NetApp solutions for SAP
Contributors netapp-mschoen
Multiple hosts setup
This chapter describes the setup of a 2+1 SAP HANA multiple host system as example.
LUN configuration for SAP HANA multiple-hosts systems
At the SAP HANA host, volume groups and logical volumes need to be created and mounted, as indicated in the following table.
Logical volume (LV) or volume Mount point at SAP HANA host Note
LV: FC5_data_mnt00001-vol
/hana/data/FC5/mnt00001
Mounted using storage connector
LV: FC5_log_mnt00001-vol
/hana/log/FC5/mnt00001
LV: FC5_data_mnt00002-vol
/hana/data/FC5/mnt00002
LV: FC5_log_mnt00002-vol
/hana/log/FC5/mnt00002
Volume: FC5_shared
/hana/shared
Mounted at all hosts using NFS and /etc/fstab entry
Note With the described configuration, the /usr/sap/FC5 directory in which the default home directory of user FC5adm is stored, is on the local disk for each HANA host. In a disaster recovery setup with disk-based replication, NetApp recommends creating four additional subdirectories in the FC5_shared volume for the /usr/sap/FC5 file system so that each database host has all its file systems on the central storage.
Note If SAP Local Secure Store service (LSS) is used, the /lss/shared/SID directory must be accessible at all hosts. NetApp recommends creating a volume for the /lss/shared/SID directory and mount it at all hosts using NFS.
Create LVM volume groups and logical volumes
  1. Initialize all LUNs as a physical volume.
    pvcreate /dev/mapper/hana-FC5_data_mnt00001
    pvcreate /dev/mapper/hana-FC5_data2_mnt00001
    pvcreate /dev/mapper/hana-FC5_data_mnt00002
    pvcreate /dev/mapper/hana-FC5_data2_mnt00002
    pvcreate /dev/mapper/hana-FC5_log_mnt00001
    pvcreate /dev/mapper/hana-FC5_log2_mnt00001
    pvcreate /dev/mapper/hana-FC5_log_mnt00002
    pvcreate /dev/mapper/hana-FC5_log2_mnt00002
  2. Create the volume groups for each data and log partition.
    vgcreate FC5_data_mnt00001 /dev/mapper/hana-FC5_data_mnt00001 /dev/mapper/hana-FC5_data2_mnt00001
    vgcreate FC5_data_mnt00002 /dev/mapper/hana-FC5_data_mnt00002 /dev/mapper/hana-FC5_data2_mnt00002
    vgcreate FC5_log_mnt00001 /dev/mapper/hana-FC5_log_mnt00001 /dev/mapper/hana-FC5_log2_mnt00001
    vgcreate FC5_log_mnt00002 /dev/mapper/hana-FC5_log_mnt00002 /dev/mapper/hana-FC5_log2_mnt00002
  3. Create a logical volume for each data and log partition. Use a stripe size that is equal to the number of LUNs used per volume group (in this example, it is two) and a stripe size of 256k for data and 64k for log. SAP only supports one logical volume per volume group.
    lvcreate --extents 100%FREE -i 2 -I 256k --name vol FC5_data_mnt00001
    lvcreate --extents 100%FREE -i 2 -I 256k --name vol FC5_data_mnt00002
    lvcreate --extents 100%FREE -i 2 -I 64k --name vol FC5_log_mnt00002
    lvcreate --extents 100%FREE -i 2 -I 64k --name vol FC5_log_mnt00001
  4. Scan the physical volumes, volume groups, and vol groups at all other hosts.
modprobe dm_mod
pvscan
vgscan
lvscan
Note If these commands do not find the volumes, a restart is required.
To mount the logical volumes, the logical volumes must be activated. To activate the volumes, run the following command:
vgchange -a y
Create file systems
Create the XFS file system on all data and log logical volumes.
mkfs.xfs /dev/mapper/FC5_data_mnt00001-vol
mkfs.xfs /dev/mapper/FC5_data_mnt00002-vol
mkfs.xfs /dev/mapper/FC5_log_mnt00001-vol
mkfs.xfs /dev/mapper/FC5_log_mnt00002-vol
Create mount points
Create the required mount point directories, and set the permissions on all worker and standby hosts:
sapcc-hana-tst:/ # mkdir -p /hana/data/FC5/mnt00001
sapcc-hana-tst:/ # mkdir -p /hana/log/FC5/mnt00001
sapcc-hana-tst:/ # mkdir -p /hana/data/FC5/mnt00002
sapcc-hana-tst:/ # mkdir -p /hana/log/FC5/mnt00002
sapcc-hana-tst:/ # mkdir -p /hana/shared
sapcc-hana-tst:/ # chmod -R 777 /hana/log/FC5
sapcc-hana-tst:/ # chmod -R 777 /hana/data/FC5
sapcc-hana-tst:/ # chmod 777 /hana/shared
Mount file systems
To mount the /hana/shared file systems during system boot using the /etc/fstab configuration file, add the /hana/shared file system to the /etc/fstab configuration file of each host.
sapcc-hana-tst:/ # cat /etc/fstab
<storage-ip>:/hana_shared /hana/shared nfs rw,vers=3,hard,timeo=600, intr,noatime,nolock 0 0
Note All the data and log file systems are mounted through the SAP HANA storage connector.
To mount the file systems, run the mount -a command at each host.
