SAP HANA on NetApp AFF Systems with Fibre Channel Protocol
The NetApp AFF product family is certified for use with SAP HANA in TDI projects. This guide provides best practices for SAP HANA on this platform for FCP.
Marco Schoen, NetApp
Introduction
The NetApp AFF/ASA A-Series product family has been certified for use with SAP HANA in tailored data center integration (TDI) projects.
This certification is valid for the following models:
AFF A20, AFF A30, AFF A50, AFF A70, AFF A90, AFF A1K
For a complete list of NetApp certified storage solutions for SAP HANA, see the Certified and supported SAP HANA hardware directory.
This document describes AFF configurations that use the Fibre Channel Protocol (FCP).
The configuration described in this paper is necessary to achieve the required SAP HANA KPIs and the best performance for SAP HANA. Changing any settings or using features not listed herein might cause performance degradation or unexpected behavior and should only be done if advised by NetApp support. |
The configuration guides for AFF systems using NFS and NetApp FAS systems can be found using the following links:
In an SAP HANA multiple-host environment, the standard SAP HANA storage connector is used to provide fencing in the event of an SAP HANA host failover. Always refer to the relevant SAP notes for operating system configuration guidelines and HANA specific Linux kernel dependencies. For more information, see SAP Note 2235581 – SAP HANA Supported Operating Systems.
SAP HANA tailored data center integration
NetApp AFF storage systems are certified in the SAP HANA TDI program using both NFS (NAS) and FC (SAN) protocols. They can be deployed in any of the current SAP HANA scenarios, such as SAP Business Suite on HANA, S/4HANA, BW/4HANA, or SAP Business Warehouse on HANA in either single-host or multiple-host configurations. Any server that is certified for use with SAP HANA can be combined with NetApp certified storage solutions. The following figure shows an architecture overview.
For more information regarding the prerequisites and recommendations for productive SAP HANA systems, see the following resource:
SAP HANA using VMware vSphere
There are several options to connect storage to virtual machines (VMs). The preferred one is to connect the storage volumes with NFS directly out of the guest operating system. This option is described in SAP HANA on NetApp AFF Systems with NFS.
Raw device mappings (RDM), FCP datastores, or VVOL datastores with FCP are supported as well. For both datastore options, only one SAP HANA data or log volume must be stored within the datastore for productive use cases.
For more information about using vSphere with SAP HANA, see the following links:
