Block integrity check
SAP recommends combining storage-based Snapshot backups with a weekly file-based backup to execute a block integrity check. SnapCenter supports the execution of a block integrity check by using a policy in which file-based backup is selected as the backup type.
When scheduling backups using this policy, SnapCenter creates a standard SAP HANA file backup for the system and tenant databases.
SnapCenter does not display the block integrity check in the same manner as Snapshot copy-based backups. Instead, the summary card shows the number of file-based backups and the status of the previous backup.
A block integrity check backup cannot be deleted using the SnapCenter UI, but it can be deleted using PowerShell commands.
PS C:\Users\scadmin> Get-SmBackupReport -Resource SS1 SmBackupId : 9 SmJobId : 42 StartDateTime : 11/19/2019 8:26:32 AM EndDateTime : 11/19/2019 8:27:33 AM Duration : 00:01:00.7652030 CreatedDateTime : 11/19/2019 8:27:24 AM Status : Completed ProtectionGroupName : hana-1_sapcc_stl_netapp_com_hana_MDC_SS1 SmProtectionGroupId : 1 PolicyName : BlockIntegrityCheck SmPolicyId : 5 BackupName : SnapCenter_BlockIntegrityCheck_11-19-2019_08.26.33.2913 VerificationStatus : NotApplicable VerificationStatuses : SmJobError : BackupType : SCC_BACKUP CatalogingStatus : NotApplicable CatalogingStatuses : ReportDataCreatedDateTime : PluginCode : SCC PluginName : hana JobTypeId : 0 JobHost : PS C:\Users\scadmin> Remove-SmBackup -BackupIds 9 Remove-SmBackup Are you sure want to remove the backup(s). [Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y BackupResult : {} Result : SMCoreContracts.SMResult TotalCount : 0 DisplayCount : 0 Context : Job : SMCoreContracts.SmJob PS C:\Users\scadmin>
The SAP HANA backup catalog shows entries for both the system and the tenant databases. The following figure shows a SnapCenter block integrity check in the backup catalog of the system database.
A successful block integrity check creates standard SAP HANA data backup files. SnapCenter uses the backup path that has been configured in the HANA database for file-based data backup operations.
hana-1:/usr/sap/SS1/HDB00/backup/data # ls -al * DB_SS1: total 1710840 drwxr-xr-- 2 ss1adm sapsys 4096 Nov 28 10:25 . drwxr-xr-- 4 ss1adm sapsys 4096 Nov 19 05:11 .. -rw-r----- 1 ss1adm sapsys 155648 Nov 23 08:46 SnapCenter_SnapCenter_BlockIntegrityCheck_Weekly_11-23-2019_06.00.07.8397_databackup_0_1 -rw-r----- 1 ss1adm sapsys 83894272 Nov 23 08:46 SnapCenter_SnapCenter_BlockIntegrityCheck_Weekly_11-23-2019_06.00.07.8397_databackup_2_1 -rw-r----- 1 ss1adm sapsys 1660952576 Nov 23 08:46 SnapCenter_SnapCenter_BlockIntegrityCheck_Weekly_11-23-2019_06.00.07.8397_databackup_3_1 SYSTEMDB: total 1546340 drwxr-xr-- 2 ss1adm sapsys 4096 Nov 28 10:24 . drwxr-xr-- 4 ss1adm sapsys 4096 Nov 19 05:11 .. -rw-r----- 1 ss1adm sapsys 159744 Nov 23 08:46 SnapCenter_SnapCenter_BlockIntegrityCheck_Weekly_11-23-2019_06.00.07.8397_databackup_0_1 -rw-r----- 1 ss1adm sapsys 1577066496 Nov 23 08:46 SnapCenter_SnapCenter_BlockIntegrityCheck_Weekly_11-23-2019_06.00.07.8397_databackup_1_1
