NetApp data management solutions
CIFS data migration with ACLs from a source storage box to ONTAP
Contributors kevin-hoke
This section covers the step-by-step procedure for migrating CIFS data with security information from a source to a target ONTAP system.
  1. Verify that the target ONTAP system is healthy.
    C1_sti96-vsim-ucs540m_cluster::> cluster show
    Node                  Health  Eligibility
    sti96-vsim-ucs540m    true    true
    sti96-vsim-ucs540n    true    true
    2 entries were displayed.
    C1_sti96-vsim-ucs540m_cluster::> node show
    Node      Health Eligibility Uptime        Model       Owner    Location
    sti96-vsim-ucs540m
              true   true        15 days 21:17 SIMBOX      ahammed  sti
    sti96-vsim-ucs540n
    cluster::>  storage failover show
                                  Takeover
    Node           Partner        Possible State Description
    sti96-vsim-ucs540m
                   sti96-vsim-    true     Connected to sti96-vsim-ucs540n
                   ucs540n
    sti96-vsim-ucs540n
                   sti96-vsim-    true     Connected to sti96-vsim-ucs540m
                   ucs540m
  2. Verify that at least one nonroot aggregate exists on the target system. The aggregate is normal.
    cluster::*> storage aggregate show
    Aggregate     Size Available Used% State   #Vols  Nodes            RAID Status
    aggr0_sti96_vsim_ucs540o
                7.58GB   373.3MB   95% online       1 sti96-vsim-      raid_dp,
                                                      ucs540o          normal
    aggr0_sti96_vsim_ucs540p
                                                      ucs540p          normal
    aggr_001   103.7GB   93.63GB   10% online       1 sti96-vsim-      raid_dp,
                                                      ucs540p          normal
    sti96_vsim_ucs540o_aggr1
               23.93GB   23.83GB    0% online       1 sti96-vsim-      raid_dp,
                                                      ucs540o          normal
    sti96_vsim_ucs540p_aggr1
               23.93GB   23.93GB    0% online       0 sti96-vsim-      raid_dp,
                                                      ucs540p          normal
    5 entries were displayed.
    Note If there is no data aggregate, create a new one using the storage aggr create command.
  3. Create an SVM on the target cluster system.
    cluster::*> vserver create -vserver vs1 -rootvolume root_vs1 -aggregate sti96_vsim_ucs540o_aggr1 -rootvolume-security-style mixed
    Verify that the SVM was successfully created.
    C2_sti96-vsim-ucs540o_cluster::*>  vserver show -vserver vs1
                                        Vserver: vs1
                                   Vserver Type: data
                                Vserver Subtype: default
                                   Vserver UUID: f8bc54be-d91b-11e9-b99c-005056a7e57e
                                    Root Volume: root_vs1
                                      Aggregate: sti96_vsim_ucs540o_aggr1
                                     NIS Domain: NSQA-RTP-NIS1
                     Root Volume Security Style: mixed
                                    LDAP Client: esisconfig
                   Default Volume Language Code: C.UTF-8
                                Snapshot Policy: default
                                  Data Services: data-nfs, data-cifs,
                                                 data-flexcache, data-iscsi
                                        Comment: vs1
                                   Quota Policy: default
                    List of Aggregates Assigned: -
     Limit on Maximum Number of Volumes allowed: unlimited
                            Vserver Admin State: running
                      Vserver Operational State: running
       Vserver Operational State Stopped Reason: -
                              Allowed Protocols: nfs, cifs, fcp, iscsi, ndmp
                           Disallowed Protocols: -
                Is Vserver with Infinite Volume: false
                               QoS Policy Group: -
                            Caching Policy Name: -
                                    Config Lock: false
                 Volume Delete Retention Period: 0
                                   IPspace Name: Default
                             Foreground Process: -
                       Is Msid Preserved for DR: false
    Force start required to start Destination in muliple IDP fan-out case: false
                        Logical Space Reporting: false
                      Logical Space Enforcement: false
  4. Create a new read-write data volume on the destination SVM. Verify that the security style, language settings, and capacity requirements match the source volume.
    CLUSTER CLUSTER::> vol create -vserver vs1 -volume dest_vol -aggregate aggr_001 -size 150g type RW -state online -security-style ntfs
  5. Create a data LIF to serve SMB client requests.
    CLUSTER::> network interface create -vserver vs1 -lif sti96-vsim-ucs540o_data1  -address 10.237.165.87 -netmask 255.255.240.0 -role data -data-protocol nfs,cifs -home-node sti96-vsim-ucs540o  -home-port e0d
    Verify that the LIF was successfully created.
    cluster::*>  network interface show -vserver vs1
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    vs1
                             up/up    10.237.165.87/20   sti96-vsim-ucs540o
        e0d     true
  6. If required, create a static route with the SVM.
    Network route create -vserver dest -destination 0.0.0.0/0 -gateway 10.237.160.1
    Verify that the route was successfully created.
    cluster::*>  network route show -vserver vs1
    Vserver             Destination     Gateway         Metric
    vs1
                        0.0.0.0/0       10.237.160.1    20
                        ::/0            fd20:8b1e:b255:9155::1
                                                        20
  7. Mount the target data volume in the SVM namespace.
    CLUSTER::> volume mount -vserver vs1 -volume dest_vol  -junction-path /dest_vol -active true
    Verify that the volume is successfully mounted.
    cluster::*> volume show -vserver vs1  -fields junction-path
    vserver volume   junction-path
    vs1     dest_vol /dest_vol
    vs1     root_vs1 /
    Note: You can also specify the volume mount options (junction path) with the volume create command.
  8. Start the CIFs service on the target SVM.
    cluster::*> vserver cifs start -vserver vs1
    Warning: The admin status of the CIFS server for Vserver "vs1" is already "up".
    Verify that the service is started and running.
    cluster::*>
    Verify the service is started and running
    C2_sti96-vsim-ucs540o_cluster::*> cifs show
                Server          Status    Domain/Workgroup Authentication
    Vserver     Name            Admin     Name             Style
    vs1         D60AB15C2AFC4D6 up        CTL              domain
  9. Verify that the default export policy is applied to the target SVM.
    CLUSTER::> vserver export-policy show -vserver dest
    Vserver          Policy Name
    dest             default
    If required, create a new custom export policy for the target SVM.
    CLUSTER::> vserver export-policy create -vserver vs1 -policyname xcpexport
  10. Modify the export policy rules to allow access to CIFs clients.
    CLUSTER::> export-policy rule modify -vserver dest -ruleindex 1 -policyname xcpexportpolicy -clientmatch 0.0.0.0/0 -rorule any -rwrule any -anon 0
    Verify that the policy rules are modified.
    cluster::*> export-policy rule show -instance
                                        Vserver: vs1
                                    Policy Name: default
                                     Rule Index: 1
                                Access Protocol: any
    List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 0.0.0.0/0
                                 RO Access Rule: any
                                 RW Access Rule: any
    User ID To Which Anonymous Users Are Mapped: 65534
                       Superuser Security Types: any
                   Honor SetUID Bits in SETATTR: true
                      Allow Creation of Devices: true
                     NTFS Unix Security Options: fail
             Vserver NTFS Unix Security Options: use_export_policy
                          Change Ownership Mode: restricted
                  Vserver Change Ownership Mode: use_export_policy
                                      Policy ID: 12884901889
                                        Vserver: vs1
                                     Rule Index: 2
    List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 0:0:0:0:0:0:0:0/0
                                 RO Access Rule: any
                                 RW Access Rule: any
                       Superuser Security Types: none
  11. Verify that the client is allowed access to the volume.
    cluster::*> export-policy check-access -vserver vs1 -volume dest_vol -client-ip 10.234.17.81 -authentication-method none -protocol cifs -access-type read-write
                                             Policy    Policy       Rule
    Path                          Policy     Owner     Owner Type  Index Access
    /                             default    root_vs1  volume          1 read
    /dest_vol                     default    dest_vol  volume          1 read-write
  12. Connect to the Windows client system where XCP is installed. Browse to the XCP install path.
    C:\WRSHDNT>dir c:\netapp\xcp
    dir c:\netapp\xcp
     Volume in drive C has no label.
     Volume Serial Number is 5C04-C0C7
     Directory of c:\netapp\xcp
    09/18/2019  09:30 AM    <DIR>          .
    09/18/2019  09:30 AM    <DIR>          ..
    06/25/2019  06:27 AM               304 license
    09/18/2019  09:30 AM    <DIR>          Logs
    09/29/2019  08:45 PM        12,143,105 xcp.exe
                   2 File(s)     12,143,409 bytes
                   3 Dir(s)  29,219,549,184 bytes free
  13. Query the source node SMB exports by running the xcp show command on the XCP Windows client host system.
    C:\WRSHDNT>c:\netapp\xcp\xcp show \\10.237.165.71
    XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029
     Shares   Errors   Server
          6        0            10.237.165.71
    == SMB Shares ==
     Space   Space   Current
     Free    Used    Connections Share Path                   Folder Path
     9.50GiB 4.57MiB 1           \\10.237.165.71\source_share C:\source_vol
     94.3MiB 716KiB  0           \\10.237.165.71\ROOTSHARE    C:\
     0       0       N/A         \\10.237.165.71\ipc$         N/A
     94.3MiB 716KiB  0           \\10.237.165.71\c$           C:\
    == Attributes of SMB Shares ==
     Share                             Types                             Remark
     source_share                      DISKTREE
     test share                        DISKTREE
     test_sh                           DISKTREE
     ROOTSHARE                         DISKTREE             \"Share mapped to top of Vserver global namespace, created bydeux_init \"
     ipc$                              PRINTQ,SPECIAL,IPC,DEVICE
     c$                                SPECIAL
    == Permissions of SMB Shares ==
     Share                             Entity                                         Type
     source_share                      Everyone                                       Allow/Full Control
    ROOTSHARE                         Everyone                                       Allow/Full Control
     ipc$                              Everyone                                       Allow/Full Control
     c$                                Administrators                                 Allow/Full Control/
  14. Run the help command for copy.
    C:\WRSHDNT>c:\netapp\xcp\xcp help copy
    usage: xcp copy [-h] [-v] [-parallel <n>] [-match <filter>] [-preserve-atime]
                    [-acl] [-fallback-user FALLBACK_USER]
                    [-fallback-group FALLBACK_GROUP] [-root]
                    source target
    positional arguments:
      source
      target
    optional arguments:
      -h, --help            show this help message and exit
      -v                    increase debug verbosity
      -parallel <n>         number of concurrent processes (default: <cpu-count>)
      -match <filter>       only process files and directories that match the
                            filter (see `xcp help -match` for details)
      -preserve-atime       restore last accessed date on source
      -acl                  copy security information
                            the name of the user on the target machine to receive
                            the permissions of local (non-domain) source machine
                            users (eg. domain\administrator)
                            the name of the group on the target machine to receive
                            groups (eg. domain\administrators)
      -root                 copy acl for root directorytxt
  15. On the target ONTAP system, get the list of local user and local group names that you need to provide as values for the fallback-user and fallback-group arguments path.
    cluster::*> local-user show
      (vserver cifs users-and-groups local-user show)
    Vserver      User Name                   Full Name            Description
    vs1          D60AB15C2AFC4D6\Administrator
        Built-in administrator account
    C2_sti96-vsim-ucs540o_cluster::*>  local-group show
      (vserver cifs users-and-groups local-group show)
    Vserver        Group Name                       Description
    vs1            BUILTIN\Administrators           Built-in Administrators group
    vs1            BUILTIN\Backup Operators         Backup Operators group
    vs1            BUILTIN\Guests                   Built-in Guests Group
    vs1            BUILTIN\Power Users              Restricted administrative privileges
    vs1            BUILTIN\Users                    All users
  16. To migrate the CIFs data with ACLs from the source to target, run the xcp copy command with the -acl and –fallback-user/group options.
    For the fallback-user/group options, specify any user or group that can be found in Active Directory or local user/group to target system.
    C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users  \\10.237.165.79\source_share \\10.237.165.89\dest_share
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 8s
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 13s
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 18s
    ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6".
    ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6".
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 23s
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 28s
    753 scanned, 0 errors, 0 skipped, 249 copied, 24.0KiB (4.82KiB/s), 33s
    753 scanned, 0 errors, 0 skipped, 744 copied, 54.4KiB (6.07KiB/s), 38s
    753 scanned, 0 errors, 0 skipped, 746 copied, 54.5KiB (20/s), 43s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (1.23KiB/s), 44s
    C:\WRSHDNT>
  17. If xcp copy results in the error message ERROR failed to obtain fallback security principal, add the destination box in the hosts file (C:\Windows\System32\drivers\etc\hosts).
    Use the following format for the NetApp storage destination box entry.
    <data vserver data interface ip> 1 or more white spaces <cifs server name>
    C2_sti96-vsim-ucs540o_cluster::*> network interface show
    Cluster
                sti96-vsim-ucs540p_clus1
                             up/up    192.168.148.136/24 sti96-vsim-ucs540p
        e0a     true
                sti96-vsim-ucs540p_clus2
                             up/up    192.168.148.137/24 sti96-vsim-ucs540p
        e0b     true
    vs1
        e0d     true
                sti96-vsim-ucs540o_data1_inet6
                             up/up    fd20:8b1e:b255:9155::583/64
                                                         sti96-vsim-ucs540o
        e0d     true
                sti96-vsim-ucs540o_data2
                             up/up    10.237.165.88/20   sti96-vsim-ucs540o
        e0e     true
    10.237.165.87  D60AB15C2AFC4D6  -> destination box entry to be added in hosts file.
  18. If you still get the error message ERROR failed to obtain fallback security principal after adding the destination box entry in the hosts files, then the user/group does not exist in the target system.
    C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\unknown_user -fallback-group BUILTIN\Users  \\10.237.165.79\source_share \\10.237.165.89\dest_share
    ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6".
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 5s
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 10s
    753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 15s
    753 scanned, 0 errors, 0 skipped, 284 copied, 27.6KiB (5.54KiB/s), 20s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (2.44KiB/s), 22s
    C:\WRSHDNT>
  19. Use xcp copy to migrate CIFs data with ACLs (with or without the root folder).
    Without the root folder, run the following commands:
    753 scanned, 0 errors, 0 skipped, 210 copied, 20.4KiB (4.08KiB/s), 20s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (2.38KiB/s), 22s
    C:\WRSHDNT>
    With the root folder, run the following commands:
    C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -root  -fallback-user  D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users  \\10.237.165.79\source_share \\10.237.165.89\dest_share
    753 scanned, 0 errors, 0 skipped, 243 copied, 23.6KiB (4.73KiB/s), 20s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (6.21KiB/s), 25s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 30s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 35s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 40s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 45s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 50s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 55s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 1m0s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 1m5s
    753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (817/s), 1m8s
    C:\WRSHDNT>
