NetApp solutions for SAP
I/O stack configuration for SAP HANA
Contributors netapp-mschoen kevin-hoke
Starting with SAP HANA 1.0 SPS10, SAP introduced parameters to adjust the I/O behavior and optimize the database for the file and storage systems used.
NetApp conducted performance tests to define the ideal values. The following table lists the optimal values inferred from the performance tests.
Parameter Value
max_parallel_io_requests
128
async_read_submit
on
async_write_submit_active
on
async_write_submit_blocks
all
For SAP HANA 1.0 versions up to SPS12, these parameters can be set during the installation of the SAP HANA database, as described in SAP note 2267798: Configuration of the SAP HANA Database During Installation Using hdbparam.
Alternatively, the parameters can be set after SAP HANA database installation by using the hdbparam framework.
nf2adm@sapcc-hana-tst-06:/usr/sap/NF2/HDB00> hdbparam --paramset fileio.max_parallel_io_requests=128
nf2adm@sapcc-hana-tst-06:/usr/sap/NF2/HDB00> hdbparam --paramset fileio.async_write_submit_active=on
nf2adm@sapcc-hana-tst-06:/usr/sap/NF2/HDB00> hdbparam --paramset fileio.async_read_submit=on
nf2adm@sapcc-hana-tst-06:/usr/sap/NF2/HDB00> hdbparam --paramset fileio.async_write_submit_blocks=all
Starting with SAP HANA 2.0, hdbparam was deprecated and the parameters were moved to global.ini. The parameters can be set using SQL commands or SAP HANA Studio. For more details, see SAP note 2399079: Elimination of hdbparam in HANA 2. The parameters can also be set within the global.ini as shown below:
nf2adm@stlrx300s8-6: /usr/sap/NF2/SYS/global/hdb/custom/config> cat global.ini
[fileio]
async_read_submit = on
async_write_submit_active = on
max_parallel_io_requests = 128
async_write_submit_blocks = all
As of SAP HANA 2.0 SPS5, you can use the setParameter.py script to set the correct parameters:
nf2adm@sapcc-hana-tst-03:/usr/sap/NF2/HDB00/exe/python_support>
python setParameter.py -set=SYSTEM/global.ini/fileio/max_parallel_io_requests=128
python setParameter.py -set=SYSTEM/global.ini/fileio/async_read_submit=on
python setParameter.py -set=SYSTEM/global.ini/fileio/async_write_submit_active=on
python setParameter.py -set=SYSTEM/global.ini/fileio/async_write_submit_blocks=all
