDB$SEED 23 6 A 20-MAR-24 2379694 18-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_122m6nti Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 2, PDB Name: PDB$SEED 29 7 A 20-MAR-24 4161872 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_1a2m6o01 Tag: ORACOPYBKUPONANF_LEVEL_0 28 8 A 20-MAR-24 2379694 18-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_172m6nvr Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 2, PDB Name: PDB$SEED 26 9 A 20-MAR-24 4161835 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_132m6ntm Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 19 10 A 20-MAR-24 4161784 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_0v2m6nqs Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 21 11 A 20-MAR-24 4161780 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_0u2m6nqs Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 32 12 A 20-MAR-24 4161880 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_1b2m6o0e Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 24 13 A 20-MAR-24 4161838 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_142m6ntp Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 20 14 A 20-MAR-24 4161785 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_102m6nr3 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 30 15 A 20-MAR-24 4161863 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_182m6nvs Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 34 16 A 20-MAR-24 4161884 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_1c2m6o0k Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 25 17 A 20-MAR-24 4161841 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_152m6nts Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 22 18 A 20-MAR-24 4161810 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_112m6nrt Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 31 19 A 20-MAR-24 4161869 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_192m6nvv Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 33 20 A 20-MAR-24 4161887 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_1d2m6o0k Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 7 21 A 20-MAR-24 4152514 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_0f2m6brl Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 4 22 A 20-MAR-24 4152518 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_0g2m6brl Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 6 23 A 20-MAR-24 4152522 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_0h2m6brl Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 5 24 A 20-MAR-24 4152529 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_0i2m6brl Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 9 25 A 20-MAR-24 4156120 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_0j2m6fol Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 8 26 A 20-MAR-24 4156130 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_0k2m6fot Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 10 27 A 20-MAR-24 4156159 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_0l2m6frc Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 11 28 A 20-MAR-24 4156183 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_0m2m6fsu Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 12 29 A 20-MAR-24 4158795 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_0n2m6jlr Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 13 30 A 20-MAR-24 4158803 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_0o2m6jlr Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 18 31 A 20-MAR-24 4158871 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_0p2m6jrb Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 17 32 A 20-MAR-24 4158886 20-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_0q2m6jsi Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 -
Report schema from Oracle RMAN command prompt to observe that current VLDB data files are on primary storage.
RMAN> report schema; Report of database schema for database with db_unique_name NTAP1 List of Permanent Datafiles =========================== File Size(MB) Tablespace RB segs Datafile Name ---- -------- -------------------- ------- ------------------------ 1 1060 SYSTEM YES /u02/oradata/NTAP1/system01.dbf 3 1000 SYSAUX NO /u02/oradata/NTAP1/sysaux01.dbf 4 695 UNDOTBS1 YES /u02/oradata/NTAP1/undotbs01.dbf 5 400 PDB$SEED:SYSTEM NO /u02/oradata/NTAP1/pdbseed/system01.dbf 6 440 PDB$SEED:SYSAUX NO /u02/oradata/NTAP1/pdbseed/sysaux01.dbf 7 5 USERS NO /u02/oradata/NTAP1/users01.dbf 8 235 PDB$SEED:UNDOTBS1 NO /u02/oradata/NTAP1/pdbseed/undotbs01.dbf 9 410 NTAP1_PDB1:SYSTEM YES /u02/oradata/NTAP1/NTAP1_pdb1/system01.dbf 10 520 NTAP1_PDB1:SYSAUX NO /u02/oradata/NTAP1/NTAP1_pdb1/sysaux01.dbf 11 580 NTAP1_PDB1:UNDOTBS1 YES /u02/oradata/NTAP1/NTAP1_pdb1/undotbs01.dbf 12 5 NTAP1_PDB1:USERS NO /u02/oradata/NTAP1/NTAP1_pdb1/users01.dbf 13 410 NTAP1_PDB2:SYSTEM YES /u02/oradata/NTAP1/NTAP1_pdb2/system01.dbf 14 500 NTAP1_PDB2:SYSAUX NO /u02/oradata/NTAP1/NTAP1_pdb2/sysaux01.dbf 15 235 NTAP1_PDB2:UNDOTBS1 YES /u02/oradata/NTAP1/NTAP1_pdb2/undotbs01.dbf 16 5 NTAP1_PDB2:USERS NO /u02/oradata/NTAP1/NTAP1_pdb2/users01.dbf 17 410 NTAP1_PDB3:SYSTEM YES /u02/oradata/NTAP1/NTAP1_pdb3/system01.dbf 18 500 NTAP1_PDB3:SYSAUX NO /u02/oradata/NTAP1/NTAP1_pdb3/sysaux01.dbf 19 235 NTAP1_PDB3:UNDOTBS1 YES /u02/oradata/NTAP1/NTAP1_pdb3/undotbs01.dbf 20 5 NTAP1_PDB3:USERS NO /u02/oradata/NTAP1/NTAP1_pdb3/users01.dbf 21 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_01.dbf 22 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_02.dbf 23 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_03.dbf 24 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_04.dbf 25 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_05.dbf 26 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_06.dbf 27 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_07.dbf 28 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_08.dbf 29 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_09.dbf 30 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_10.dbf 31 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_11.dbf 32 31744 NTAP1_PDB1:SOE NO /u02/oradata/NTAP1/NTAP1_pdb1/soe_12.dbf List of Temporary Files ======================= File Size(MB) Tablespace Maxsize(MB) Tempfile Name ---- -------- -------------------- ----------- -------------------- 1 123 TEMP 32767 /u02/oradata/NTAP1/temp01.dbf 2 123 PDB$SEED:TEMP 32767 /u02/oradata/NTAP1/pdbseed/temp012024-03-18_16-07-32-463-PM.dbf 3 31744 NTAP1_PDB1:TEMP 32767 /u02/oradata/NTAP1/NTAP1_pdb1/temp01.dbf 4 123 NTAP1_PDB2:TEMP 32767 /u02/oradata/NTAP1/NTAP1_pdb2/temp01.dbf 5 123 NTAP1_PDB3:TEMP 32767 /u02/oradata/NTAP1/NTAP1_pdb3/temp01.dbf 6 31744 NTAP1_PDB1:TEMP 31744 /u02/oradata/NTAP1/NTAP1_pdb1/temp02.dbf RMAN>
Validate database image copy from OS NFS mount point.
[oracle@ora-01 ~]$ ls -l /nfsanf/oracopy total 399482176 -rw-r----- 1 oracle oinstall 11600384 Mar 20 21:44 bct_ntap1.ctf -rw-r----- 1 oracle oinstall 33286004736 Mar 20 18:03 data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_0f2m6brl -rw-r----- 1 oracle oinstall 33286004736 Mar 20 18:01 data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_0g2m6brl -rw-r----- 1 oracle oinstall 33286004736 Mar 20 18:03 data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_0h2m6brl -rw-r----- 1 oracle oinstall 33286004736 Mar 20 18:02 data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_0i2m6brl -rw-r----- 1 oracle oinstall 33286004736 Mar 20 19:08 data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_0j2m6fol -rw-r----- 1 oracle oinstall 33286004736 Mar 20 19:08 data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_0k2m6fot -rw-r----- 1 oracle oinstall 33286004736 Mar 20 19:11 data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_0l2m6frc -rw-r----- 1 oracle oinstall 33286004736 Mar 20 19:12 data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_0m2m6fsu -rw-r----- 1 oracle oinstall 33286004736 Mar 20 20:14 data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_0n2m6jlr -rw-r----- 1 oracle oinstall 33286004736 Mar 20 20:16 data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_0o2m6jlr -rw-r----- 1 oracle oinstall 33286004736 Mar 20 20:20 data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_0p2m6jrb -rw-r----- 1 oracle oinstall 33286004736 Mar 20 20:19 data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_0q2m6jsi -rw-r----- 1 oracle oinstall 545267712 Mar 20 20:20 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_0v2m6nqs -rw-r----- 1 oracle oinstall 524296192 Mar 20 20:21 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_102m6nr3 -rw-r----- 1 oracle oinstall 524296192 Mar 20 20:21 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_112m6nrt -rw-r----- 1 oracle oinstall 1048584192 Mar 20 20:19 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_0s2m6nl1 -rw-r----- 1 oracle oinstall 461381632 Mar 20 20:21 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_122m6nti -rw-r----- 1 oracle oinstall 1111498752 Mar 20 20:17 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_0r2m6nhk -rw-r----- 1 oracle oinstall 429924352 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_142m6ntp -rw-r----- 1 oracle oinstall 429924352 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_152m6nts -rw-r----- 1 oracle oinstall 419438592 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_162m6nuc -rw-r----- 1 oracle oinstall 429924352 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_132m6ntm -rw-r----- 1 oracle oinstall 608182272 Mar 20 20:21 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_0u2m6nqs -rw-r----- 1 oracle oinstall 246423552 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_182m6nvs -rw-r----- 1 oracle oinstall 246423552 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_192m6nvv -rw-r----- 1 oracle oinstall 728768512 Mar 20 20:19 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_0t2m6nml -rw-r----- 1 oracle oinstall 246423552 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_172m6nvr -rw-r----- 1 oracle oinstall 5251072 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_1b2m6o0e -rw-r----- 1 oracle oinstall 5251072 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_1c2m6o0k -rw-r----- 1 oracle oinstall 5251072 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_1d2m6o0k -rw-r----- 1 oracle oinstall 5251072 Mar 20 20:22 data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_1a2m6o01 [oracle@ora-01 ~]$
This completes the setup of an Oracle VLDB standby image copy backup and merge.
Switch Oracle VLDB to image copy for quick recovery
Details
In the event of a failure due to primary storage issue such as data loss or corruption, database can be quickly switched over to image copy on ANF NFS mount and recovered to current state without database restore. Eliminating media restoration speeds up the database recovery tremendously for a VLDB. This use case assumes that the Oracle VLDB DB server is intact and database control file, archived and current logs are all available for recovery.
Login to Azure primary VLDB server host as oracle user and create a test table before switch over.
[oracle@ora-01 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Thu Mar 21 15:13:52 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP1_PDB1 READ WRITE NO 4 NTAP1_PDB2 READ WRITE NO 5 NTAP1_PDB3 READ WRITE NO SQL> alter session set container=ntap1_pdb1; Session altered. SQL> create table test (id integer, dt timestamp, event varchar(100)); Table created. SQL> insert into test values(1, sysdate, 'test oracle incremental merge switch to copy'); 1 row created. SQL> commit; Commit complete. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 21-MAR-24 03.15.03.000000 PM test oracle incremental merge switch to copy -
Simulate a failure by shutdown abort database, then start up oracle in mount stage.
SQL> shutdown abort; ORACLE instance shut down. SQL> startup mount; ORACLE instance started. Total System Global Area 6442449688 bytes Fixed Size 9177880 bytes Variable Size 1325400064 bytes Database Buffers 5100273664 bytes Redo Buffers 7598080 bytes Database mounted. SQL> exit
As oracle user, connect to Oracle database via RMAN to switch database to copy.
[oracle@ora-01 ~]$ rman target / nocatalog Recovery Manager: Release 19.0.0.0.0 - Production on Thu Mar 21 15:20:58 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2019, Oracle and/or its affiliates. All rights reserved. connected to target database: NTAP1 (DBID=2441823937, not open) using target database control file instead of recovery catalog RMAN> switch database to copy; datafile 1 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_0r2m6nhk" datafile 3 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_0s2m6nl1" datafile 4 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_0t2m6nml" datafile 5 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_162m6nuc" datafile 6 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_122m6nti" datafile 7 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_1a2m6o01" datafile 8 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_172m6nvr" datafile 9 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_132m6ntm" datafile 10 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_0v2m6nqs" datafile 11 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_0u2m6nqs" datafile 12 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_1b2m6o0e" datafile 13 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_142m6ntp" datafile 14 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_102m6nr3" datafile 15 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_182m6nvs" datafile 16 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_1c2m6o0k" datafile 17 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_152m6nts" datafile 18 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_112m6nrt" datafile 19 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_192m6nvv" datafile 20 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_1d2m6o0k" datafile 21 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_0f2m6brl" datafile 22 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_0g2m6brl" datafile 23 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_0h2m6brl" datafile 24 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_0i2m6brl" datafile 25 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_0j2m6fol" datafile 26 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_0k2m6fot" datafile 27 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_0l2m6frc" datafile 28 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_0m2m6fsu" datafile 29 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_0n2m6jlr" datafile 30 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_0o2m6jlr" datafile 31 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_0p2m6jrb" datafile 32 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_0q2m6jsi"
Recover and open database to bring it up to current from last incremental backup.
RMAN> recover database; Starting recover at 21-MAR-24 allocated channel: ORA_DISK_1 channel ORA_DISK_1: SID=392 device type=DISK channel ORA_DISK_1: starting incremental datafile backup set restore channel ORA_DISK_1: specifying datafile(s) to restore from backup set destination for restore of datafile 00009: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_0q1sd7cm destination for restore of datafile 00023: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_041sd6s5 destination for restore of datafile 00027: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_081sd70i destination for restore of datafile 00031: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_0c1sd74u destination for restore of datafile 00034: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-34_0f1sd788 channel ORA_DISK_1: reading from backup piece /nfsanf/oracopy/321sfous_98_1_1 channel ORA_DISK_1: piece handle=/nfsanf/oracopy/321sfous_98_1_1 tag=ORACOPYBKUPONANF_LEVEL_0 channel ORA_DISK_1: restored backup piece 1 channel ORA_DISK_1: restore complete, elapsed time: 00:00:01 channel ORA_DISK_1: starting incremental datafile backup set restore channel ORA_DISK_1: specifying datafile(s) to restore from backup set destination for restore of datafile 00010: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_0k1sd7bb destination for restore of datafile 00021: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_021sd6pv destination for restore of datafile 00025: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_061sd6uc . . . channel ORA_DISK_1: starting incremental datafile backup set restore channel ORA_DISK_1: specifying datafile(s) to restore from backup set destination for restore of datafile 00016: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_121sd7dn channel ORA_DISK_1: reading from backup piece /nfsanf/oracopy/3i1sfov0_114_1_1 channel ORA_DISK_1: piece handle=/nfsanf/oracopy/3i1sfov0_114_1_1 tag=ORACOPYBKUPONANF_LEVEL_0 channel ORA_DISK_1: restored backup piece 1 channel ORA_DISK_1: restore complete, elapsed time: 00:00:01 channel ORA_DISK_1: starting incremental datafile backup set restore channel ORA_DISK_1: specifying datafile(s) to restore from backup set destination for restore of datafile 00020: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_131sd7do channel ORA_DISK_1: reading from backup piece /nfsanf/oracopy/3j1sfov0_115_1_1 channel ORA_DISK_1: piece handle=/nfsanf/oracopy/3j1sfov0_115_1_1 tag=ORACOPYBKUPONANF_LEVEL_0 channel ORA_DISK_1: restored backup piece 1 channel ORA_DISK_1: restore complete, elapsed time: 00:00:01 starting media recovery media recovery complete, elapsed time: 00:00:01 Finished recover at 21-MAR-24 RMAN> alter database open; Statement processed RMAN>
Check database structure from sqlplus after recovery to observe that all VLDB data files with exception of control, temp, and current log files are now switched over to copy on ANF NFS file system.
SQL> select name from v$datafile 2 union 3 select name from v$tempfile 4 union 5 select name from v$controlfile 6 union 7* select member from v$logfile SQL> / NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_0f2m6brl /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_0g2m6brl /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_0h2m6brl /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_0i2m6brl /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_0j2m6fol /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_0k2m6fot /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_0l2m6frc /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_0m2m6fsu /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_0n2m6jlr /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_0o2m6jlr /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_0p2m6jrb NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_0q2m6jsi /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_0v2m6nqs /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_102m6nr3 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_112m6nrt /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_0s2m6nl1 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_122m6nti /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_142m6ntp /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_152m6nts /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_0r2m6nhk /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_162m6nuc /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_132m6ntm NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_0u2m6nqs /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_182m6nvs /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_192m6nvv /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_0t2m6nml /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_172m6nvr /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_1b2m6o0e /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_1c2m6o0k /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_1d2m6o0k /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_1a2m6o01 /u02/oradata/NTAP1/NTAP1_pdb1/temp01.dbf /u02/oradata/NTAP1/NTAP1_pdb1/temp02.dbf NAME -------------------------------------------------------------------------------- /u02/oradata/NTAP1/NTAP1_pdb2/temp01.dbf /u02/oradata/NTAP1/NTAP1_pdb3/temp01.dbf /u02/oradata/NTAP1/control01.ctl /u02/oradata/NTAP1/pdbseed/temp012024-03-18_16-07-32-463-PM.dbf /u02/oradata/NTAP1/temp01.dbf /u03/orareco/NTAP1/control02.ctl /u03/orareco/NTAP1/onlinelog/redo01.log /u03/orareco/NTAP1/onlinelog/redo02.log /u03/orareco/NTAP1/onlinelog/redo03.log 42 rows selected.
From SQL plus, check the content of test table we have inserted before the switch over to copy.
SQL> alter session set container=ntap1_pdb1; Session altered. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 21-MAR-24 03.15.03.000000 PM test oracle incremental merge switch to copy SQL> -
You could run the Oracle VLDB in ANF NFS mount for an extended period of time while maintaining expected performance level. When the primary storage issue is fixed, you can swing back to it by reversing the incremental backup merge processes with minimal downtime.
Oracle VLDB recovery from image copy to a standby DB server
Details
In the event of a failure where both the primary storage and primary DB server host are lost, recovery cannot be performed from the original server. However, your Oracle database backup image copy available on the ANF NFS file system comes in handy. You can quickly recover the primary database to a standby DB server if one is available, using the backup image copy. In this section, we will demonstrate the step-by-step procedures for such recovery.
Insert a row to test table we have created previously for Oracle VLDB restoring to alternative host validation.
SQL> insert into test values(2, sysdate, 'test recovery on a new Azure VM host with image copy on ANF'); 1 row created. SQL> commit; Commit complete. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 21-MAR-24 03.15.03.000000 PM test oracle incremental merge switch to copy 2 22-MAR-24 02.22.06.000000 PM test recovery on a new Azure VM host with image copy on ANF ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- SQL> -
As oracle user, run RMAN incremental backup and merge to flush the transaction to backup set on ANF NFS mount.
[oracle@ip-172-30-15-99 ~]$ rman target / nocatalog Recovery Manager: Release 19.0.0.0.0 - Production on Tue May 30 17:26:03 2023 Version 19.18.0.0.0 Copyright (c) 1982, 2019, Oracle and/or its affiliates. All rights reserved. connected to target database: NTAP1 (DBID=2441823937) using target database control file instead of recovery catalog RMAN> @rman_bkup_merge.cmd
Shutdown primary VLDB server host to simulate a total failure of storage and DB server host.
On the standby DB server ora-02 with same OS and version, OS kernal should be patched up as primary VLDB server host. Also, the same version and patches of Oracle has been installed and configured on standby DB server with software only option.
Configure oracle environment similiarly to primary VLDB server ora_01, such as oratab, and oracle user .bash_profile etc. It is a good practice to backup those files to ANF NFS mount point.
The Oracle database backup image copy on ANF NFS file system is then mounted on the standby DB server for recovery. The following procedures demonstrate the process details.
As azueruser, create the mount point.
sudo mkdir /nfsanfAs azureuser, mount the NFS volume that stored Oracle VLDB backup image copy.
Validate the Oracle database backup image copy on ANF NFS mount point.
[oracle@ora-02 ~]$ ls -ltr /nfsanf/oracopy/ total 400452728 -rw-r-----. 1 oracle oinstall 461381632 Mar 21 23:47 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_242m9oan -rw-r-----. 1 oracle oinstall 419438592 Mar 21 23:49 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_282m9oem -rw-r-----. 1 oracle oinstall 246423552 Mar 21 23:49 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_292m9oem -rw-r-----. 1 oracle oinstall 21438464 Mar 22 14:35 2h2mbccv_81_1_1 -rw-r-----. 1 oracle oinstall 17956864 Mar 22 14:35 2i2mbcd0_82_1_1 -rw-r-----. 1 oracle oinstall 17956864 Mar 22 14:35 2j2mbcd1_83_1_1 -rw-r-----. 1 oracle oinstall 15245312 Mar 22 14:35 2k2mbcd3_84_1_1 -rw-r-----. 1 oracle oinstall 1638400 Mar 22 14:35 2m2mbcdn_86_1_1 -rw-r-----. 1 oracle oinstall 40042496 Mar 22 14:35 2l2mbcdn_85_1_1 -rw-r-----. 1 oracle oinstall 21856256 Mar 22 14:35 2n2mbcdo_87_1_1 -rw-r-----. 1 oracle oinstall 3710976 Mar 22 14:35 2o2mbcdv_88_1_1 -rw-r-----. 1 oracle oinstall 3416064 Mar 22 14:35 2p2mbcdv_89_1_1 -rw-r-----. 1 oracle oinstall 2596864 Mar 22 14:35 2r2mbce0_91_1_1 -rw-r-----. 1 oracle oinstall 2531328 Mar 22 14:35 2s2mbce1_92_1_1 -rw-r-----. 1 oracle oinstall 4718592 Mar 22 14:35 2v2mbce2_95_1_1 -rw-r-----. 1 oracle oinstall 4243456 Mar 22 14:35 302mbce2_96_1_1 -rw-r-----. 1 oracle oinstall 57344 Mar 22 14:35 312mbce3_97_1_1 -rw-r-----. 1 oracle oinstall 57344 Mar 22 14:35 322mbce3_98_1_1 -rw-r-----. 1 oracle oinstall 57344 Mar 22 14:35 332mbce3_99_1_1 -rw-r-----. 1 oracle oinstall 608182272 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_202m9o22 -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_1q2m9k7a -rw-r-----. 1 oracle oinstall 555753472 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_212m9o52 -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_1m2m9g9j -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_1n2m9gcg -rw-r-----. 1 oracle oinstall 429924352 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_252m9oc5 -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_1i2m9cap -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_1j2m9cap -rw-r-----. 1 oracle oinstall 5251072 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_2d2m9ofs -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_1o2m9gd4 -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_1r2m9kfk -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_1p2m9ju6 -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_1s2m9kgg -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_1l2m9g3u -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_1k2m9cap -rw-r-----. 1 oracle oinstall 33286004736 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_1h2m9cap -rw-r-----. 1 oracle oinstall 1121984512 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_1t2m9nij -rw-r-----. 1 oracle oinstall 1142956032 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_1u2m9nog -rw-r-----. 1 oracle oinstall 728768512 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_1v2m9nu6 -rw-r-----. 1 oracle oinstall 534781952 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_222m9o53 -rw-r-----. 1 oracle oinstall 534781952 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_232m9oa8 -rw-r-----. 1 oracle oinstall 429924352 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_262m9oca -rw-r-----. 1 oracle oinstall 246423552 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_2a2m9of6 -rw-r-----. 1 oracle oinstall 429924352 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_272m9oel -rw-r-----. 1 oracle oinstall 5251072 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_2c2m9ofn -rw-r-----. 1 oracle oinstall 5251072 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_2e2m9og8 -rw-r-----. 1 oracle oinstall 246423552 Mar 22 15:31 data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_2b2m9ofn -rw-r-----. 1 oracle oinstall 5251072 Mar 22 15:32 data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_2f2m9og8 -rw-r-----. 1 oracle oinstall 76546048 Mar 22 15:37 362mbft5_102_1_1 -rw-r-----. 1 oracle oinstall 14671872 Mar 22 15:37 392mbg1i_105_1_1 -rw-r-----. 1 oracle oinstall 79462400 Mar 22 15:37 372mbftb_103_1_1 -rw-r-----. 1 oracle oinstall 917504 Mar 22 15:37 3a2mbg23_106_1_1 -rw-r-----. 1 oracle oinstall 428498944 Mar 22 15:37 352mbfst_101_1_1 -rw-r-----. 1 oracle oinstall 88702976 Mar 22 15:37 382mbftm_104_1_1 -rw-r-----. 1 oracle oinstall 5021696 Mar 22 15:37 3b2mbg2b_107_1_1 -rw-r-----. 1 oracle oinstall 278528 Mar 22 15:38 3c2mbg2f_108_1_1 -rw-r-----. 1 oracle oinstall 278528 Mar 22 15:38 3d2mbg2i_109_1_1 -rw-r-----. 1 oracle oinstall 425984 Mar 22 15:38 3f2mbg2m_111_1_1 -rw-r-----. 1 oracle oinstall 442368 Mar 22 15:38 3g2mbg2q_112_1_1 -rw-r-----. 1 oracle oinstall 278528 Mar 22 15:38 3j2mbg37_115_1_1 -rw-r-----. 1 oracle oinstall 270336 Mar 22 15:38 3k2mbg3a_116_1_1 -rw-r-----. 1 oracle oinstall 57344 Mar 22 15:38 3l2mbg3f_117_1_1 -rw-r-----. 1 oracle oinstall 57344 Mar 22 15:38 3n2mbg3k_119_1_1 -rw-r-----. 1 oracle oinstall 57344 Mar 22 15:38 3m2mbg3g_118_1_1 -rw-r-----. 1 oracle oinstall 11600384 Mar 22 15:52 bct_ntap1.ctf [oracle@ora-02 ~]$
Verify the available Oracle archived logs on the ANF NFS mount for recovery and note the last log file log sequency number. In this case, it is 10. Our recovery point is up to log sequency number 11.
[oracle@ora-02 ~]$ ls -ltr /nfsanf/archlog/NTAP1/archivelog/2024_03_22 total 1429548 -r--r-----. 1 oracle oinstall 176650752 Mar 22 12:00 o1_mf_1_2__9m198x6t_.arc -r--r-----. 1 oracle oinstall 17674752 Mar 22 14:34 o1_mf_1_3__9vn701r5_.arc -r--r-----. 1 oracle oinstall 188782080 Mar 22 15:20 o1_mf_1_4__9y6gn5co_.arc -r--r-----. 1 oracle oinstall 183638016 Mar 22 15:21 o1_mf_1_5__9y7p68s6_.arc -r--r-----. 1 oracle oinstall 193106944 Mar 22 15:21 o1_mf_1_6__9y8ygtss_.arc -r--r-----. 1 oracle oinstall 179439104 Mar 22 15:22 o1_mf_1_7__9ybjdp55_.arc -r--r-----. 1 oracle oinstall 198815232 Mar 22 15:23 o1_mf_1_8__9yctxjgy_.arc -r--r-----. 1 oracle oinstall 185494528 Mar 22 15:24 o1_mf_1_9__9yfrj0b1_.arc -r--r-----. 1 oracle oinstall 134470144 Mar 22 15:29 o1_mf_1_10__9yomybbc_.arc [oracle@ora-02 ~]$
As oracle user, set ORACLE_HOME variable to current Oracle installation on standby DB server ora-02, ORACLE_SID to primary Oracle instance SID. In this case, it is NTAP1.
[oracle@ora-02 ~]$ export ORACLE_HOME=/u01/app/oracle/product/19.0.0/NTAP2 [oracle@ora-02 ~]$ export ORACLE_SID=NTAP1 [oracle@ora-02 ~]$ export PATH=$PATH:$ORACLE_HOME/bin
As oracle user, create a generic Oracle init file in $ORACLE_HOME/dbs directory with proper admin directories configured. Most importantly, have Oracle
flash recovery areapoint to ANF NFS mount path as defined in primary Oracle VLDB server.flash recovery areaconfiguration is demonstrated in sectionSetup Oracle RMAN incremental merge to image copy on ANF. Set the Oracle control file to ANF NFS file system.vi $ORACLE_HOME/dbs/initNTAP1.oraWith following example entries:
*.audit_file_dest='/u01/app/oracle/admin/NTAP1/adump' *.audit_trail='db' *.compatible='19.0.0' *.control_files=('/nfsanf/oracopy/NTAP1.ctl') *.db_block_size=8192 *.db_create_file_dest='/nfsanf/oracopy/' *.db_domain='solutions.netapp.com' *.db_name='NTAP1' *.db_recovery_file_dest_size=85899345920 *.db_recovery_file_dest='/nfsanf/archlog/' *.diagnostic_dest='/u01/app/oracle' *.dispatchers='(PROTOCOL=TCP) (SERVICE=NTAP1XDB)' *.enable_pluggable_database=true *.local_listener='LISTENER' *.nls_language='AMERICAN' *.nls_territory='AMERICA' *.open_cursors=300 *.pga_aggregate_target=1024m *.processes=320 *.remote_login_passwordfile='EXCLUSIVE' *.sga_target=10240m *.undo_tablespace='UNDOTBS1'The above init file should be replaced by restored backup init file from primary Oracle VLDB server in the case of discrepancy.
As oracle user, launch RMAN to run Oracle recovery on the standby DB server host. First, start the Oracle instance in
nomountstate.[oracle@ora-02 ~]$ rman target / nocatalog Recovery Manager: Release 19.0.0.0.0 - Production on Fri Mar 22 16:02:55 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2019, Oracle and/or its affiliates. All rights reserved. connected to target database (not started) RMAN> startup nomount; Oracle instance started Total System Global Area 10737418000 bytes Fixed Size 9174800 bytes Variable Size 1577058304 bytes Database Buffers 9126805504 bytes Redo Buffers 24379392 bytes
Set database ID. The database ID can be retrieved from Oracle file name of image copy on ANF NFS mount point.
RMAN> set dbid = 2441823937; executing command: SET DBID
Restore controlfile from autobackup. If Oracle controlfile and spfile autobackup is enabled, they are backed up in every incremental backup and merge cycle. The latest backup will be restored if multiple copies are available.
RMAN> restore controlfile from autobackup; Starting restore at 22-MAR-24 allocated channel: ORA_DISK_1 channel ORA_DISK_1: SID=2 device type=DISK recovery area destination: /nfsanf/archlog/ database name (or database unique name) used for search: NTAP1 channel ORA_DISK_1: AUTOBACKUP /nfsanf/archlog/NTAP1/autobackup/2024_03_22/o1_mf_s_1164296325__9z77zyxb_.bkp found in the recovery area channel ORA_DISK_1: looking for AUTOBACKUP on day: 20240322 channel ORA_DISK_1: restoring control file from AUTOBACKUP /nfsanf/archlog/NTAP1/autobackup/2024_03_22/o1_mf_s_1164296325__9z77zyxb_.bkp channel ORA_DISK_1: control file restore from AUTOBACKUP complete output file name=/nfsanf/oracopy/NTAP1.ctl Finished restore at 22-MAR-24
Restore init file from spfile to a /tmp folder for updating parameter file later to match with primary VLDB.
RMAN> restore spfile to pfile '/tmp/archive/initNTAP1.ora' from autobackup; Starting restore at 22-MAR-24 using channel ORA_DISK_1 recovery area destination: /nfsanf/archlog/ database name (or database unique name) used for search: NTAP1 channel ORA_DISK_1: AUTOBACKUP /nfsanf/archlog/NTAP1/autobackup/2024_03_22/o1_mf_s_1164296325__9z77zyxb_.bkp found in the recovery area channel ORA_DISK_1: looking for AUTOBACKUP on day: 20240322 channel ORA_DISK_1: restoring spfile from AUTOBACKUP /nfsanf/archlog/NTAP1/autobackup/2024_03_22/o1_mf_s_1164296325__9z77zyxb_.bkp channel ORA_DISK_1: SPFILE restore from AUTOBACKUP complete Finished restore at 22-MAR-24
Mount control file and validate the database backup image copy.
RMAN> alter database mount; released channel: ORA_DISK_1 Statement processed RMAN> list copy of database tag 'ORACOPYBKUPONANF_LEVEL_0'; List of Datafile Copies ======================= Key File S Completion Time Ckp SCN Ckp Time Sparse ------- ---- - --------------- ---------- --------------- ------ 82 1 A 22-MAR-24 4598427 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_1t2m9nij Tag: ORACOPYBKUPONANF_LEVEL_0 83 3 A 22-MAR-24 4598423 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_1u2m9nog Tag: ORACOPYBKUPONANF_LEVEL_0 84 4 A 22-MAR-24 4598431 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_1v2m9nu6 Tag: ORACOPYBKUPONANF_LEVEL_0 58 5 A 21-MAR-24 2379694 18-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_282m9oem Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 2, PDB Name: PDB$SEED 52 6 A 21-MAR-24 2379694 18-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_242m9oan Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 2, PDB Name: PDB$SEED 90 7 A 22-MAR-24 4598462 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_2c2m9ofn Tag: ORACOPYBKUPONANF_LEVEL_0 59 8 A 21-MAR-24 2379694 18-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_292m9oem Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 2, PDB Name: PDB$SEED 71 9 A 22-MAR-24 4598313 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_252m9oc5 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 68 10 A 22-MAR-24 4598308 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_212m9o52 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 66 11 A 22-MAR-24 4598304 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_202m9o22 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 74 12 A 22-MAR-24 4598318 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_2d2m9ofs Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 86 13 A 22-MAR-24 4598445 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_262m9oca Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 85 14 A 22-MAR-24 4598437 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_222m9o53 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 87 15 A 22-MAR-24 4598454 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_2a2m9of6 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 89 16 A 22-MAR-24 4598466 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_2e2m9og8 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 4, PDB Name: NTAP1_PDB2 91 17 A 22-MAR-24 4598450 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_272m9oel Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 88 18 A 22-MAR-24 4598441 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_232m9oa8 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 92 19 A 22-MAR-24 4598458 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_2b2m9ofn Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 93 20 A 22-MAR-24 4598470 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_2f2m9og8 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 5, PDB Name: NTAP1_PDB3 81 21 A 22-MAR-24 4598318 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_1h2m9cap Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 72 22 A 22-MAR-24 4598304 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_1i2m9cap Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 73 23 A 22-MAR-24 4598308 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_1j2m9cap Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 80 24 A 22-MAR-24 4598313 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_1k2m9cap Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 79 25 A 22-MAR-24 4598318 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_1l2m9g3u Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 69 26 A 22-MAR-24 4598304 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_1m2m9g9j Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 70 27 A 22-MAR-24 4598308 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_1n2m9gcg Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 75 28 A 22-MAR-24 4598313 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_1o2m9gd4 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 77 29 A 22-MAR-24 4598318 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_1p2m9ju6 Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 67 30 A 22-MAR-24 4598304 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_1q2m9k7a Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 76 31 A 22-MAR-24 4598308 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_1r2m9kfk Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 78 32 A 22-MAR-24 4598313 22-MAR-24 NO Name: /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_1s2m9kgg Tag: ORACOPYBKUPONANF_LEVEL_0 Container ID: 3, PDB Name: NTAP1_PDB1 -
Switch database to copy to run recovery without database restore.
RMAN> switch database to copy; Starting implicit crosscheck backup at 22-MAR-24 allocated channel: ORA_DISK_1 channel ORA_DISK_1: SID=12 device type=DISK Crosschecked 33 objects Finished implicit crosscheck backup at 22-MAR-24 Starting implicit crosscheck copy at 22-MAR-24 using channel ORA_DISK_1 Crosschecked 31 objects Finished implicit crosscheck copy at 22-MAR-24 searching for all files in the recovery area cataloging files... cataloging done List of Cataloged Files ======================= File Name: /nfsanf/archlog/NTAP1/autobackup/2024_03_20/o1_mf_s_1164140565__5g56ypks_.bkp File Name: /nfsanf/archlog/NTAP1/autobackup/2024_03_22/o1_mf_s_1164296325__9z77zyxb_.bkp datafile 1 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_1t2m9nij" datafile 3 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_1u2m9nog" datafile 4 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_1v2m9nu6" datafile 5 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_282m9oem" datafile 6 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_242m9oan" datafile 7 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_2c2m9ofn" datafile 8 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_292m9oem" datafile 9 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_252m9oc5" datafile 10 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_212m9o52" datafile 11 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_202m9o22" datafile 12 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_2d2m9ofs" datafile 13 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_262m9oca" datafile 14 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_222m9o53" datafile 15 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_2a2m9of6" datafile 16 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_2e2m9og8" datafile 17 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_272m9oel" datafile 18 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_232m9oa8" datafile 19 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_2b2m9ofn" datafile 20 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_2f2m9og8" datafile 21 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_1h2m9cap" datafile 22 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_1i2m9cap" datafile 23 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_1j2m9cap" datafile 24 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_1k2m9cap" datafile 25 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_1l2m9g3u" datafile 26 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_1m2m9g9j" datafile 27 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_1n2m9gcg" datafile 28 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_1o2m9gd4" datafile 29 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_1p2m9ju6" datafile 30 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_1q2m9k7a" datafile 31 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_1r2m9kfk" datafile 32 switched to datafile copy "/nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_1s2m9kgg"
Run Oracle recovery up to last available archive log in flash recovery area.
RMAN> run { 2> set until sequence=11; 3> recover database; 4> } executing command: SET until clause Starting recover at 22-MAR-24 using channel ORA_DISK_1 starting media recovery archived log for thread 1 with sequence 4 is already on disk as file /nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_4__9y6gn5co_.arc archived log for thread 1 with sequence 5 is already on disk as file /nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_5__9y7p68s6_.arc archived log for thread 1 with sequence 6 is already on disk as file /nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_6__9y8ygtss_.arc archived log for thread 1 with sequence 7 is already on disk as file /nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_7__9ybjdp55_.arc archived log for thread 1 with sequence 8 is already on disk as file /nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_8__9yctxjgy_.arc archived log for thread 1 with sequence 9 is already on disk as file /nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_9__9yfrj0b1_.arc archived log for thread 1 with sequence 10 is already on disk as file /nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_10__9yomybbc_.arc archived log file name=/nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_4__9y6gn5co_.arc thread=1 sequence=4 archived log file name=/nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_5__9y7p68s6_.arc thread=1 sequence=5 archived log file name=/nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_6__9y8ygtss_.arc thread=1 sequence=6 archived log file name=/nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_7__9ybjdp55_.arc thread=1 sequence=7 archived log file name=/nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_8__9yctxjgy_.arc thread=1 sequence=8 archived log file name=/nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_9__9yfrj0b1_.arc thread=1 sequence=9 archived log file name=/nfsanf/archlog/NTAP1/archivelog/2024_03_22/o1_mf_1_10__9yomybbc_.arc thread=1 sequence=10 media recovery complete, elapsed time: 00:01:17 Finished recover at 22-MAR-24 RMAN> exit Recovery Manager complete.For faster recovery, enable parallel sessions with recovery_parallelism parameter or specify degree of parallel in recovery command for database recovery: RECOVER DATABASE PARALLEL (DEGREE d INSTANCES DEFAULT);. In general, degrees of parallelism should be equal to number of CPU cores on the host. -
Exit RMAN, login to Oracle as oracle user via sqlplus to open database and reset log after an incomplete recovery.
SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- NTAP1 MOUNTED SQL> select instance_name, host_name from v$instance; INSTANCE_NAME ---------------- HOST_NAME ---------------------------------------------------------------- NTAP1 ora-02 SQL> SQL> select member from v$logfile; MEMBER -------------------------------------------------------------------------------- /u03/orareco/NTAP1/onlinelog/redo03.log /u03/orareco/NTAP1/onlinelog/redo02.log /u03/orareco/NTAP1/onlinelog/redo01.log SQL> alter database rename file '/u03/orareco/NTAP1/onlinelog/redo01.log' to '/nfsanf/oracopy/redo01.log'; Database altered. SQL> alter database rename file '/u03/orareco/NTAP1/onlinelog/redo02.log' to '/nfsanf/oracopy/redo02.log'; Database altered. SQL> alter database rename file '/u03/orareco/NTAP1/onlinelog/redo03.log' to '/nfsanf/oracopy/redo03.log'; Database altered. SQL> alter database open resetlogs; Database altered. SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP1_PDB1 READ WRITE NO 4 NTAP1_PDB2 READ WRITE NO 5 NTAP1_PDB3 READ WRITE NO -
Validate the database structure restored to new host as well as the test row we have inserted before primary VLDB failure.
SQL> select name from v$datafile; NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-1_1t2m9nij /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-3_1u2m9nog /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-4_1v2m9nu6 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-5_282m9oem /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-6_242m9oan /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-7_2c2m9ofn /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-8_292m9oem /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-9_252m9oc5 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-10_212m9o52 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-11_202m9o22 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-12_2d2m9ofs NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-13_262m9oca /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-14_222m9o53 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-15_2a2m9of6 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-16_2e2m9og8 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSTEM_FNO-17_272m9oel /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SYSAUX_FNO-18_232m9oa8 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-UNDOTBS1_FNO-19_2b2m9ofn /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-USERS_FNO-20_2f2m9og8 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-21_1h2m9cap /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-22_1i2m9cap /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-23_1j2m9cap NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-24_1k2m9cap /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-25_1l2m9g3u /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-26_1m2m9g9j /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-27_1n2m9gcg /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-28_1o2m9gd4 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-29_1p2m9ju6 /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-30_1q2m9k7a /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-31_1r2m9kfk /nfsanf/oracopy/data_D-NTAP1_I-2441823937_TS-SOE_FNO-32_1s2m9kgg 31 rows selected. SQL> select member from v$logfile; MEMBER -------------------------------------------------------------------------------- /nfsanf/oracopy/redo03.log /nfsanf/oracopy/redo02.log /nfsanf/oracopy/redo01.log SQL> select name from v$controlfile; NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/NTAP1.ctl SQL> alter session set container=ntap1_pdb1; Session altered. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 21-MAR-24 03.15.03.000000 PM test oracle incremental merge switch to copy 2 22-MAR-24 02.22.06.000000 PM test recovery on a new Azure VM host with image copy on ANF -
Drop invalid tempfiles and add new tempfiles to temp tablespaces.
SQL> select name from v$tempfile; NAME -------------------------------------------------------------------------------- /u02/oradata/NTAP1/NTAP1_pdb1/temp01.dbf /u02/oradata/NTAP1/NTAP1_pdb1/temp02.dbf SQL> alter tablespace temp add tempfile '/nfsanf/oracopy/ntap1_pdb1_temp01.dbf' size 100M; Tablespace altered. SQL> select name from v$tempfile; NAME -------------------------------------------------------------------------------- /u02/oradata/NTAP1/NTAP1_pdb1/temp01.dbf /u02/oradata/NTAP1/NTAP1_pdb1/temp02.dbf /nfsanf/oracopy/ntap1_pdb1_temp01.dbf SQL> alter database tempfile '/u02/oradata/NTAP1/NTAP1_pdb1/temp01.dbf' offline; Database altered. SQL> alter database tempfile '/u02/oradata/NTAP1/NTAP1_pdb1/temp01.dbf' drop; Database altered. SQL> alter database tempfile '/u02/oradata/NTAP1/NTAP1_pdb1/temp02.dbf' offline; Database altered. SQL> alter database tempfile '/u02/oradata/NTAP1/NTAP1_pdb1/temp02.dbf' drop; Database altered. SQL> select name from v$tempfile; NAME -------------------------------------------------------------------------------- /nfsanf/oracopy/ntap1_pdb1_temp01.dbf SQL>
Other post recovery tasks
- Add ANF NFS mount to fstab so that the NFS file system will be mounted when DB server host rebooted. As azureuser, sudo vi /etc/fstab and add following entry: 172.30.136.68:/ora-01-u02-copy /nfsanf nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=262144,wsize=262144,nointr 0 0 - Update the Oracle init file from primary databse init file backup that is restored to /tmp/archive and create spfile as needed.
This completes the Oracle VLDB database recovery from backup image copy on ANF NFS file system to a standby DB server host.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
RMAN: Merged Incremental Backup Strategies (Doc ID 745798.1)
RMAN Backup and Recovery User's Guide
Azure NetApp Files
